Expert Sleepers disting EX
- bemushroomed
- Super Deluxe Wiggler
Re: Expert Sleepers disting EX
Great, thanks!os wrote: ↑Tue Dec 15, 2020 9:37 amProbably not today but any day now.bemushroomed wrote: ↑Tue Dec 15, 2020 9:35 amSold off the Disting mk4.. Disting EX here we go, anyone know it's available anywhere in the EU?
https://wigglehunt.com/?query=disting+e ... sort=price
Giving it a spin, pretty unbelievable how good this filter sounds! I did notice a freeze up on the Poly alog however. Fast-browsing through the wavetables with the R knob froze the module on ''Reticulating splines''.
edit: I kept playing with it and it hasn't happened since, so perhaps a one off bleep.
Still playing with new Dual VCO algorithm. Quick demo patch:
Patch notes:
Chord output from Sinfonion into Disting EX. Disting setup for Dual VCO in both slots. Slow heavily attenuated LFO into Disting Z input (moving through wavetable). All four Disting outputs routed into single XaVCF filter and then through Mimeophon. No other processing of any kind.
Patch starts as above, then towards the end I turn Mimeophon mix from pretty wet to mostly dry, and then open XaVCF almost fully up with resonance turned down - what you hear from then on is just the sound of moving through Disting's wavetable. I also then isolate the 2 higher pitches of the chord (all 4 were going through Performance Mixer), and then isolate lower 2 pitches.
This was a pretty straightforward table, with mild modulation - but with the other wavetables that come with it very easy to get 8-bit-like chiptunes going, wavy electro bass, convincing flutes, etc.
Okay, now on to explore the even newer Polyalgorithm - hard to keep up with Os!
Patch notes:
- bemushroomed
Did someone else see the insta post, that he's now made it compatible with Serum wavetables? That's pretty sick
- Zijnzijn Zijnzijn!
- Common Wiggler
Finally got around to updating, new polysynth is killer, but I'm still running into issues on the multisample I was running into on the og firmware, namely a lot of weird artifacting seemingly randomly, but mostly when more than a few notes are sustained at the same time. Stuttering and popping mostly. The built in sample of the xylophone/hand drum has this happen basically anytime more than two notes are played, but it also happens often in the piano bank. Is this a known/common thing?
I had the same problem. a new, faster SD card solved my problem :-)
Do you know how to put those on the disting? I think he must have converted the serum files to be compatible or somethingbemushroomed wrote: ↑Wed Dec 16, 2020 3:58 pmDid someone else see the insta post, that he's now made it compatible with Serum wavetables? That's pretty sick![]()
edit: from twitter" Turns out it was simple to get the disting EX loading Serum wavetables natively. Expect an update with that in shortly."
- Common Wiggler
Zijnzijn Zijnzijn! wrote: ↑Thu Dec 17, 2020 8:30 amMakes sense! Any recommendations for good brands that work well for this?
i have same problem , migrated from a dist mk4 to a ex and im super happy , but i need a better sd card looks like what everybody got?
I transferred the disting ex card contents to a Samsung EVO Plus 64GB micro SD card, and everything has been working great today (want to thank ES for the firmware update and the module, I'm really loving this) The user manual said the Samsung EVO's can utilise faster speeds than other cards:vilovisp wrote: ↑Thu Dec 17, 2020 8:59 amZijnzijn Zijnzijn! wrote: ↑Thu Dec 17, 2020 8:30 amMakes sense! Any recommendations for good brands that work well for this?
"It can however use High Speed mode
where available to double the throughput. Unfortunately whether a given card supports High Speed
mode over SPI seems to be hard to gauge from the specs – we've tested a number of cards rated at
UHS-I and above, some of which support High Speed mode and some of which don't. For the
record, the Samsung EVO range do; the Sandisk Extreme range does not. A card which does not
support High Speed mode will read around 1.8 MB/s on the disting EX's 'Test SD speed'."
Hi Bindi, any idea of the transfer speed you are achieving on the Samsung Evo Plus? Just to be able to compare with the 1.8 MB/s quoted above.
Thanks.
Waiting on my Disting EX's (2) and now looking to get the best cards in eager anticipation!
Thanks.
Just loaded up some serum wavetables... I think I need 2 more disting EXs..
Where to start with Serum wavetables? I would like to have some vocal-sounding wavetables, but browsing thousands of wavetables is not an option. Does a searchable database exist? (I do not have Serum, so I am just talking about freely distributed stuff.)
Just google free serum wavetables in whatever category you like. Id advise once you load them up to take note of those you dont like and remove them
later
Hi Os! While setting up my Faderfox EC4 to control the PolyWavetable algo, I have not been able to set up the six attenuverters (CC 1-6). Should I not be able to control the attenuverters via midi?
Also: An observation about delay time in PolyWavetable: As it goes up to 10 seconds (!), the shorter delay times have a rather crude resolution when controlled via midi, due to the 128 cc steps. So getting close to a musical delay time such as 1/8th notes and such, is often not really doable. Perhaps we could have a setting to select between, say, 2 seconds max and 10 seconds max?
Oh, and the surplus of Gain control is awesome. Like actually having an overdrive unit built in as well, since you have made it clip in a nice way.
No problem, just did the test for you under Misc-> tests. Says max speed of 3 MB/sec and average of 2.99 MB/ sec. Hope that helps!
Hi bindi - thanks for that, very helpful
Yes, but note that the mappings default to Disabled.
+1LDT wrote: ↑Sat Dec 19, 2020 2:34 pmAlso: An observation about delay time in PolyWavetable: As it goes up to 10 seconds (!), the shorter delay times have a rather crude resolution when controlled via midi, due to the 128 cc steps. So getting close to a musical delay time such as 1/8th notes and such, is often not really doable. Perhaps we could have a setting to select between, say, 2 seconds max and 10 seconds max?
Having a built in delay in the PolyWavetable is really great. But getting close to a musical delay with 1/8 notes is difficult. Can something be done?
This PolyWavatable algorithm for the DistingEX is worth the money alone. I am really thinking in buying a second DistingEX.
Ideas:
- tap tempo
- clock input
- sync to MIDI clock
- tap tempo
- clock input
Tap tempo and Sync to MIDI clock should be the best, as you don't have to waste another CV input, I think
Just dropped v1.6.1. Merry Christmas!
