Ochd by Instruo / DivKid
mother misty
Post by mother misty » Wed Dec 18, 2019 11:51 am
Interesting new module announced from Instruo & Divkid
It's a modulation source with 8 LFO's in 4HP
[video]http://www.youtube.com/watch?v=ZtLzzYUtZcw[/video]
ben_hex
Post by ben_hex » Wed Dec 18, 2019 12:29 pm
Hello all, thank you mother misty for starting the thread. I just came on here to do exactly that. I'll post all the information below, thanks for sharing the video. Lot of info here of course but people can skip it :hihi:
WORDS FROM ME
Hello hello, here's my second eurorack module øchd or ochd. It's pronounced "oct" as in octave or octuplet and as if by magic there's eight outputs on this module, an octuplet of analogue LFOs if you will. I often find I need more modulation, simple sources that will keep things moving and stop things getting repetitive. That’s why ochd was brought to life, to keep patches organically drifting and moving… and as it’s modular, we wanted an intuitive easy to use module with plenty of patchable tricks up it’s sleeves too!
ochd is a 4HP Eurorack module with eight analogue triangle LFOs. The outputs go from fast on the top output to slow on the bottom output. The default ranges are deliberate NOT synced. These are free running LFOs that were tuned by ear to be musical useful for a range of fast to slow modulations in a patch. Organic animation, drifting and musical phasing is the intention of the module. The rate control controls the rate of all LFOs globally and takes this into lower audio rates right down to 25 minute cycles on the lowest output. This can be extended even slower with CV, with the CV input and attenuverter on board and we can also track and hold the outputs with a negative CV, interrupting and holding modulation values with external gates of CVs. Another trick to take this from simple triangle shapes is to patch a spare output into the CV input and wave shape with feedback. Exponential curves, odd squares, stepped waveforms and more are available with some adjustment of the attenuverter and using different outputs to voltage control itself.
While patching a prototype at DivKid HQ Richard Devine said this was "the most organic little modulator ever" - lovely stuff!
This module is made in collaboration with Instruo and I'm very proud to be part of their amazing line up of modules. https://www.instruomodular.com
The full product description and specs can be found on the Modular Grid link or my website link below
DivKid website
http://bit.ly/ochdDIVKIDWEBSITE
Modulargrid
http://bit.ly/ochdMODULARGRID
PRODUCT DESCRIPTION
Designed in collaboration with Ben “DivKid” Wilson, the Instruō øchd packs 8 all analogue LFO’s into a convenient 4HP package.
Each independent core is free running with rates con gured from fastest to slowest arranged from top to bottom. Each frequency range was tuned by ear during development to give the optimum spread of control frequencies running in parallel. Being 100% analogue, the LFO’s will phase organically with the ability to ebb and ow together with their global frequency control.
Modulation breathes life into otherwise static patches, but CV sources can often run out quickly. Even in larger systems. øchd adds a lot of movement without hogging a lot of space. Both small lunch box cases and larger set ups can be made to drift, move and organically change over time. With either subtle use of øchd to keep things alive or wider ranging use that drives a whole patch that drifts around itself.
FEATURES / SPECS
• 8 independent, un-synced free running analogue triangle LFO’s
• Wide frequency range across the oscillators (160Hz to 25 minute cycle time, this goes much lower with CV)
• CV controllable global rate with attenuverter
• Track and Hold capabilities using negative CV to stall oscillator cores
• Bipolar LED display for each LFO
• Self patchable for complex wave shaping
80 mA +12V
80 mA -12V
0 mA 5V
32 mm deep
STORES - either in stock now or in transit to be in stock very soon to the following ...
UK & EU
Cymru Beats (Bristol, England)
http://bit.ly/ochdCYMRUBEATS
Elevator Sound (Bristol, England)
http://bit.ly/ochdELEVATORSOUND
Escape From Noise (Stockholm, Sweden)
http://bit.ly/ochdESCAPEFROMNOISE
Matttech Modular (Manchester, England)
http://bit.ly/ochdMATTTECHMODULAR
MIDI Amsterdam (Amsterdam, Netherlands)
http://bit.ly/ochdMIDIAMSTERDAM
Patch Point (Berlin, Germany)
https://www.patch-point.com
Rubadub (Edinburgh, Scotland)
https://www.rubadub.co.uk
Schneidersladen (Berlin, Germany)
http://bit.ly/ochdSCHNEIDERSLADEN
Signal Sounds (Glasgow, Scotland)
http://bit.ly/ochdSIGNALSOUNDS
USA
Control (Brooklyn, New York)
http://bit.ly/ochdCONTROL
Perfect Circuit (Burbank, California)
https://www.perfectcircuit.com
FURTHER EAST
Clockface (Tokyo, Japan)
https://www.clockfacemodular.com/html/page5.html
Found Sound (Melbourne, Australia)
https://foundsound.com.au/
All DivKid video series to be found here!
http://www.youtube.com/divkidvideo
Modular Meets Electric Spring 2020 - THIS SUNDAY FEB 23RD - viewtopic.php?f=43&t=226844
matttech
Post by matttech » Wed Dec 18, 2019 1:01 pm
wicked little idea for a module - so simple, yet so useful and efficient in terms of HP-per-function without being really cramped :tu:
....and selling very fast!
:bananaguitar: :bananaguitar: :bananaguitar: :bananaguitar: :bananaguitar: :bananaguitar: :bananaguitar: :bananaguitar:
BlinkyLights
Post by BlinkyLights » Wed Dec 18, 2019 2:32 pm
Groovy.
Congratulations.
danishchairs
Post by danishchairs » Wed Dec 18, 2019 2:57 pm
Fantastic - congrats ben hex and Instruo! This looks perfect for the person who can never have enough LFOs (like me)!
Two questions (sorry if I missed this in the announcement video):
a) What voltage range is the input expecting?
b) What is the voltage range of the outputs?
Cheers!
Sound precedes music | Instruments for Neb2 module
kxx303
Post by kxx303 » Wed Dec 18, 2019 3:17 pm
Wow! All this time I was hoping someone will make a 4hp version of Batumi and here it is! Of course approach is different but it fits my needs. Gonna get one.
Thank you Ben Hex!
BC / MG / IG / YT
Post by lisa » Wed Dec 18, 2019 3:33 pm
Batumi has four separate LFOs and four different waveforms for each LFO. It can’t be compared to Ochd, can it? :)
Ochd is a simple but clever module, though. And everything Jason does seems to be of great quality. So this is a winner, surely.
My first modular track where I used drum modules! There's also a ton of FM cross modulation from the Instruō Cš-L in there and the Metasonix R56 is a big part of the sound. :star:
We also just did a live performance. Just eurorack, a mixer and two nitwits. :hyper: http://tiny.cc/8ndspz
Nutritional Zero
Post by Nutritional Zero » Wed Dec 18, 2019 3:45 pm
It says “bipolar LED display” but this doesn’t necessarily equal bipolar LFOs. Does anyone know the voltage range?
kxx303
Post by kxx303 » Wed Dec 18, 2019 3:51 pm
lisa wrote: It can’t be compared to Ochd, can it? :)
Well, my point of view is very subjective, I know. I mean I was going to get a Batumi, but in my case it would be an overkill. So Ochd is a better choice for me.
BC / MG / IG / YT
2disbetter
Post by 2disbetter » Wed Dec 18, 2019 3:53 pm
Instruo's design is top notch. I'm fairly certain anything they touch is going to be gold.
My synth is full at the moment, but I'm keeping on the radar should some room open up.
Congrats Ben! Super well executed!
cackland
Post by cackland » Wed Dec 18, 2019 3:56 pm
Very nice :)
djd_oz
Post by djd_oz » Wed Dec 18, 2019 4:13 pm
Well done Mr. Kid.
brandonlogic
Post by brandonlogic » Wed Dec 18, 2019 4:17 pm
Looks great. Want one! Was hoping this would be $150 usd not $180 though tbh.
pekbro
Post by pekbro » Wed Dec 18, 2019 4:30 pm
Nice, congratulations on the release. Added to wishlist :tu:
nios
Post by nios » Wed Dec 18, 2019 4:32 pm
I was kind of "meh" on Mutes because I already had that function covered, but an octo-LFO in only 4HP is insane. Quite often in planning out rack expansions, I've had a 4hp space possibly come up and I thought "nah, better just leave that open as future room to shuffle things for bigger modules" - here though is a module worthy of claiming a leftover pocket in a big system that gives a full-functioned-feeling result, or surely being a top-tier option in compact setups.
It's too bad their shapes can't be altered; it might have been nice to have jumpers on the back or something for that, even if it only changed the shape on all of them. I also wonder if a button toggle to select the individual LFOs to adjust rates individually could have been done over a CV/attenuator, but the idea of simultaneously tweaking 8 LFO rates at once via CV is also really cool and will encourage unconventional exploration.
Zymos
Post by Zymos » Wed Dec 18, 2019 5:17 pm
brandonlogic wrote:Looks great. Want one! Was hoping this would be $150 usd not $180 though tbh.
$185 at Control, and they are not even taking anymore preorders till they get the second batch. :cry: I should have jumped on it when I first heard about it this AM :doh:
cackland
Post by cackland » Wed Dec 18, 2019 5:25 pm
Gone already?? Damn!!
Johnnyfive
Post by Johnnyfive » Wed Dec 18, 2019 5:49 pm
this is such a great idea!
Nutritional Zero
Post by Nutritional Zero » Wed Dec 18, 2019 6:11 pm
Err.... Everyone forgets about Canada, but... any chance we’ll get?
Drilldoughzer
Post by Drilldoughzer » Wed Dec 18, 2019 6:30 pm
Congrats ben hex and Instruo!! This is nice little modulator!!
I hope that a DIY kit will appear one day!
bommelito
Post by bommelito » Wed Dec 18, 2019 6:57 pm
gonna get me one of these for sure!
versipellis
Post by versipellis » Wed Dec 18, 2019 7:21 pm
I do sorely wish this was clockable :(
tunes: https://www.soundcloud.com/dycedot
in boston? I run nights: https://www.facebook.com/4OTFEvents/
selling [Qu-bit Bloom; NE Cursus Iteritas]: viewtopic.php?f=74&t=229821
mrhooks
Post by mrhooks » Wed Dec 18, 2019 8:34 pm
versipellis wrote:I do sorely wish this was clockable :(
What would be the benefit of that, considering the 8 LFOs all run at different, non-sync'd tempi?
Scott M2
Post by Scott M2 » Wed Dec 18, 2019 9:00 pm
It seems like it will be a great companion for an Individual Wavebank Batumi to keep a patch animated. Also... Black!
kuuma
Post by kuuma » Wed Dec 18, 2019 9:36 pm
I was just shown the North Coast Synths Fixed Sine Bank a few days ago by a dude I bought an Instruo oscillator from, and he mentioned how much a gamechanger it was to have a box that was just organically ratio'd lfos out with no settings. I'd been thinking about it ever since and even got a kit in my cart – thankfully I didn't buy it because Instruo's new drop is cuter, smaller, and has just enough parameters to keep it extra functional but not too much.
I can't wait to get one when I upgrade cases.
