Tasty Chips ECR-1 Convolution Reverb
- Dark Barn
- Wiggling with Experience
- Contact:
Re: Tasty Chips ECR-1 Convolution Reverb
Mine finally scanned in to US Customs! Hadn’t budged on the tracker since April 23rd. If you’ve been anxiously waiting for one I thought you’d like to hear that.
damn that's great news. i ordered mine on april 17th and it's been in limbo in between NL and los angeles since may 5th.
+1 this is great news, thank you!! Still waiting in limbo today but fingers crossed. I'm in LA area as well.
- Super Deluxe Wiggler
- Contact:
the site seems down, same for you?
- wavejockey
it's up again
I wonder if these will load ( wavs ) been waiting for a hardware convolution reverb to load these for years.
1925 Individual custom Impulse responses
Banks
12 Alesis quadraverb
13 Eventide H3000 Space
14 Eventide H8000 Enviroments
15 Eventide H8000 Space
16 Outdoor spaces
17 Psychoacoustics
18 Roland Rss10
19 Spektral rooms
20 Spektral sfx
21 Springs and things
22 Vintage fx
23 Virtual Enviroments
24 Virtual Micro
25 Virtual Space
26 Ursa major
27 Lexicon 224 ambience
27 Quantec
28 Tc 6000
29 Lexicon 960 Reverbs
30 Lexicon 960 sfx
31 Lexicon 224 ambience
32 Lexicon 224 Halls 1
33 Lexicon 224 Halls 2
34 Lexicon 224 Orchestral
35 Lexicon 224 Plates 1
36 Lexicon 224 Plates 2
37 Lexicon 224 Vocal
38 Tc electronic Vss3
39 Ewql Churches
40 Ewql Offbeat
41 Ewql Plates
Banks
16 Outdoor spaces
17 Psychoacoustics
18 Roland Rss10
19 Spektral rooms
20 Spektral sfx
22 Vintage fx
24 Virtual Micro
25 Virtual Space
26 Ursa major
27 Quantec
28 Tc 6000
30 Lexicon 960 sfx
39 Ewql Churches
40 Ewql Offbeat
41 Ewql Plates
Can anyone highlight how many impulses a card can hold and whether the card can contain different folders of impulses ?
As far as my tests go, it would be very well possible for
those IRs to load. I’ve successfully loaded a
couple from different sources. Though I haven’t tried these specifically.
W.r.t the amount: I’ve loaded over 200 on a card, and I suppose the limit is possibly only restricted by the size of the card. The catch is that there is no folder support currently, so browsing many IRs is a bit cumbersome.
- Contact:
Ok it's 1811 EST and it looks down again. How am I supposed to order a module I can't even get to the site of? I gotta say I'm a little nervous ordering an expensive module that depends on firmware if they can't keep a website up.
Probably just demand is higher than they anticipated and they didn't buy enough server bandwidth before launching this thing or something. I doubt it's due to the technical deficiencies of Tasty Chips' programmers.
- Contact:
No I get it, but I don't get why they don't get a distributor or host or something. This is the third time I've tried to go to their site (with the intention of buying) but it won't load. Is anyone distributing this?
- Dark Barn
- Contact:
Both times you’ve reported the site being down I’ve opened it fine on my end. Perhaps there is another issue? Maybe you could email them directly at info@tastychips.nl and see if they can help you out.
- wavejockey
btw, firmware update(s) are not possible on user end, they 'll have to change chips, hence the name
Under 'Control voltages' the ECR-1 manual states that the "Aux" CV input "currently modulates pitch bend", but the diagram states that it currently modulates the wet signal. Which is the actual default status, and can the Aux CV input be reassigned easily?
- Contact:
Interesting. I used a US-based proxy and it came up fine. Very strange bc I am not with a small provider or anything like that. I tried on 2 different computers (two different OS) both with the same results but the proxy comes up fine. Very strange.Dark Barn wrote: ↑Fri May 22, 2020 8:05 amBoth times you’ve reported the site being down I’ve opened it fine on my end. Perhaps there is another issue? Maybe you could email them directly at info@tastychips.nl and see if they can help you out.
I’ve tried the 2nd edition of these IRs and they sound really interesting! Especially those vintage reverb plates and the ones with harmonics. Works well in the ECR-1.1kip wrote: ↑Sat May 02, 2020 5:01 pmI have also heard these which sound fabulous!
https://vintagesynthpads.com/ocart/impu ... _Responses
By the way, if someone has other ideas of IRs, it would be interesting to post them here![]()
That said, does anyone know if you can extract the IRs from altiverb, or know of any high quality room response library? Ideally in stereo?
There are a few free libraries online that might do the trick:erde wrote: ↑Sat May 23, 2020 2:53 amI’ve tried the 2nd edition of these IRs and they sound really interesting! Especially those vintage reverb plates and the ones with harmonics. Works well in the ECR-1.1kip wrote: ↑Sat May 02, 2020 5:01 pmI have also heard these which sound fabulous!
Lexicon 480
https://www.housecallfm.com/download-gn ... xicon-480l
Bricasti M7
https://web.archive.org/web/20190201211 ... responses/
(it's a wayback machine link, but it works, be it very slowly:) )
Waves
https://www.waves.com/downloads/ir-conv ... rb-library
(needs a login)
Open air lib
https://www.openair.hosted.york.ac.uk/?page_id=36
If anyone knows any more places feel free to share.
Currently it modulates the wet knob.
As far as i know there's currently no possibility to change this.
Thank you for the awesome suggestions! One question though: The Waves IRs are in the wir format; It seems proprietary found some info here: http://freeverb3vst.osdn.jp/tips/tips.shtml -- but can the ECR-1 read it? Did you try? Or do I need to write my own converter for it?nikmettez wrote: ↑Sat May 23, 2020 5:30 amWaves
(needs a login)
I personally don't pitch the impulses all that much, as i find results not that pleasing for my applications.
One thing i really like doing is setting the release quite short and setting or modulating the position. When a reverb dies out, it loses high frequencies so it colours the sound in a very nice way. Great for percussion.
I completely forgot about them being in .wir extension. I have a folder on my computer where i store all my found and created impulses, but i didn't use the waves ones yet.erde wrote: ↑Sat May 23, 2020 8:32 amThank you for the awesome suggestions! One question though: The Waves IRs are in the wir format; It seems proprietary found some info here: http://freeverb3vst.osdn.jp/tips/tips.shtml -- but can the ECR-1 read it? Did you try? Or do I need to write my own converter for it?nikmettez wrote: ↑Sat May 23, 2020 5:30 amWaves
(needs a login)
If you get them to work, drop a line...
I actually managed to pull out IRs from them using the commandline and sox, if they are stereo:nikmettez wrote: ↑Sat May 23, 2020 9:16 amI completely forgot about them being in .wir extension. I have a folder on my computer where i store all my found and created impulses, but i didn't use the waves ones yet.erde wrote: ↑Sat May 23, 2020 8:32 amThank you for the awesome suggestions! One question though: The Waves IRs are in the wir format; It seems proprietary found some info here: http://freeverb3vst.osdn.jp/tips/tips.shtml -- but can the ECR-1 read it? Did you try? Or do I need to write my own converter for it?nikmettez wrote: ↑Sat May 23, 2020 5:30 amWaves
(needs a login)
tail -c +125 inputIR.wir | sox --norm -t raw -b 32 -c 2 -r 48000 -e float - -b 16 --norm outputIR.wav
YMMV
Re my above questions, I've just had this reply from Tasty Chips on messenger via their FB page.
"We'll release a V2 DIMM (you can swap out the DIMM) on the back of the module and this will feature assignable aux, and a lot of other features."
Cool stuff!
