Clocked delay for pitch CV and gate
versipellis
Post by versipellis » Thu Mar 19, 2020 4:00 am
Are there modules that can take a pitch CV and gate and delay them by a certain number of clock trigs? Modules I've seen do one or the other, but not both. I could hack something together with stock o_C running CopierMaschine for pitch CV, and another o_C with Hemispheres running ShiftGate, but coordinating the modulation for both of these such that I can change the delay length is something of a small nightmare.
tunes: https://www.soundcloud.com/dycedot
in boston? I run nights: https://www.facebook.com/4OTFEvents/
selling [Qu-bit Bloom; NE Cursus Iteritas]: viewtopic.php?f=74&t=229821
Paranormal Patroler
Re: Clocked delay for pitch CV and gate
Post by Paranormal Patroler » Thu Mar 19, 2020 4:30 am
Hm, I haven't run across a module that is dedicated to doing both but that being said, any module with multiple inputs/outputs that can delay CV can also delay Gates, no?
I'm thinking maybe Stages could work ... but then again, it's not clocked. I'm guessing your best bet would be 2 x module. Synthesis technology's E102 readily comes to mind.
versipellis
Post by versipellis » Thu Mar 19, 2020 5:53 am
Shift registers are pretty much got me on this train.
I did look at the E102. It seems a little like a bit of a waste to get two of them just to shift one set of CV-gate - I was hoping for something with the with a common delay value shared between two inputs and two outputs. Two E102's means three duplicated CVs and gates that are otherwise wasted.. And at a cost at which is more economical to write it on a Monome Teletype :P
Navs
Post by Navs » Thu Mar 19, 2020 11:23 am
As it's stepped CVs and gates, you could patch this with a sample & hold and a switch (or two). Grab the CV you want, then when you want to 'release' it, flick the switch. Is that what you're after?
Buttons ARE toys
Post by Buttons ARE toys » Thu Mar 19, 2020 2:29 pm
I don't know about doing it with a single module, but you could do this with a combination of something like MI Frames and either a Mungo D0 or MI Stages. Both of the former can be CV delays, and you could manually tune a few frames to lock onto various clock divisions.
Astronomical Dusk - a web radio show of synthetic delights and collected oddities. Airs monthly at astronomical dusk.
versipellis
Post by versipellis » Fri Mar 20, 2020 7:55 pm
Not really, I need to grab something like 2 bars of CV :)
Navs
Post by Navs » Sat Mar 21, 2020 4:03 am
If it's bars of information, can I assume it's coming from a DAW or similar? If so, would duplicating and delaying the track in the DAW and then sending it out on a separate channel work?
versipellis
Post by versipellis » Sat Mar 21, 2020 4:09 pm
Nope, not coming from a DAW - sequencing from either my Launchpad Pro mk3 or Monome Grid + Ansible running Kria. The use of this would be in a live set too, for improvisation.
mkasthe
Post by mkasthe » Sun Mar 22, 2020 1:15 pm
Have you looked into the Bishop's Miscellany from Shakmat Modular?
https://www.shakmatmodular.com/products/bm.html
Some of the features from the website:
• Dual Stepped CV / Gate Recorder
• Variable length sequences (up to 32 steps)
• Shift parameter scanning different segments in your original sequence.
• AB switch allowing to record two different 32 steps sequences.
• CV inputs for Length and Shift functions
• Gate inputs for all the switch functions (Record, AB, Cut and Random)
Made in Italy and exported to NYC
