Frap Tools Brenso
vilovisp
Re: Frap Tools Brenso
Post by vilovisp » Tue Aug 25, 2020 1:23 pm
just for the record frap tools amazing customer service is helping !!!
nrg242
Post by nrg242 » Wed Aug 26, 2020 12:48 pm
was just about to say to get in touch with them as their customer service is on top of things.
ipnoteca
cane morto
Post by ipnoteca » Thu Aug 27, 2020 8:19 am
a quick question about ping and decay on brenso. as far as i understand from the manual is it possible to set manually the decay but there is no control over cv. am i right?
thank you!
i've blown a fuse...
previously robocoder
YOUTUBE http://www.youtube.com/user/ipnoteca
INSTAGRAM http://www.instagram.com/ipnoteca/
Hovercraft
Post by Hovercraft » Thu Aug 27, 2020 9:50 am
thank you!
That's correct--the decay adjustment doesn't have a separate cv input. In practice, the ping feature has been super useful, but if I want more control, I send an envelope into the vca/wavefolder, and control the envelope.
ipnoteca
cane morto
Post by ipnoteca » Thu Aug 27, 2020 8:31 pm
thank you!
cheers thank you for clarification! what i want to achieve is basically percusive bass and be able to control cv over decay, at the moment i am using the intellijel shapeshifter, but after hearing the sound of brenso i completely fall in love with it!
endwino
Post by endwino » Fri Aug 28, 2020 10:07 am
I'm trying to decide between this or replacing my CS-L which is having issues with one oscillator....so difficult.....CS-L sounds great but this looks so good. TZFM might sway me towards the brenso....I don't have any experience with it but I guess it helps with tuning?
closedLoop
Post by closedLoop » Fri Aug 28, 2020 12:23 pm
What issues is the CS-L having? Is it with the saw or triangle oscillator?
Asking because I'm also weighing the CS-L against the Brenso.
endwino
Post by endwino » Fri Aug 28, 2020 2:05 pm
The pitch of the triangle core osc is stuck. Jason with Instruo is very helpful and I know it will be dealt with, but the Brenso is tempting
edit: I miss the cs-l already so I’ll probably end up with both eventually..... :doh:
buzzbuzz
Post by buzzbuzz » Mon Aug 31, 2020 2:46 pm
Now that this is out in the wild I can't help but want a Frap LPG to pair with it
studioutopia
Post by studioutopia » Mon Aug 31, 2020 10:29 pm
YESSSSSSSSSSS!!!!!
nrg242
Post by nrg242 » Wed Sep 02, 2020 3:54 pm
did a little test of Brenso vs CSL for my own usage and figured i'd share a clip of the results. by no means am i an expert in matching all of the intricacies of these two modules, but i applied the same modulation to each with about the same attenuation and tried to get the levels of the ring mod and pwm to match somewhat (needing external mixing on CSL, whereas Brenso's final has everything). i think the most noticeable thing is how different the wavefolders sound and how much "cleaner" CSL is. looking at a frequency analyzer, brenso does put out a lot more content below 50Hz, but somehow CSL sounds like it has a bigger bottom end.
hope this helps. happy to hear feedback about how i could better match them if someone has some golden complex osc ears.
honestly, its a tough call getting rid of CSL (which is what i assumed i would do). not a fan of how the wavefolder drops out the volume on it and the overall clutter of the panel when modulating things, and how the trim pots feel very imprecise compared to brenso, but it just has this rounded woody tone thats very different from brenso.
embedding never works for me even after removing the "s".
edit: soundcloud won't play the audio file so you'll just have to take my word for it.
studioutopia
Post by studioutopia » Wed Sep 02, 2020 4:18 pm
http://soundcloud.com/naveen-g/brenso-v ... eFzmSh0KgH
Naveen - You nailed it... "Woody" is exactly how I'd describe Cš-L's secret sauce/unique sound. I had the exact same plan... and even though Brenso is definitely my favourite between the two... I will not be letting go of my Cš-L so easily.
Hovercraft
Post by Hovercraft » Wed Sep 02, 2020 4:45 pm
Here's a streaming performance where I primarily used Brenso/Jove and Cs-L/Belgrad---with some high tone accents from Mangrove/Three Sisters. Brenso and Cs-L sit perfectly in a mix together--enough of a timbral difference to be interesting, but not glaring.
twitch.tv/videos/726380295
Edit: *sigh*, this site is a mess as usual
smoo
Post by smoo » Sat Sep 26, 2020 11:28 pm
Try VCO 2-> VCO 1 Lin FM (no patching), Soft Sync and AM Mod 100% (not Ringmod). Tons of sweetspots! Thats my favorite setting for the Brenso to get nice colors in sequences. I had that at the beginning, then I forgot and now I found it again.
I never use too much folder on this one and usually prefer a bit more triangle shaping in that patch (final out).
drowld
Post by drowld » Tue Oct 06, 2020 4:20 am
Yes i also love that about the cs-l can easily get in woody territory
Also the soundcloud link isnt up anymore
WTB: Intellijel Quadrax, Klangbau Twin Peak Resonator, 1BIT Multitap Delay, five 12 vector, dplr
carlotter
Post by carlotter » Thu Oct 08, 2020 4:05 am
Do they make an LPG? Currently Brenso is pairing nicely with my Optomix
buzzbuzz
Post by buzzbuzz » Thu Oct 08, 2020 8:51 am
no, not yet. i'd realy love one from them though. I currently have it paired with a Jolinlab Agogo, working out quite well.
axm311
Post by axm311 » Sat Oct 17, 2020 8:22 am
FYI These are in stock at perfect circuit, just bought one. A lot of osc for a modular whippersnapper so wish me luck!
Kattefjaes
Post by Kattefjaes » Sat Oct 17, 2020 8:37 am
Yep, they are in stock at Juno, Thomann and various other places suddenly. Rejoice!
I am still navigating the various ways and paths of mine, but have been having fun. The manual is beautifully written and laid-out, but because the layout is more like an academic paper, I ended up actually printing it. For some reason, it's easier to follow as dead tree.
HenryBurlingame
Post by HenryBurlingame » Sat Oct 17, 2020 10:29 am
I would really love if someone could post some comparisons of this with the Cs-L (or just some more samples with the brenso). I have the Cs-L, but there are quite a few things I don't like about it... the sound is what keeps me hanging on to it though. I am thinking about getting the brenso instead, I love all my other frap tools modules so much, I have just not heard enough demos yet :).
