Expert Sleepers disting EX
Re: Expert Sleepers disting EX
Post by os » Mon Nov 16, 2020 4:27 am
OK. Under the disting EX's calibration menu is 'view input voltages'. What does that show?
Audiodaan
Post by Audiodaan » Mon Nov 16, 2020 4:38 am
Thank you, you put me on the right track. The problem was with my VCA & the way I was measuring on the scope. I was only looking at the output of the velocity track but not at the output of how the gate was affected by this velocity - turns out I was losing 1V, so I wasn't sending 2V at all...
Using a different VCA with manual gain control I was able to get it it back to where it should be. Thanks and apologies!
Post by os » Wed Nov 18, 2020 6:47 am
Just sharing this:
Umcorps
Will patch for food
Post by Umcorps » Sat Nov 21, 2020 3:24 am
I’ve been giving the Augustus Loop algorithm some attention. Set up for some classic time lag accumulation in a fully generative ambient style. Also using two Mk 4s for tremolo and subtle timbral change.
Probably better on headphones to hear the spacial results of the interplay between the L/R delay line feeds.
The lead is from Plaits in dual op FM mode. Marbles drives.
sylvainmoreau
Post by sylvainmoreau » Tue Nov 24, 2020 7:42 am
Hi,
About the SC compressor (E5).
I use it with traditional kick input side chaining my mix. (i guess most people do ?)
problem is like to be able to have my kick post compression in my mixes. The way i do that is send my mix without kick to distingEX, split my kick to trig the sidechain and other side to mix it laster. It requires a second mix stage.
Wouldn't it be possible to have a "blend trig post" (0-100%) to directly get the dry kick mixed with the compressed result ?
would be very handy.
Post by os » Tue Nov 24, 2020 7:53 am
It's not possible on the mk4, since the Z input is not an audio input on that hardware.
Would be possible on the EX though.
sylvainmoreau
Post by sylvainmoreau » Tue Nov 24, 2020 9:06 am
yes i was talking about the EX :)
please do that 8D
aragorn23
Post by aragorn23 » Wed Nov 25, 2020 12:21 pm
Hey all, two SD card questions:
1) What make of SD card is currently recommended? I've got one of the old janky cards and I'm getting a lot of glitching in multisample mode. Would a Sandisk Extreme Pro (U3) 64gb be overkill? (https://www.incredible.co.za/sandisk-ex ... sd-adapter)
2) Are the card contents available online somewhere so I don't have to copy them off of the current card?
Post by os » Wed Nov 25, 2020 1:38 pm
The EX is currently shipping with Kingston Canvas Select Plus 32GB cards.
mntbighker
Post by mntbighker » Wed Nov 25, 2020 2:11 pm
I was also wondering if the card image is available somewhere. Or if I should be making a copy in case it dies.
neopl
Post by neopl » Wed Nov 25, 2020 7:12 pm
Hello,
Maybe someone can tell me if I'm doing something daft, but I'm having trouble working the M-6 Stereo delay algorithm. No matter what I do, I can only get output A to output any signal, regardless of the 'Output' setting 0 = A & B are mix, and A & B are delay only. Only the output A outputs sounds.
I am sending Aux send from my Mackie mixer to the X input and as M-6 is a stereo delay algorithm, I am expecting stereo singnal coming out of A&B outputs, but this is not the case, I get the delayed signal only coming out of output A, which means that after it is Returned back to my mixer, I only hear the delayed sound in one speaker, despite having return cable in output B as well. Any ideas anyone? I was really looking forward to using this as a stereo module. I'm hoping this is just a user error on my part!
scragz
Post by scragz » Wed Nov 25, 2020 7:46 pm
X -> A and Y -> B. It's not a ping pong, they are separate signals.
aragorn23
Post by aragorn23 » Thu Nov 26, 2020 12:55 am
Thanks os, I'll give that card a try. A reformat of my current card does seem to have helped a bit in the interim.
neopl
Post by neopl » Thu Nov 26, 2020 5:55 am
Thank you for clarification on this. This is a bummer, as having only mono signal coming in it seems like this effect is is not very useful to me. I'll have to stick to ping pong, and this evening I'll have a look at other stereo effects, hoping that some of the others accept mono inputs.
Still I'm barely scratching the surface with this module, but over all it has been super ace. Recently I've been having a ton of great fun with the chaos algo producing extremely slow modulations. Am I correct in thinking that the chaos alog is something like the Triple Sloth module?
dziga
Post by dziga » Thu Nov 26, 2020 2:52 pm
#deleted
nevermind, i was dumb :D
Well, just so I don't leave an empty message: for me a Lexar 16GB card works pretty well in terms of non freezing when using multi sample playback.Will write the exact model once it copied the content back;)
Edit: It is a Lexar 633x card:)
MossGarden
Post by MossGarden » Sun Nov 29, 2020 1:21 pm
A Sunday spent very much enjoying the Disting EX Multisampler
shareddrive
Post by shareddrive » Tue Dec 01, 2020 6:22 pm
is there an ETA on the next batch of this module for the US? I pre-ordered one back in May from Perfect Circuit. Just curious, I know its been a tough year for everyone. Cheers
@MossGarden - very nice patch you shared above.
mntbighker
Post by mntbighker » Tue Dec 01, 2020 8:36 pm
I just got one from Detroit Modular, and an ES-9. I never got any notice from Perfect Circuit or Patchwerks that any had arrived.
casciato
Post by casciato » Tue Dec 01, 2020 11:12 pm
Yeah, cancel that preorder and get one from someplace else. I canceled my day one preorder in July when a local dealer had one in stock. I've seen them in stock at several places several times since then (albeit never for more than a day or two). I don't know what exactly the deal is with PC and those preorders, but I know that you have a much better chance getting one almost anywhere else.
Hear my music at my Bandcamp site: E T H E R D I V E R
Look at pictures of my synths and tape recorders and hear the sounds at my Instagram
mntbighker
Post by mntbighker » Wed Dec 02, 2020 1:22 am
Agree :bang:
DCDanno
Post by DCDanno » Wed Dec 02, 2020 9:21 am
Ordered from Perfect Circuit on May 30 and received it Sunday, Nov 30. (For some reason FedEx delivered on Sunday!) I sent them nag emails about twice per month. Squeaky wheel and all that.
Squallaz
Post by Squallaz » Wed Dec 02, 2020 10:25 am
Also in EU the module seems to be sold out pretty much everywhere. I am trying to buy one but with no luck :(
escargot
Post by escargot » Thu Dec 03, 2020 5:15 am
Signal sounds had them a few days ago. Best shop with lightning fast shipping
Squallaz
Post by Squallaz » Thu Dec 03, 2020 9:12 am
I love the shop and i have jsut bought an Acid Rain chainsaw from them but the taxes for buying from italy are a bit high :(
vraufen
Post by vraufen » Thu Dec 03, 2020 11:28 am
