Expert Sleepers ES-9 USB Audio Interface
escargot
Re: Expert Sleepers ES-9 USB Audio Interface
Post by escargot » Wed Aug 05, 2020 6:43 am
i can't figure out how to use inputs 9-14! could someone share some lights? can't see the inputs in my DAW. must be the config tool not well setup...i have inputs 1-14 on the USB block though. 1-8 outputs in my daw, but not 9-14.
not getting the buses either...
also are the spdf i/o: what is the use of that??
Post by os » Wed Aug 05, 2020 6:49 am
Which DAW?
Can you post a screenshot of your config?
Multi Grooves
Post by Multi Grooves » Wed Aug 05, 2020 11:30 am
Andrew, can we get a solid actual date for the next batch is out- some of us need to plan accordingly for purchases @£500?
...but Cynthia, my Daddy never had a heath kit..
escargot
Post by escargot » Thu Aug 06, 2020 6:33 am
Which DAW?
Ableton
Live- Using aggregate device RME UFX+ ES9
Post by os » Thu Aug 06, 2020 6:50 am
It would also help to see the ES-9 config, and the Aggregate setup in the Audio MIDI Setup utility.
ForeignKeys
Post by ForeignKeys » Fri Aug 07, 2020 3:14 pm
:agree:
note!
Post by note! » Tue Aug 11, 2020 1:32 pm
:agree:
+1, my preorder has been in limbo for many weeks!
iamkory
Post by iamkory » Sun Aug 16, 2020 10:35 pm
transferpoint wrote:
Sat Jan 25, 2020 10:51 am
Jaypee wrote:
Sat Jan 25, 2020 4:45 am
I have very low but audible high frequencies noise from input 1&2. No pb at all, dead quiet on the others.
I haven't noticed it till recently in studio recording situation.
Will do a screenshot next week.
Meanwhile, can you check if you guys have similar problem?
Every one of my channels hiss. :/
Oof, yeah I have VERY noticeable, high frequency noise from mine. Have tried different power connections, cables. No grounding issues. Really frustrating. Any luck with yours?
Wubz
Post by Wubz » Tue Aug 18, 2020 9:36 am
I had this issue, got a replacement from Os. New one is perfect.
bengarland
Post by bengarland » Tue Aug 18, 2020 9:42 am
I posted months ago (last year?) about Inputs 1 and 2 being noisier than the others and was told this was normal and due to the way it's designed. Who knows.
Ears
Post by Ears » Tue Aug 18, 2020 8:09 pm
I have a ES-8 attached to my PC sound card using ADAT - this is how I record my modular. I added an ES-9 to my rack originally thinking I’d use it with my iPad only for all the fun of combining iPad and Eurorack. But on a whim tonight I decided to try also plugging my ES-9 into the PC and using ASIO4ALL to create an aggregate device. Shockingly it all worked fine. Not sure if it will stand up in a long session but was amazed that the basic test worked well. Past experience with ASIO4ALL wasn’t great so my expectations were low.
Anyone else playing with similar setups to record and control lots of Expert Sleepers in/outs to a Windows PC? Hows that working out?
escargot
Post by escargot » Wed Aug 19, 2020 12:13 am
sorry for late reply- here are screenshots
Post by os » Wed Aug 19, 2020 2:24 am
You'll want 'drift correction' enabled for the ES-9, if the UFX is the clock source.
ES-9 inputs 1-14 will be inputs 31-44 in your DAW. I don't see those channels activated in your Live screenshot.
escargot
Post by escargot » Wed Aug 19, 2020 7:42 am
thank you sir!
ForAiur
Post by ForAiur » Wed Aug 26, 2020 10:15 am
From the manual "Channel numbering
The default channel numbering in your DAW will appear as follows, though this can be
reconfigured as required."
How can this be achieved? And how can I rename the ES-9? It only shows up as "8 - Midi Input" at the moment, somehow it lost its naming.
Post by os » Wed Aug 26, 2020 10:20 am
Use the configuration tool to change which USB channels correspond to which inputs/outputs.
No idea why your ES-9 would be called "8". Is this on mac or pc?
Wubz
Post by Wubz » Wed Aug 26, 2020 1:21 pm
I have mine aggregated with a clarett 8pre and it works like a hot damn!!
Orange
Post by Orange » Wed Aug 26, 2020 1:40 pm
Wait! You mean with a pc?
I’m planning to buy the es-3 and es-6, but I really hope the es-9 can work as an aggregated device with my babyface pro and laptop :hyper:
Wubz
Post by Wubz » Wed Aug 26, 2020 3:22 pm
No, with a Mac.
Orange
Post by Orange » Wed Aug 26, 2020 4:48 pm
No, with a Mac.
:cry:
Ears
Post by Ears » Wed Aug 26, 2020 7:25 pm
No, with a Mac.
:cry:
I have bonkers level aggregation going on my PC and it’s working so far (just started using last week so fingers crossed). ES-9 aggregated with a audio interface that has ADAT that I connect to a ES-8. I’ve not checked to see if there are timing issues on long tracks, but there are ways to solve for that as well I’ve read. I’ll be interested in seeing how it all works for you.
tonefloat
Post by tonefloat » Tue Sep 01, 2020 2:49 pm
Any intel here on dates for new stock? various vendors reporting various estimated dates - one i see is up to Nov.
Calverhall
Post by Calverhall » Wed Sep 02, 2020 8:59 am
I ordered an ES-9 at the stroke of June, was supposed to be arriving by tomorrow, but gear4music had not charged me, I emailed to ask whats happening. Apparently the supplier has been unable to meet the date and they are now saying November. Bit gutted, might have to get an ES-8 for the meantime.
Post by os » Wed Sep 02, 2020 9:17 am
There will be ES-9s before November.
tonefloat
Post by tonefloat » Thu Sep 03, 2020 12:13 pm
:tu:
