Expert Sleepers disting EX
Daisuk
Re: Expert Sleepers disting EX
Post by Daisuk » Fri Mar 19, 2021 7:31 am
LDT wrote:
Fri Mar 19, 2021 5:46 am
Regarding the new Granulator mode, I found that it can...
Hahaha, whaaaaaaat. Brilliant. :yay:
Glydez
Post by Glydez » Fri Mar 19, 2021 7:45 am
There goes my next few months trying to replicate :hihi:
tvparcable
Post by tvparcable » Fri Mar 19, 2021 8:48 am
If this doesn't deserve a remix context, nothing does.
LDT
The Modu-Lars
Post by LDT » Fri Mar 19, 2021 10:17 am
Pointers: Shape = Equal power, Spawn mode = Mid-grain. Set buffer size very low, turn size up (it will not matter then), rate rather fast, no randomization anywhere. For doing something like in the video, sing only one pitch all the way.
If you turn up main feedback, one can make some very evil monsters speak. :mrgreen:
Glydez
Post by Glydez » Fri Mar 19, 2021 11:19 am
Never have I been more grateful for a tutorial. Now I may have time to focus on other life things :guinness: :hyper:
maudibe
Post by maudibe » Fri Mar 19, 2021 5:12 pm
Whoa!
Phitar
Post by Phitar » Sat Mar 20, 2021 7:41 am
@LDT - Awesome
@Os - Had some real fun with the Granulator last night. Great job! Was able to get good results from just having watched your first video once. Have been modifying parameters right on the module so far. Where can I find that editor for use with a PC?
In adddition to "More Cowbell!" everything should have more REVERB! :tu:
gearhead61
Post by gearhead61 » Sat Mar 20, 2021 8:59 pm
Is the Disting Ex actually available for purchase anywhere in the US or Canada right now, or scheduled to be available in the near future?
So much gear, so little time...
recliq
Post by recliq » Sun Mar 21, 2021 3:41 am
@LDT - Awesome
https://github.com/expertsleepersltd/distingEX_tools
https://expert-sleepers.co.uk/webapps/d ... ditor.html
Phitar
Post by Phitar » Sun Mar 21, 2021 3:58 am
@LDT - Awesome
Thanks! Really appreciate it! :yay:
TechForze
Post by TechForze » Sun Mar 21, 2021 2:50 pm
Just a quick check: It is not possible to record/pause/play in the Looper mode with a trigger?
Edit: I can map a clock to one of the inputs, but not record?
Edit2: It's possible with MIDI, but apparently it's not possible with CV. Time to buy the MIDI breakout then..
Current racks / trade: ModularGrid
Post by os » Mon Mar 22, 2021 3:24 am
Record is parameter 56, which you can map to a CV.
TechForze
Post by TechForze » Mon Mar 22, 2021 7:58 am
Ah, just found out how to map. Thanks!
Daisuk
Post by Daisuk » Mon Mar 22, 2021 3:24 pm
I got my Disting EX today, installed the latest firmware on it - but in multi-sample mode it's just ... it'll work for a few seconds, then just glitch out, audio drops out and distorts. Tried in two different cases. Is the SD-card to blame? Using the one that came with the module (Samsung 32 gig).
ehr
Post by ehr » Mon Mar 22, 2021 3:40 pm
@daisuk Are you using midi or CV? If you are using CV increasing the gate offset has been suggested (parameter 49). Also if you are playing big chords maybe raise the Normalisation setting to 8 (parameter 52).
Daisuk
Post by Daisuk » Mon Mar 22, 2021 4:11 pm
Hey! Thanks for the suggestion. :) I just copied the contents of the sd card over to a Sandisk Extreme SD card, and it's working fine now. :)
Blond 12
Post by Blond 12 » Mon Mar 22, 2021 6:26 pm
Hello Daisuk,
Its exactly what i reported the page before but no answer yet. I had no issue before on any previous firmware and with this one, the multisample mode is sadly unusable 🤷🏻‍♂️
Daisuk
Post by Daisuk » Tue Mar 23, 2021 8:16 am
This app is great for extracting wav files from Soundfont-files on Windows:
http://audio.clockbeat.com/sfZed.html
Just do the following after installing:
- Import Soundfont
- Save as SFZ
- You'll then be asked "save samples?" - click yes, and all the samples are saved in the folder you choose
Easy peasy. :)
Also, leaving a few useful Soundfont-resources in here, for future reference.
https://logicalsoundz.selz.com/nb
https://trisamples.com/free-soundfonts/
https://sites.google.com/site/fluidvolt/
vilovisp
Post by vilovisp » Tue Mar 23, 2021 11:00 am
hi i been experiencing some problems with my disting ex i love it but when in playback mode glitches , the unit freezes and it crackles.
ocationally is fine also , my sd card is a kingston canvas that came with the module , which one are you using that is perfect?
thx a lot
JP_King
Post by JP_King » Tue Mar 23, 2021 4:26 pm
I'm trying to figure out a user-friendly workflow for loading Spitfire Audio samples (and other samples) onto my Disting's SD Card for SD Multisample Playback. I've watched the ES video here for converting .sf2 files. However, Spitfire Labs has their own proprietary format:
FYI: instead of running this script (which I found challenging), you can use the Polyphone application (free download) to run a conversion from .sf2 to .WAV: https://www.polyphone-soundfonts.com/do ... l-versions
I feel like I have looked all over the internet for some kind of forum discussion of this topic or basically a "Dummies Guide to Getting Spitfire Samples into the Disting EX", but alas, no luck. Or maybe, only purchased Spitfire samples can be had as WAV files?
Can someone walk me through it like I'm five years old? Like, from the point where I've downloaded a Spitfire Labs file to the point where I have a folder full of WAV files?
Thanks so much!!!
Daisuk
Post by Daisuk » Tue Mar 23, 2021 5:14 pm
What kind of file format are they? I think I've seen Spitfire samples in .nki format, which means you can play them with Native Instrument's Kontakt. In that case, if you have Kontakt, you can sample the various instruments using the auto-sample feature of Disting Ex. Kind of a rough workaround though, but I have also been looking for ways to just extract wav files from .nki files - but no luck.
I have to say - I absolutely looove the multi-sample and the granulator - they're wonderful. So good I think I need a second Disting Ex to be able to use both at the same time. :lol:
Glydez
Post by Glydez » Tue Mar 23, 2021 5:28 pm
Thanks so much!!!
Likewise, this 5 year old walkthrough would be invaluable for me!
Post by os » Thu Mar 25, 2021 3:20 am
New video from Sound Isles:
Skelecaster
Post by Skelecaster » Thu Mar 25, 2021 10:08 am
Wondering if anyone has put one of these into the Moog cases? It would be a tight fit for sure but it might just make it.
ehr
Post by ehr » Thu Mar 25, 2021 10:32 am
Blond 12 wrote:
Wed Mar 17, 2021 5:52 am
Hellos Os
Thanks again for this amazing new update. The new granulator work so well.
I just have to report one bug.
The sd multisample his now unusable on my side.
I never had this issue before 🤷🏻‍♂️.
Here is the setup.
My midi keyboard into FH-2 USB linked with the Disting EX ( PCB cable 4pin)
And now when i use for exemple the preset piano 49 if you just do a stress test pressing just the same note alternatively in tempo at some point the sound start to lag with latency then stopping the sound , freezing then playing again and sometimes i have to restart the module cause general freeze.
I never had this problem on prévious others firmware.
Thanks in advance having a look on that.
I am also experiencing audio dropouts with the SD mulitisample with the new firmware 1.7.1. No sd multisample problems with version 1.6.3.
