Schippmann to end Eurorack production
Jee
Re: Schippmann to end Eurorack production
Post by Jee » Mon Sep 28, 2020 6:26 pm
Quad invert is a CV inverter, not a gate inverter it will not work as expected (0V in = 0V out).
You also now know that I’m doing all x4 so plog has been discarded I prefer a (much) more compact and oriented module even if I don’t have all logic functions (it’s mainly inverting I need) ;)
22tape
Post by 22tape » Mon Sep 28, 2020 7:50 pm
If Schippmann ever really does end Eurorack production, we will have to start another thread entitled-- Schippmann releases new slate of modules.
damase
Post by damase » Mon Sep 28, 2020 8:09 pm
right on thanks for mentioning that before i got the quad inverter and would have been very disappointed. im certainly interested in all logic combinations, have a lot of gates i can combine to do ratcheting n such on the DTG. keep us updated on the upcoming quad gate inverter you spoke of
mazzatronsynths
Post by mazzatronsynths » Tue Sep 29, 2020 12:37 pm
damase wrote:
Mon Sep 28, 2020 7:04 am
theres an Intellijel Quad Invert, that should work right? i was thinking about getting one for the DTG
i was also lookin at Intellijel Plog, seems unmatched for compact logic modules
and a couple Frap Tools 333, maybe a 321 also
been trying to decide on utilities for a while and this is my best effort.
Hello! I looked a little into the Intellijel Quad Inverter and it seems like it inverts CV or gate signals centered around zero volts. So, a 0V to +5V signal would become a 0V to -5V signal. Where the module we are working on here will take a 0V to +5V signal and invert it to a +5V to 0V signal. So, it will be a purely digital gate inverter!
Cheers!
Sean
Jee
Post by Jee » Tue Sep 29, 2020 1:26 pm
Hi Sean, thanks for passing by :)
Trying to hijack the regular use before it even exist: what would happen if we send it a negative CV signal? Would be treated as 0 I assume?
cheers!
mazzatronsynths
Post by mazzatronsynths » Wed Sep 30, 2020 4:01 pm
cheers!
Hi Jee!
Yes, a negative signal at the input will result in 5V at the output. The output will always be either 0V or 5V. The positive-going threshold will be 1.5V and the negative-going threshold will be 1V. And there will be over-under voltage protection so it will be able to handle anything -12V to +12V at the inputs and at the outputs without damage. Revised panel layout attached.
Cheers!
Sean
mazzatronsynths
Post by mazzatronsynths » Sat Oct 17, 2020 12:36 pm
Hey Guys!
The Quad Gate Inverter is now available!
https://www.mazzatron.com/product-page/ ... e-inverter
Cheers!
Sean Mazzatti
pekbro
Post by pekbro » Sat Oct 17, 2020 6:38 pm
Hey Guys!
Cheers!
Sean Mazzatti
Instabuy :tu: (and I wasn't even in this thread)
Jee
Post by Jee » Sun Oct 18, 2020 1:23 am
So cool ! :)
Thanks Sean!!
