I love the sound. The fact that you can't save your settings when powering down is pretty annoying tho.
Dual FSR? I've got 10hp left on my 1U line, and was wondering how useful these are.
i've only had this case for a couple weeks now, but i've liked having both fsrs. i got a good deal on the case and a few modules and decided to replace my 0-coast/0-ctrl combo with it, so the fsrs give me some of the tactile-ness of the 0-ctrl. i definitely don't always use both, but i find it's fun when i do. so far i've tended to keep my finger on one for slow naturalizing sorts of modulation and then go wild on the second. i do find it hard to actively engage with both at the same time because of their sensitivity/response curve/whatever, but there's a 90%+ chance that's user error :p
nope. i'm mostly using saich's internal interval control so far, but i'm sure i'll be using the duatt to set pedal notes or the sloths to make drifting drones or finding other wonky ways of using what's in the rack. my goal with this rack is for it to be a harmony-focused drone machine that i can tweak/perform using the knobs and fsr modules.
Interesting. I think having the 1U at the bottom, and the mults as at the top makes lots of sense, especially if you have a headphone jack out.Biff wrote: ↑Fri Apr 09, 2021 3:58 pmI don’t know if someone has posted this idea before, but I made wood sides for my pallete that allowed me to reverse the 1u and 3u but keep the power unit at top. Here is how my system looked in its last iteration (I’ve since grown). I left a slip on the bottom right for power modules if they didn’t fit. I also made the wood side a little above the ground so wires could go underneath and wrap to the multiples with less of a wire rat king mess.
No, the underbelly is there. The only thing different are the sides swapped of wooden ones I made so the rails would fit a 3u over 1u configuration, everything else is from the palette.Kosmikos wrote: ↑Fri Apr 09, 2021 4:34 pmInteresting. I think having the 1U at the bottom, and the mults as at the top makes lots of sense, especially if you have a headphone jack out.Biff wrote: ↑Fri Apr 09, 2021 3:58 pmI don’t know if someone has posted this idea before, but I made wood sides for my pallete that allowed me to reverse the 1u and 3u but keep the power unit at top. Here is how my system looked in its last iteration (I’ve since grown). I left a slip on the bottom right for power modules if they didn’t fit. I also made the wood side a little above the ground so wires could go underneath and wrap to the multiples with less of a wire rat king mess.
I guess you have no underbelly plate? That wouldn’t work for me.
