Ritual Electronics 1U modules
Terdjman
Post by Terdjman » Tue Apr 28, 2020 8:15 am
We introduced six new 1U modules for Superbooth 20 Home Edition.
Quick overview:
Flexibilité
Expression pedal adaptor
Foot controlled attenuator / attenuverter
Input to attenuate external signals (audio or CV)
Without an input signal, outputs 0/+5v in unipolar mode or -5v/+5v in bipolar mode
Reverse polarity switch inside for compatibility with most expression pedals
10HP
Pointeuse
Momentary footswitch pedal adaptor
Foot controlled momentary & latching mute
Input to mute external signals (audio or CV)
Without an input signal, outputs 5v.
Clickless mute
Reverse polarity switch inside for compatibility with most sustain pedals
12HP
Assemblée
Signal mixer & mangler
Combine two signals with analog logic operations (Max & Min) and mixing (Mix)
Mute switch for each signal
Output selected with a 6-position rotary switch
Bipolar output LED to check the signal polarity
14HP
Krach
White noise and pink noise
10Vpp
Cheap and compact
6HP
Répression
Comparator with CV controlled threshold
Out outputs a gate when the input is above the threshold
Inverted Out outputs a gate when the input is below the threshold
The threshold range is 0-8V.
If an external signal is patched in the Threshold CV input the knob becomes an attenuator.
10HP
Guillotine
Stereo soft + hard clipping distortion
Its insane amount of gain can be used as an instrument adaptor (guitars, basses, microphones…)
It can bring line levels to modular levels
Three way switch to select from three different frequency emphasis
14HP
These are Intellijel 1U format but we could do a run of Pulplogic 1U format faceplates.
We did a poll on Instagram to know if we should offer these in both Intellijel & Pulplogic format, and it seemed the Pulplogic users were scarce in our followers. What about here? Can you please raise your hands Pulplogic format users?
As I write the prices are not fixed, nor is the release date. I'll edit the post once we know more!
corbetta
Re: Ritual Electronics 1U modules
Post by corbetta » Tue Apr 28, 2020 9:04 am
These are great! Especially interested in the expression pedal tiles.
@realwiggler
Post by @realwiggler » Tue Apr 28, 2020 9:14 am
Awesome to see more in 1U, these look super useful! Great work
+1 for Pulplogic format :yay:
"Don't be a douchebag"
- Mr. Muffs
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Tue Apr 28, 2020 10:32 am
Good thing you started off making the Intellijel versions, it is easier to make the Pulp Logic versions from them than visa versa (the space used for the PCB is smaller on the Intellijel tiles). I am not a tile person myself, but the only other difference is the power connector, correct? If the board have both connectors then all that is needed is a different front panel.
-James
otnemem
Post by otnemem » Tue Apr 28, 2020 10:36 am
These look great! I could certainly use the expression pedal module
Crimesofthecrown
Post by Crimesofthecrown » Tue Apr 28, 2020 10:40 am
Guillotine looks incredible!!!!! Assemble too!
Merci mon ami!
GOD IS WAR - Curator of Hyper-Violent Industrial and Heavy Electronics
corbetta
Post by corbetta » Tue Apr 28, 2020 11:01 am
Does Flexibilité output the max unattenuated offset WITHOUT an exp pedal patched? Or does it output 0v in that scenario?
droningspaghettimonster
Post by droningspaghettimonster » Tue Apr 28, 2020 11:15 am
ritual electronics is awesome. hope the matrix mixer is getting along fine too. :tu:
blaythe.steuer
Post by blaythe.steuer » Tue Apr 28, 2020 12:26 pm
another +1 for pulp logic
and looks very cool! make more distortion 1U modules:)
mrhooks
Post by mrhooks » Tue Apr 28, 2020 1:51 pm
Great ideas, especially the last two. However, I wish the Krach were 4HP.
WTB: original MI Rings panel
Also looking for someone willing to make a couple small changes to Rings firmware
tenshun
Post by tenshun » Tue Apr 28, 2020 2:53 pm
count me in for Pulp Logic format as well.
That distortion sounds brutal
scottmfr
Post by scottmfr » Tue Apr 28, 2020 3:07 pm
Very cool! I've been wanting a 1U foot pedal input...
As much as I hate to be "that guy", will you be offering these in silver faceplates to match Intellijel modules? It seems odd to me to make Intellijel sized 1U modules in black when all the Intellijel 1U modules are silver. Although I know there's lots of people that want black Intellijel faceplates!
yellowecho
Post by yellowecho » Tue Apr 28, 2020 3:31 pm
I'm one of them! These look incredible :sb:
deftinwulf
Post by deftinwulf » Tue Apr 28, 2020 4:31 pm
I don't have a 1U case, but if I did I would be giving a long, yearning look at that Guillotine as a stereo stompbox adapter + gain stage for pedals -> euro. Awesome!
Voltcontrol
Ravey Dave
Post by Voltcontrol » Tue Apr 28, 2020 4:38 pm
Make another run of those blind panels pretty please? ¿?
Control
Post by Control » Tue Apr 28, 2020 5:40 pm
The Guillotine module looks fantastic!!! Nice work. Can’t wait to try one!
minatorymodular
Post by minatorymodular » Tue Apr 28, 2020 6:14 pm
Time to find 1U rail brackets. Or wait until shipping from Clicks and Clocks returns to pre-virus prices.
HiHamGautier
Post by HiHamGautier » Wed Apr 29, 2020 3:28 am
Thanks guys for your comments! Here's a few replies to your questions.
Yes the only other difference is the power connector, however we do not plan on adding the Pulp logic tile connector as you're still able to use the normal 10pin power connector with a long cable. The space on the Intellijel 1U PCB is really, really tight.
In this scenario it outputs 0v.
We would have loved to have it in 4hp too but the space is really small on the PCB for the 1U format and we would not be able to fit all the components.
Well I guess it's a question of tastes. For now Ritual Electronics will stay all black panels but maybe at some point we'll do special limited edition silver panels.
And Yes, there are plans to make another run of blank panels ;).
teamhobson
Post by teamhobson » Wed Apr 29, 2020 7:37 am
I said it in the Superbooth thread a few days ago but those pedal interface modules are a great idea. Can't wait to try them out.
The answer seems fairly obvious to me: small Eurorack company with a very obvious dark, occult style aesthetic probably aren't going to step away from that to conform with Intellijel's panel colour.
+1
I'd love to see another run of the blind panels.
minatorymodular
Post by minatorymodular » Wed Apr 29, 2020 5:41 pm
If anything they should make the panels darker and occultier. Might be a minority here, though
DeltaTucanae
Post by DeltaTucanae » Wed Apr 29, 2020 6:44 pm
So many great 1U tiles that have come out recently, these are no exception
HiHamGautier
Post by HiHamGautier » Mon May 04, 2020 2:55 pm
We talked a bit more about the new 1U range in this video with Synth Anatomy
Polyterative
Post by Polyterative » Tue May 05, 2020 1:10 pm
Hell yes finally !!! Definitely gonna consider some for my new case
Rack / Music / Instagram / Module demos
► Show Spoiler
lumena
Post by lumena » Thu May 07, 2020 11:51 am
Looks like a great way to add my guitar in.
super!
