Difference between outputs on the Make Noise Maths?
tyebillion
Post by tyebillion » Fri Feb 14, 2020 11:21 am
Hi,
On the Make Noise Maths what's the difference between the function outputs (labelled with curves) and the outputs labelled "1" and "4"?
:confused:
Arneb
Re: Difference between outputs on the Make Noise Maths?
Post by Arneb » Fri Feb 14, 2020 11:24 am
The unity outputs (the ones with the integral signs) aren't affected by the attenuators (the middle column knobs).
Edit: Also, patching the numbered outputs takes them out of the OR/SUM/INV mixing stage at the end; patching the unity outputs doesn't.
scragz
Post by scragz » Fri Feb 14, 2020 11:34 am
Maths has a really good manual that explains everything and has lots of smart patching examples. Not to be all RTFM at you but also that.
tyebillion
Post by tyebillion » Fri Feb 14, 2020 12:29 pm
Thanks Arneb and scragz, noted.
