Varigate 4+ Reset Advice Please
CapabilityBrown
Post by CapabilityBrown » Thu Mar 26, 2020 10:03 am
I have midi going out of my Model:Samples in to Erica Synths Midi-Clock which is sending clock to my Varigate 4+ I'm trying to workout how to send a reset signal to the Varigate reset input so it restarts on the stop. I'm not sure whether I need a dedicated reset output to facilitate this? System link below, any help much appreciated.
https://www.modulargrid.net/e/racks/view/1154951
CapabilityBrown
Re: Varigate 4+ Reset Advice Please
Post by CapabilityBrown » Thu Mar 26, 2020 11:09 am
Having looked in to this further, I’m assuming I need a gate signal to send to the reset input every time I hit play/ stop? Buying a new clock module seems like overkill this being the case. Would a module with manual gate trigger do the job, in which case any recommendations?
bc3
Post by bc3 » Thu Mar 26, 2020 11:24 am
IMO if you are going to be using MIDI clock to drive your modular system you really should consider investing in a dedicated MIDI to CV module.
I would recommend the Intellijel uMidi as I have been using them for a few years and they work flawlessly.
CapabilityBrown
Post by CapabilityBrown » Thu Mar 26, 2020 11:41 am
Everything does seem to be pointing to the uMidi. It’s a shame because the Erica midi-clock does everything I need it to other than send a reset signal. I have the clock out going in to a mult then split to a Disting which I’m using to send quantized CV to Wavetable VCO and the Varigate which is sequencing the BIA. Wouldn’t mind manually resetting with a gate but I’m lacking that capability by the looks of it.
