Well, that doesn't sound good at all. I mean, the Perfourmer is the older design (right?), so there's no reason to think it would respond any better. Not that I plan on audio rate triggering---on the contrary, I've so far used those up to 64 triggers at low bpm's to articulate rhythmic forms, not tones. But still. Maybe Perfourmer's expensive CV add-on is designed for a higher level performance? Considering its price, though, I don't think I want to buy a Perfourmer on spec.joeman wrote: ↑Sun Feb 14, 2021 10:19 pmwhen combining the DRM1 with Flux, the DRM1 will stop responding once the triggers reach a certain speed. The DRM1 can't handle very fast triggers, it will stop responding or only allow an occasional trigger through (like 1 in 50-100 at certain speeds).
It responds perfectly well up to a point
FLUX - Temporal Modulation Rhythm Sequencer
Re: FLUX - Temporal Modulation Rhythm Sequencer
I find that the inability for the DRM1 to respond to the very fast triggers is actually of no cause for concern at all. The DRM1 can be triggered fast enough for me and I'm sure most people. Every euro module also has its limits to trigger input speeds that it can handle. I think the Perfourmer (like pretty much anything at all) would be great to pair with Flux! Because Flux is just so amazing.
I would say, the amount of groove possibilities with Flux on its own without any other modules but sound making ones, is some orders of magnitude greater than any other sequencer with "16 steps", and this of course applies even before it starts playing too fast for xyz module's gate/trigger input to respond without dropping triggers. It is a truly magnificently vastly stupendously incredibly mind-bogglingly astounding groove box. I am off topic I know, I just wanted to sing the praises of Flux while I was here!
- Wiggling with Experience
Maybe manufacturers should start testing if their modules are Flux-approved.joeman wrote: ↑Mon Feb 15, 2021 5:17 amI find that the inability for the DRM1 to respond to the very fast triggers is actually of no cause for concern at all. The DRM1 can be triggered fast enough for me and I'm sure most people. Every euro module also has its limits to trigger input speeds that it can handle. I think the Perfourmer (like pretty much anything at all) would be great to pair with Flux!
One big problem with Perfourmer is that I can't find it in stock anywhere, except a place in Japan charging double the normal price.
A little ambient with only one single step!!!!!
Can someone recommend a video where the the basic functionality and philosophy is described?
We are the Borg. Resistance is equal to voltage divided by current.
https://soundcloud.com/logic_not
current 9U: https://www.modulargrid.net/e/racks/view/428567
Skiff: https://www.modulargrid.net/e/racks/view/818039
Recording: https://www.modulargrid.net/e/racks/view/1392937
Video: https://www.youtube.com/playlist?list=P ... PvexiFtvhI
thx
While I've thoroughly enjoyed FriendlyVoice's videos, I would respectfully disagree that basic functionality and/or philosophies are described. More that the patches and step parameters are set up beforehand and the videos simply show tweaking macro pots to achieve some cool results. I'd love to see a video walkthrough at some point where someone actually narrates and explains/translates Flux's concepts to demonstrate their effect on a pattern. Thankfully, the new version of the manual is a bit more in-depth and descriptive than it was for the first few months of its release, I feel I'm getting a little closer to wrapping my head around it.
There was one where they did a deep walkthrough of everything. There was also an official tutorial video but I think it got pulled to be redone.
Hi guys, there’s a playlist now for your convenience:
http://youtube.com/playlist?list=PLDxv3 ... I6uR_zQ9H2
- mdoudoroff
- Super Deluxe Wiggler
I think the core functionality and philosophy can be summarized thusly:
- Internal or external clocking.
- Four channels/tracks.
- 1-16 variable-length steps per channel/track (therefore better described as stages than steps); length of step/stage is related to the clock, it is NOT a fixed time duration like you see on Control Forge
- (what follows is functionality that exists pretty much nowhere else)
- Each stage can emit 1-64 triggers/gates (think ratcheting); by default these triggers/gates are perfectly equally distributed through the length of the stage.
- However, these triggers/gates do NOT have to be perfectly evenly distributed; they can be distributed non-linearly in endless parametric ways, including various built-in functions that result in discontinuities and sub-bursts.
[/quote]
[/quote]
While I agree with you that describing the functionality and philosophie of Flux is not an easy task, this was -as flawfull as it may be- a try: http://youtu.be/BNls3CX6B1g
Since the last firmware 1.05 practically makes Flux a brand new module, imho, maybe a new tutorial is needed too.
[/quote]
Ah cool I must have missed that one, I've seen most but admittedly not all. Thanks for the clarification.
I remember IO Labs' video utilizing the original prototype, I still hope for one featuring the released version.
Awesome, thanks!Sweetfiltersweep wrote: ↑Tue Feb 16, 2021 12:35 pmHi guys, there’s a playlist now for your convenience:
Cheers!mdoudoroff wrote: ↑Tue Feb 16, 2021 12:42 pmI think the core functionality and philosophy can be summarized thusly:
Agreed, the new update is awesome (even though I haven't had much time to sit down with it yet). I missed this video but will certainly dig in later today...thanks so much for making this!Sweetfiltersweep wrote: ↑Tue Feb 16, 2021 12:49 pmWhile I agree with you that describing the functionality and philosophie of Flux is not an easy task, this was -as flawfull as it may be- a try: http://youtu.be/BNls3CX6B1g
Explaining the basic functionality of Flux is tricky because it sits outside what we are most familiar with. I can feel your pain here. Flux seemed a bit more straighforward at the beginning of the Kickstarter, but it really has evolved into an incredible tool.kosmische wrote: ↑Tue Feb 16, 2021 12:22 pmWhile I've thoroughly enjoyed FriendlyVoice's videos, I would respectfully disagree that basic functionality and/or philosophies are described. More that the patches and step parameters are set up beforehand and the videos simply show tweaking macro pots to achieve some cool results. I'd love to see a video walkthrough at some point where someone actually narrates and explains/translates Flux's concepts to demonstrate their effect on a pattern. Thankfully, the new version of the manual is a bit more in-depth and descriptive than it was for the first few months of its release, I feel I'm getting a little closer to wrapping my head around it.
The way that the parameters can be modulated with CV or the pots opens up much deeper and, more importantly, expressive possibilities than I had assumed. I think that is why FriendlyVoices videos explore the control side so comprehensively. It is integral to the performance and expressive power of the sequencer.
You can make a varied and intricate patch with just one step.
[/quote]
[/quote]
The videos Flux 22 and MSS009 are made with one single step. It’s almost impossible to make people aware of what that really means, because before Flux (and with anything else which is not Flux) we don’t thought that one single step can make anything enjoyable.
In a traditional sequencer, the first step is maybe the first hit of the bass drum. Think of it: only just this one first hit! In Flux, one single step can be an evolving and never repeating composition.
That’s a real game changer.
[/quote]
[/quote]
[/quote]
Btw, it’s “Friendly Noise” (not Voice). :-)
[/quote]
I understand and totally agree with you, it's a unique approach...just one I have yet to crack because I haven't been able to spend as much time with it as I've wanted. I'm definitely looking forward to a deep dive over the next 2 weeks though.Marizu wrote: ↑Wed Feb 17, 2021 3:50 amExplaining the basic functionality of Flux is tricky because it sits outside what we are most familiar with. I can feel your pain here. Flux seemed a bit more straighforward at the beginning of the Kickstarter, but it really has evolved into an incredible tool.
I've posted some demos of Flux doing some straight ahead grooves. Check out just a few small excerpts of what you can do with only a single step:
https://soundcloud.com/joeman/iolabs-fl ... e-examples
https://soundcloud.com/joeman/iolabs-fl ... t-24-hours
To be clear though, when you say one single step, it's a little misleading. Each "step" can have a density up to 64, so at slower tempos, that's up to 64 steps inside each step. A "step," in this context, is basically up to a 64-long sequence. Depending on usage, it's more descriptive sometimes to call the 16 steps "stages". As you've pointed out, you can do a whole lot with just one stage, which is because a stage allows rather elaborate sequencing and temporal modulation without even using another step.Sweetfiltersweep wrote: ↑Wed Feb 17, 2021 4:14 amThe videos Flux 22 and MSS009 are made with one single step. It’s almost impossible to make people aware of what that really means, because before Flux (and with anything else which is not Flux) we don’t thought that one single step can make anything enjoyable.
Flux isn't wondrous for how much it can do with so little, but for how much it can do and how it can be flexibly organized and perform its modulations at different levels of its functioning.
Respectfully, I don't think it's misleading. You can use one step and leave it unedited (as in fresh boot init patch unedited) and then modulate params using any/all of the Macros, CV inputs, the Evolve matrix (and self patching of the CV OUTs to CV INs) to create universes of possibilities, which then can be vastly differently set up on subsequent steps should you want to use more than one step. This doesn't rely on using slower tempos at all either.blipson wrote: ↑Wed Feb 17, 2021 10:24 pmTo be clear though, when you say one single step, it's a little misleading. Each "step" can have a density up to 64, so at slower tempos, that's up to 64 steps inside each step. A "step," in this context, is basically up to a 64-long sequence. Depending on usage, it's more descriptive sometimes to call the 16 steps "stages". As you've pointed out, you can do a whole lot with just one stage, which is because a stage allows rather elaborate sequencing and temporal modulation without even using another step.
Yes, this method of sequencing with Flux then relies on modulation of params as you say, but still, it's not misleading to say that there's an insane amount of options for rhythms (or just pure modulation using Flux as a CV modulation source for other modules) from a single step.
As mentioned, the demos I've posted use one step per channel almost exclusively. All of the grooves and constant variations are therefore created using the mod matrix.
Once moving onto using multiple steps, let's not forget that there's also the possibility of taking advantage of the three mod busses which can be used in any desired combination on a per step basis.
[/quote]
[/quote]
Gentlemen, when people here says “step” or “stage”, I understand the same thing. The Moog 960, one of the first available sequencers (if not the first) is described in the manual as “eight step” sequencer. Same “step” with Flux in the web page. And when you clock Flux internal or externally, you are clocking steps, not triggers.
Also: we know ratcheting since forever (Tangerine Dream/Stratosfear 1976) but no one defines ratcheting as “having more steps”, but as “having more triggers within one single step”. So, as long as you know what you are doing, use the words you are familiar with. Otherwise we are going into an purely academic discussion...
The names don’t change the fact that you can make whole tracks with only one single (put your favourite word here) of Flux. And you have still 15 (same thing here) left. That’s game changing. :-)
[/quote]
Those are amazing.joeman wrote: ↑Wed Feb 17, 2021 9:21 pmI've posted some demos of Flux doing some straight ahead grooves. Check out just a few small excerpts of what you can do with only a single step:
Re: FLUX - Temporal Modulation Rhythm S7equencer
Sweetfiltersweep,
Just a quick note because I see u have difficulty quoting: the first of the '[Qu ote]' tags does not get a '/'.
The '/' slash is only for the second (final) tag that closes the quote.
Don't believe the hype.
WTB: Schippmann Omega-Phi Mk2.
