WMD 4tten - 4 channel attenuator and offset
NastyNachos
Post by NastyNachos » Wed May 20, 2020 12:33 pm
Our newest module is out and shipping now!
Such a useful little module.
Here's the deets:.
4TTEN (pronounced either ATTEN or FOUR-TEN) is a four channel attenuator and offset generator.
Use 4TTEN to attenuate any CV or audio signal by running through the ins and outs.
A +5V voltage source is normalled to each input, making it a standalone offset when there is no cable patched into an input.
Each channel is completely independent.
Ever-so-useful in live performance, we designed this module with 4 sliders for easy maneuverability, visual feedback, and enjoyable to play interface. Make your eurorack modular synthesizer system more playable with 4TTEN!
*** 4TTEN's PCB is 113mm (4.45") tall and may be a tight fit in some cases ***
Highlights
  • 4 independent attenuators for Control Voltage and Audio signals
    Performance friendly sliders
    Can be used as 0 to +5V Offset
    Comfortable fader caps from the Performance Mixer
    Only 4 hp!
Specs:
Depth: 30mm(with cables)
Power: +5mA , -5mA
Virtually no drop on 1V/Oct signals.
VERTICAL PCB LENGTH: 4.45 in
IMPEDANCE
(SOURCE + 100ohm ) / 100kohm
UNBUFFERED
dooj88
Re: WMD 4tten - 4 channel attenuator and offset
Post by dooj88 » Wed May 20, 2020 1:52 pm
sweet, a little must have module! love me blinkenlights on utilities!
Buyakasoundman
Post by Buyakasoundman » Wed May 20, 2020 2:22 pm
Too bad it only outputs 5 volts. I’m looking for faders for my Muton and this would have been perfect. Back to the MSW F8R plan I guess.
Any chance in 8-10V outputs, Alex?
I know, I know, completely different use cases; attenuater vs cv souce, but a girl can dream.
WMDevices
Post by WMDevices » Wed May 20, 2020 7:19 pm
From the Muton Manual: "A control voltage, such as an envelope with an 8-10V peak will open the VCA completely for unity gain output. Lower voltage CV will also work with a reduction in output volume - in some situations such as mixing, lower volumes may be desired as to alleviate clipping."
So it's probably good with 0-5. If you've verified that you need 8-10V, then we could swap one part for you and do a lil custom jobby. But, you should try first to see if it's totally necessary!
-WM
Check out the growing number of WMD Demo Videos | WMD Website
autopoiesis
Post by autopoiesis » Thu May 21, 2020 12:48 am
cool. does it have LEDs (can't really tell for sure in the photo) to indicate input or output voltage levels and polarity? will there be a silver panel too?
WMDevices
Post by WMDevices » Thu May 21, 2020 12:51 am
Yes LEDs, indicates positive voltage. Negative voltage is not indicated by the LED. No silver panel because we are manufacturing panels in house, and we can not make silver panels. The panels are milled and engraved.
joefrost01
Post by joefrost01 » Thu May 21, 2020 7:14 am
Brilliant idea! Where can I buy it in the UK?
khyber
Post by khyber » Thu May 21, 2020 7:26 am
Voltage and polarity jumpers would be a cool mod
Buyakasoundman
Post by Buyakasoundman » Thu May 21, 2020 11:07 am
-WM
Wow, thanks for the offer, I’ll be in touch. I tried using a 16n with my Muton in this fashion, but the 5v output wasn’t enough to open the vca’s satisfactorily. I could never get my drum mixes just right, mostly the Crater seemed like it was wasn’t getting to deliver it’s all. Faders all up on 16n, and the Crater was underrepresented compared to my 3 other WMD drum modules.
Thanks again Alex! You guys rock.
LYFoulidis
Post by LYFoulidis » Fri May 22, 2020 1:13 am
This is just the module I’ve been waiting for, I love to keep my bottom row accessible. Looking forward!
