nonlinearcircuits NLC 2020 modules
bemushroomed
Re: nonlinearcircuits NLC 2020 modules
Post by bemushroomed » Sat Sep 12, 2020 12:07 pm
I have Squid Axon and 329 Phase / Flange for sale, both original white/gold panel if anyone's interested, can send WW free shipping..
both really cool modules btw, though none are essential for what i do right now.
JakoGreyshire
Post by JakoGreyshire » Sun Sep 13, 2020 2:24 am
Yimeyall.... Choral genermarator.....? eh?.....
Picture picture..... Please?
My YouTuBe Page...
The patch you've created in your brain is more challenging to modify than the patch you have on your modular.
JakoGreyshire
Post by JakoGreyshire » Wed Sep 16, 2020 8:51 pm
My YouTuBe Page...
forrest
Post by forrest » Thu Sep 17, 2020 11:10 am
Quick update on my hyperchaos deluxe, I went to build another one this morning and discovered, instead of a DG202/212 I had installed a DG411?? In its place, don't ask me how that happened :despair: hahah.. So I just replaced it with a DG202 and now I'm getting the response I was looking for, which is, fast when jack in rate, slow when nothing in rate.. Signals are very similar however.. So basically, if you want your hyperchaos to run fast, all the time without anything patched into rate and for it to act as sort of a chaotic burst generator with a positive gate, use a DG411! Anyhow I think I prefer it with the DG202 so I'm keeping it that way.
Peng33
Post by Peng33 » Thu Sep 17, 2020 3:09 pm
Hey! I think I just bought a Plague of Demons from you. Scoped out your seller page, and wow...a bunch of NLC. I might buy another one soon-ish, depending on if I have monies left after filling the necessary holes in my beginner-ish rack.
forrest
Post by forrest » Thu Sep 17, 2020 5:06 pm
Unfortunately I have to pay a large dentist bill so selling off a few modules I'm not using in my rack, the ones in the photo here however will likely not be leaving, my favorite NLC modules: Neuron, Dual LFO/VCO, Hypster, Hyperchaos, 8 bit cipher, arseq, 1/n, divine cmos, statues, shat-noir phaser, clump, sloth DK, VCAs (nice fuzz), and of course the triple sloth.. Other NLC modules I've made that i'll never get rid of (in another case): Beat freq & cellular automata..
scragz
Post by scragz » Thu Sep 24, 2020 9:40 pm
From Perth to Seattle in an unreasonably speedy 9 days, I just hooked up a shiny new (pre-assembled because I have no SMT chops) 1U Pills and a Splosh next to my Sloths.
Pills is UNRULY! The "everything affects everything" in the description is less an observation than a warning....or a threat. Even plugging an unpatched cable can drastically change the sounds. Really fun torturing the PLLs listening to them attempt to track each other. For generating audio it seems to need an offset patched into CV Range inputs or else it just farts along.
Fun stuff!
skinpop
Post by skinpop » Mon Oct 05, 2020 12:43 am
I'm new to DIY electronics and sourcing components so please forgive my ignorance. Most NLC build documents call for choosing suitable resistor values for LED brightness. Is is safe to always assume a source voltage of 12v(or is it something different?) or do I need to use the schematics to calculate voltage drops?
Also can Kobiconn style jacks be swapped out for Thonkiconn Jacks or is the pcb connection different?
andrewF
Post by andrewF » Mon Oct 05, 2020 7:57 am
Yes, assume 10-12V for the LEDs......unless it is driven by a CV.
Just test your LEDs with 12V and select a resistor to give it a brightness level you like. These days I always use diffused LEDs and tend to use 4k7 for red and 10k for green, pink or blue. Clear lens LEDs are often quite sharp to look at and may need a much higher value resistor to make them dim enough to be comfortable.
Also, yes Thonkiconns are fine for any NLC modules.
When many of the build guides were written (and PCBs designed), Thonkiconns were not easily available.
skinpop
Post by skinpop » Mon Oct 05, 2020 10:14 am
Thanks! Can't wait to build the modules.
Zijnzijn Zijnzijn!
Post by Zijnzijn Zijnzijn! » Tue Oct 06, 2020 3:11 pm
Are there any NLC modules that focus on brownian/drunk CV movements? Like the two drunks parasites mode in tides, or the drunk object in max?
andrewF
Post by andrewF » Tue Oct 06, 2020 8:01 pm
No, I am working on a module that simulates muscular movement/spasms in the tummy before and during a poo tho.
:sstorm:
Zijnzijn Zijnzijn!
Post by Zijnzijn Zijnzijn! » Tue Oct 06, 2020 8:02 pm
:sstorm:
i mean, that does sounds fun
gnome666
Post by gnome666 » Tue Oct 06, 2020 8:18 pm
:sstorm:
oh hell yes. eurorack needs more intestinal based cv sources.
Thorsday
Post by Thorsday » Tue Oct 06, 2020 8:27 pm
:sstorm:
Awesome!
Do a vagina fart next!
Phitar
Post by Phitar » Tue Oct 06, 2020 8:57 pm
:sstorm:
What the hell you gonna call that? BM/#2?
:hyper:
Never bring a spork to a gunfight. - Guns Akimbo
bawbag
Post by bawbag » Wed Oct 07, 2020 12:27 am
Dunno but I want a chaos module called Mr Hoppy.
jabberbased
Post by jabberbased » Sun Oct 18, 2020 1:45 am
:sstorm:
Will this use your classic black-box design?
Or do you have a newer "brown box" in the works? ;)
Wysiwygler
EASYBOY
Post by EASYBOY » Mon Oct 19, 2020 2:43 am
Is there a difference between the NLC Neuron and the modduladdict Version except that it is "doubled"?
deftinwulf
Post by deftinwulf » Fri Oct 23, 2020 9:55 pm
:sstorm:
Please call it the Poop Tube.
hinterlands303
Post by hinterlands303 » Fri Oct 23, 2020 10:04 pm
andrewF wrote:
Fri Oct 23, 2020 7:48 pm
Helvetica Scenario
Wow this is great! I have the Sauce of Unce which I quite like but this seems like double the fun.
jabberbased
Post by jabberbased » Sat Oct 24, 2020 4:19 am
Helvetica Scenario
What is the module to the left of the 32:1?
Wysiwygler
andrewF
Post by andrewF » Sat Oct 24, 2020 7:42 am
Helvetica Scenario
Doof! - drum module
Phitar
Post by Phitar » Sat Oct 24, 2020 8:46 am
Helvetica Scenario
Love it! Right up my alley. 2 channel even. Sold!
