Gonna think about this inductor thing more.... copper and iron oxidation have different effects. We're these inductors tunable? Did they have ferro-resonant cores? Were they iron or ferrite core? Usually there was a ferro-magnetic slug you could use to change the inductance. Fwiw, 'mass' doesn't explain anything to me by itself.
In other news, looked closer at the pot mechanicals. Finally isolated what looks like the 'loose linkage' part of the pot's performance. Below are pictured the OEM pot on the left and the ALPHA on the right. Salient detail is the 'brass' colored tension collar for rotary resistance on the ALPHA to maintain rotary position, versus the color-less goop in the OEM pot. This explains the nudging*, and light touch on the OEM control - liquid viscosity only increase with motion (through the liquid - or goop in this case), small motions are frictionless, while gross motion is resisted, versus the more natural fixed resistance provided by the added cost of a mechanical component rather than squirt of goop.
Just noticed the press fit pin holes were on opposite corners. So much for swapping shafts :-) course, after this I wouldn't want that shaft anyway. Besides, I'm starting to think solid shaft is the best considering my next post on knobs.
I also, sectioned a 05A105 - the previous one pictured was the 05c503, where the splice is on
the other side. Nobody asked :-) anyway, yup, the splice on the 'Forward' log pot was in the opposite position as the 'reverse' log pot. So, we nailed that one.
