Schippmann to end Eurorack production
Ceres
Re: Schippmann to end Eurorack production
Post by Ceres » Thu Jan 30, 2020 10:15 pm
Schippmann wrote:
Thu Jan 30, 2020 5:54 pm
Ceres wrote:
Thu Jan 30, 2020 4:00 pm
maltemark wrote:
Wed Jan 29, 2020 12:10 pm
Badass how compared to other quadratures?
It appears to be a unique dual LFO but I don’t understand not having 4 quadrature outputs (0, 90, 180, 270). I mean that’s usually the point of a quadrature LFO. It appears this is more focused on being a dual LFO where you can do some fun weird things with the shapes of the LFOs, including shifting the degree.
No. Quadrature doesn't mean to have 4 ouputs. It means to have two orthogonal outputs (SINE/COSINE) where you can generate
by adding/substracting these 2 orthogonal outputs any other phase displacement between 0° - 360°.
But yes, it's certainly a fun tool - I hope so, guys:)!!
I understand what your saying. You can do similar quadrature modulation with Maths. Colloquially, modules called “quadrature LFOs” were/are LFOs with 4 outputs set 90 degrees apart. Doepfer A-143-9, Liivarta Quadrature LFO, yusynth quadrature LFO, Seismic Quadrature LFO, Ian Fritz Quadrature Oscillator, Quadrature apps in Ornaments and Crime and so forth...
If you don't know where you are going, any road will get you there.
monads
Post by monads » Thu Jan 30, 2020 10:21 pm
Well I'm on board with both these new modules!!! Probably means shuffling some items around but I'm good to go!!!
damase
Post by damase » Fri Jan 31, 2020 12:14 am
how far off are we from being able to order these :) very excited for them
Schippmann
Filtermeister!
Post by Schippmann » Fri Jan 31, 2020 8:36 am
Invert each output and you'll get the other two phases - nothing more is what the others did. I hadn't the space for 4 further jacks.
But the main feature is given - a quadrature output.
Schippmann
Filtermeister!
Post by Schippmann » Fri Jan 31, 2020 8:43 am
3pand wrote:
Thu Jan 30, 2020 7:40 pm
"Reverse" is a sync function which will reverse the current direction of the Triangle.
Moreover you can select 0-16 shots, where the Tri exactly ends at that point where it has been started.
The starting/ending point (including direction) is the "State" parameter.
When 0 shots is selected, the LFO is free running, but will go immediately to this selected state
and stops with a "high" at the "start/S&H" input jack - and it oscillates when the "start/S&H" input returns to "low".
"S&H" here means Set & Hold;) In shot case (1-16) the osc. is in stop mode and is set on the "State" value. A "high" at "start/S&H"
will start the shot then.
Thanks, I was very curious about the function of the 0-16 and the Start/S&H. Sounds like an amazing module for generating repeating and evolving rhythmic patterns, among other things!
On the DTG, what do the G/Del~ and G-Res jacks do? I’m also wondering how the Hold In functions and what the Dec-Act. output is.
G/Del~ is to select between Gate-function (generating a gate pulse with definite length) and Gate-Delay-function. G-Res is Gate Reset in Gate-mode.
Decay-Active is "high" when the decay phase starts (after attack, before release). A "high" at "Hold" will freeze the current state of the env immediately. By combining the Gate and the env, e.g., you can implement a hold-phase after attack or start the env with a delay after trigger asf.
Jaypee
Post by Jaypee » Fri Jan 31, 2020 10:43 am
My brain just explosed :hail:
"Those aren't your daddy's waveforms " Cynthia Webster
Schippmann
Filtermeister!
Post by Schippmann » Fri Jan 31, 2020 8:58 pm
Yes, exactly - thanks! This was my intention and idea about a shot-LFO/modulator. you can generate triplets, quintuplets and many many more.
Moreover it is possible to change every parameters during the shot. E.g., you could change with some CV-channels (CV-Freq, CV-Num) super fast from a triplet to a quintuplet - the range of possibilities goes to totaly weird patterns (syncing, shape changes, state changes,....).
3pand
Post by 3pand » Fri Jan 31, 2020 11:14 pm
So cool. As I drive around Los Angeles stuck in traffic I’ve been patching this module in my head (there’s obviously something wrong with me) and it already feels like it has such a nice balance between determining a larger metric architecture and then letting the smaller rhythmic vegetation grow and run wild inside of that.
Like using the square on one side through a clock divider and then switching or mixing the two sides while changing the shape, freq, etc.
Really fantastic!
Portabella
Post by Portabella » Sun Feb 02, 2020 7:11 pm
That's some great news here ! :goo: :yay:
I am completely sold on the LFO !
Finally something new in the Eurorack-world.
I got so freaking bored of all the new modules recently..
Another standart filter, another LFO.. jeez
We need innovative modules/instruments!
This is why Carsten Schippmann is one of the greatest designer of Eurorack.
Jaypee
Post by Jaypee » Mon Feb 03, 2020 1:26 am
Modules are up on modulargrid :miley:
oneiric.tomb
Post by oneiric.tomb » Thu Feb 06, 2020 3:51 am
:goo:
Now you guys believe me? Lol
When do the preorder start though!?
FS:
L-1 Stereo Compressor
WTB:
Schippmann Omega Phi mk2
Cwejman BLD-2
Cwejman PH-8
Jee
Post by Jee » Sun Feb 09, 2020 4:35 am
The designs are incredible, love them already, so much to dig!
I still have a few questions though on DTG:
the VCA out is for shaping the envelope output only or does the envelope actually processes audio with internal pre-routing of the env out to the VCA?
I don't see any audio in so I'm slightly confused.
The gate-O is a replica of the gate input ?
A switch would have been more convenient than a jack for Gate/Delay ? Not sure how I would automate that with CV...
The curves are linear on all segments ? Modulating a linear env with itself gives an expo response maybe that's something to do with the VCA?
Schippmann
Filtermeister!
Post by Schippmann » Sun Feb 09, 2020 8:32 am
VCA out is same as Env out. Gate out is a gate with definte lenght, independently of gate in, same with delay mode.
A switch cost 6 times of a jack and waste space, take a dummy plug and it's sitched to delay mode. Curves are exponential, where attack is cut at 63% of asymptote. Pos./neg. feedback from Env out to any CV-input (attack, decay, release) will lead to konvex/konkav bending - only 1/20 (very weak feedback) will cause clearly results, but the time is to correct manually.
weirdo
Post by weirdo » Mon Feb 10, 2020 11:55 am
Ich hätte auch gern jeweils 1 von den Modulen. LG, Tobias!
Jee
Post by Jee » Tue Feb 11, 2020 2:04 pm
OK fair point with the swith / plug dummy cable :)
So we get a dedicated VCA to modulate the env out actually, it's super neat for patching purposes and therefore will be very useful creatively speaking!
And the curved shape is great for dynamic stuff, that was clearly my favorite setting of the EG in EuF. Cool !! :sb:
I am not sure I got this sentence right though:
>> means a very small amount of feedback will cause big effects right?
I'm totally sold anyway, now the real question is when do they come :hail:
Passing by your VCO makes miracles with all sorts of sounds... here one of the gnarliest bass I played with, patched in 15mn with heavy FM and other stuff played with touché all along the track. Damn it's so good,intense and lively feeling to play your instruments Carsten, this modular is a pure sound jewell. And it sits perfectly with other instruments, the takes from the modular are raw in the track I added nothing on top (there is a 4ms DLD though) except the master limiter that is VST (barely used)!!!
I could never disagree more with those who think a modular sound crap and needs tons of processing afterwards, it's rather the opposite to me :)
https://soundcloud.com/jeeboo/creation-21
3pand
Post by 3pand » Tue Mar 03, 2020 4:03 pm
According to the website, prototyping is now complete on the dual quadrature-LFO!
Jaypee
Post by Jaypee » Wed Mar 04, 2020 6:58 am
damase
Post by damase » Wed Mar 04, 2020 8:52 am
“what a cool tool”
:cloud:
cant wait!
Jee
Post by Jee » Fri Mar 06, 2020 2:04 pm
Current project:
dual quadrature-LFO (1-16 shots)
Prototyping complete - excellent!
Current project:
dual transient generator
Prototyping...works excellently!
:omg:
3pand
Post by 3pand » Mon Mar 16, 2020 2:21 pm
DTG prototyping complete!
damase
Post by damase » Tue Mar 17, 2020 8:58 am
super excited of course.
been patching the OmegaPhi double saw a lot lately, gets some incredible string sounds through an lpg. so expressive when mixing with the phased outputs
tip... if you have a Verbos Random Sampling... plug in quantized random outs into the Omega Phi fm input with the switch to AC coupled. gets some really expressive pitch “blips” as you turn the distribution knob and the new value is quantized and some kind of DC spike is sent but filtered out by the Ophi. sounds beautiful on a melodic line through a delay. assuming this works with any quantized randoms and other AC coupled inputs too.
cheers yall, cant wait for the new schippmanns :party:
Jaypee
Post by Jaypee » Tue Mar 17, 2020 4:34 pm
pleaaaaase share some sounds damase!!!
damase
Post by damase » Wed Mar 18, 2020 8:22 am
I dont currently have demo sounds at the moment of the technique i described(the recordings are for my next release).
...but I did just upload my new record up to soundcloud, this track in particular is centered around a mono synth type patch, 2x OmegaPhi with Tzfm /pm through VCF-1e, recorded twice over for the lead (comes in around 1:45) and for the blade runner bass thing
https://soundcloud.com/damasemusic/terminus-aureole
(track is now in my sig)
euxine
Post by euxine » Wed Mar 18, 2020 8:26 am
If Schippmann is not ending production after all, maybe time for a new thread? :hmm:
damase
Post by damase » Wed Mar 18, 2020 8:30 am
the website indicates that he will be stopping eurorack production, these new modules are limited one time offerings (although we all hope he changes his mind)
i see how its confusing if you havent been following though
