Beast’s Chalkboard alternative?
kriskeyman
Post by kriskeyman » Tue May 19, 2020 10:22 pm
Any alternative modules like Beasts Chalkbord? Needs to have 2-3 inputs, thru, along with +/- per input. CV control a plus.
Re: Beast’s Chalkboard alternative?
Post by lisa » Tue May 19, 2020 11:25 pm
So, exactly as the BC but something else? I’m quite sure (and I’ve checked) that there’s nothing like that available. There are some quite digital, complex, multi purpose modules that might be able to do the same thing but that seems like overkill.
Why not just get the BC?
My first modular track where I used drum modules! There's also a ton of FM cross modulation from the Instruō Cš-L in there and the Metasonix R56 is a big part of the sound. :star:
We also just did a live performance. Just eurorack, a mixer and two nitwits. :hyper: http://tiny.cc/8ndspz
sierraoskar
Post by sierraoskar » Wed May 20, 2020 1:11 am
If I understand what you’re saying, this would work?: https://www.noiseengineering.us/shop/quant-gemi
Doesn’t have CV transposition but can be paired with: https://www.noiseengineering.us/shop/quantus-pax
Post by lisa » Wed May 20, 2020 1:22 am
Lacks thru. Could be paired with a mult but the combo will take up as much space and cost more.
sierraoskar
Post by sierraoskar » Wed May 20, 2020 1:54 am
Ah yes - first thing the morning my eyes clearly hadn’t opened enough to see those 4 little characters :doh:
darylc
Post by darylc » Wed May 20, 2020 5:27 pm
From looking myself before there really isn't anything else around that does specifically what the Beast's Chalkboard does.
Apart from the mind-boggling ergonomics of the module it's perfect. All patched up it can be an unusable mess...
Also CV control over this kind of function is essentially just a sequencer into a 2-3 input adder unit...
Other options not mentioned...
doepfer a-185-2 (single adder, with mult out, +/- voltages)
vpme.de t43 (single adder, no mult out, +/- voltages)
jox2000
Post by jox2000 » Wed May 20, 2020 6:59 pm
What about Klavis caltrans?
Post by lisa » Wed May 20, 2020 7:05 pm
No thru.
noise-e
Post by noise-e » Wed May 20, 2020 7:15 pm
Just to jump in here: QG's inputs are normaled and act as a mult when unpatched. A through could be achieved by leaving a lower channel's input unpatched and untransposed. :party:
-Markus
Jumbuktu
Post by Jumbuktu » Wed May 20, 2020 9:13 pm
Am I missing something? Doesn't a Stackable into the input provide a through?
I have a BC. What is it that is missing for you? CV control?
void23
Post by void23 » Wed May 20, 2020 9:23 pm
Normally, you should try to avoid splitting pitch signals. That's what buffered mults are for.
Jumbuktu
Post by Jumbuktu » Thu May 21, 2020 12:26 am
I haven't needed one. I haven't noticed audible voltage drop off.
Post by MindMachine » Fri May 22, 2020 9:54 pm
I tried two. They never worked right. I have an eye on the ACL Oktave. Similar but different.
msegarra
Post by msegarra » Fri May 22, 2020 11:45 pm
I’ve thought this module was named breast’s chalkboard for years
Post by MindMachine » Fri May 22, 2020 11:56 pm
Makes as much sense. I thought it was Beast's Cockboard for a second. It was bunk. Maybe they fixed the issues.
Post by lisa » Sun May 31, 2020 12:54 pm
There is a drop, no doubt. But if you're doing patches where the exact pitch isn't important it won't matter, I guess. I've solved the problem by sending the split signals to quantizers but that might not be the most efficient solution. :goo:
BTG
Post by BTG » Sun May 31, 2020 2:35 pm
there was a thread on this at some point, but at least the two units I had had noticeable droop on the 1V/oct output, which is a shame since in theory it's a really useful module.
peachesandbacon
Post by peachesandbacon » Sun May 31, 2020 5:04 pm
I recently watched Ben DivKid’s modular rig rundown with Jamie Lidell, and they were both praising the hell out of the VPME T43. Jamie had maybe 3 or 4 of them in his rack.
What’s so special about the T43 over other precision adders? :cloud:
