Expert Sleepers disting EX
Re: Expert Sleepers disting EX
Post by os » Thu Jul 02, 2020 8:12 am
Here's a thread on the Lines forum about the new i2c features and Teletype integration:
https://llllllll.co/t/teletype-disting- ... tion/33929
ehr
Post by ehr » Thu Jul 02, 2020 9:06 am
sweet! thank you for the improvements and great firmware additions!
rupa
Post by rupa » Thu Jul 02, 2020 9:34 am
oh my gosh that's a fantastic looper. thanks os!
virtualpt
Post by virtualpt » Thu Jul 02, 2020 3:41 pm
Thanks Os, superb update!
Phitar
Post by Phitar » Thu Jul 02, 2020 4:23 pm
All I can say is... Holy Shit!
:hail: :hail: :goo: :hail: :hail:
Oh.... and Thank you!!
Never bring a spork to a gunfight. - Guns Akimbo
mcpepe
Post by mcpepe » Fri Jul 03, 2020 10:04 am
First contact with the Disting EX.
apestate
Post by apestate » Fri Jul 03, 2020 10:56 am
When I try to use two wav playback in dual mode, one of the two bugs out and the second plays back the sample of the first
Also, just had an issue in dual mode where the left algorithm bugged out and outputs digital noise regardless of input
Anyone else experience this issue?
silkynight
Post by silkynight » Fri Jul 03, 2020 6:30 pm
which firmware are you on? 1.3 was released yesterday, perhaps that will fix the issue.
Peng33
Post by Peng33 » Sat Jul 04, 2020 6:07 am
os wrote:
Mon Jun 15, 2020 2:47 am
@Peng33 Right now that algorithm is fixed to send CC #1, but it would be trivial to expand that to make it settable.
You can set a different MIDI channel for the two 'sides'.
I've long meant to make an option to send CC from X & Y as well as Z, which would give you 6 CCs.
Thank you for including the selectable CCs. That will be helpful.
Watched a few of your YouTube videos, and it just boggled my mind how many functions/features/parameters were able to be changed on a single algorithm, let alone all of them. As I am still learning some modular basics and route effectively, my Disting EX is going to get a lot of use, but as intuitive as it is, it'll take me a bit to wrap my head around.
glennfin
Post by glennfin » Sat Jul 04, 2020 6:45 am
Doesn't seem to be available anywhere.... would like to get my hands on one.
fjoesz
Post by fjoesz » Sat Jul 04, 2020 6:54 am
is there a place where you can get more multi sample libs like the ones that are already in?
notinachos
Post by notinachos » Sat Jul 04, 2020 2:32 pm
Unless I'm missing something, it does not seem possible to trigger the `SD 6 Triggers` algorithm with incoming MIDI notes? I would love this as a feature request!
For context: The 8x trigger outputs from my Beat Step Pro are unfortunately too hot to trigger Disting EX directly, and it causes the Disting inputs to glitch out. Instead of using 8x attenuators on my triggers, my workaround was to try triggering this algo with MIDI instead but this does not seem to work. I end up using the `SD Multisample` algo, which does respond to MIDI note input.
notinachos
Post by notinachos » Sat Jul 04, 2020 4:59 pm
Aha! It seems the SD 6 Trigger algo was just updated in new firmware 1.3
From the change log: "The SD 6 Triggers algorithm can now be triggered by MIDI notes."
This is great!
ehr
Post by ehr » Sat Jul 04, 2020 5:07 pm
Get that 1.3! Multi-Sample SD algorithm works great now with this update.
Zijnzijn Zijnzijn!
Post by Zijnzijn Zijnzijn! » Sat Jul 04, 2020 5:27 pm
Has production on these started back up again? Obviously being understanding as can be considering the world being shut down, just endlessly hyped to get my hands on one
glennfin
Post by glennfin » Sun Jul 05, 2020 6:50 am
+1
Phitar
Post by Phitar » Sun Jul 05, 2020 12:24 pm
The trigger inputs all have attenuverter parameters. Have you tried that yet?
SJ900
Post by SJ900 » Mon Jul 06, 2020 5:39 am
+1
+1 from me too
Peng33
Post by Peng33 » Mon Jul 06, 2020 2:00 pm
+1
+1 from me too
My starter Eurorack. Lucked out on a Disting EX.
casciato
Post by casciato » Mon Jul 06, 2020 3:54 pm
+1
+1 from me too
How you liking the Panharmonium?
Look at pictures of my synths and tape recorders and hear the sounds at my Instagram
Dreth
Post by Dreth » Mon Jul 06, 2020 4:35 pm
I just got my disting ex, was curious if the output volume was really low for you guys?
Using single mode, SD/multisample, going straight into my mixer, the output is at least 50% lower than my other sound producing modules, and that's with the disting's gain set at max, +6db.
Everything else seems fine with it outside of this volume issue.
Is this normal behaviour or is something wrong with mine?
scttcmpbll
Post by scttcmpbll » Mon Jul 06, 2020 7:48 pm
Really enjoying the new Looper algorithm. 8 bit mode provides some nice grittiness and is satisfying my urge to buy a Cocoquantus.
casciato
Post by casciato » Mon Jul 06, 2020 7:51 pm
How's the volume with, say, six notes sounding?
adg672
Post by adg672 » Tue Jul 07, 2020 1:25 am
Brilliant new update. Love the Looper, few qs:
Can you pitch the loops (up/down octave, semitones)?
Can the loops all run at different lengths and unsynced to each other?
Do reverse and other modifiers (envs etc) act per loop rather than globally?
Any chance of a basic HPF? Would be really useful to clean loops up.
Can you edit loop start/end points?
(Comment moved from wrong thread)
Dreth
Post by Dreth » Tue Jul 07, 2020 1:47 pm
I don't own the midi expander, so I'm limited to 3 with cv/gate right?
3 gates in with chords on is a little louder I guess, but every sample is low volume in this algorithm, drum samples, piano, etc..
Playing the samples directly off the SD card on my pc they are all at good levels, but off the disting they are very quiet. Almost as if they aren't being brought up fully to modular levels.
I've been using the boost switch on my intellijel quad vca and the 6db gain just to get it at decent volume for example.
The other algorithms aren't as quiet, so maybe it's a velocity issue and I need that midi expander. *shrugs
