Recommendations/wisdom about CV (DC-coupled) VCAs?
Bachelard
Post by Bachelard » Thu May 21, 2020 2:09 pm
Hi all,
Wondering if anyone has recommendations for particularly good DC-coupled VCAs? I'm finding more and more often wanting to use my VCAs to control my modulations. I have a Doefper A-135-2 which is DC-coupled, and most channels are used for my audio sources. I also have a Frequency Central Dual XVCA, which has 4 channels split into 2 groups of 2 channels with separate outputs, so I use one group for audio and the other group for CV but I don't think that one is DC-coupled - the signal gets slewed or something.
I have enough attenuator/verter/mixer modules (Frap Tools 321, Flipanda, Triatt), but when I use them I'm often thinking "gosh it would nice to have CV inputs on them."
Thanks.
mosorensen
Re: Recommendations/wisdom about CV (DC-coupled) VCAs?
Post by mosorensen » Thu May 21, 2020 2:31 pm
I like the Happy Nerding 3xVCA for CV control. The offset is nice, because then it can be dialed in to not close fully when the control voltage is down to 0V, which I like for CV control. The attenuverter on the control voltage (when negative, the VCA closes as the control voltage increases) and the mixing are handy as well.
synonymist
Post by synonymist » Thu May 21, 2020 2:55 pm
Hello. I like Tangle Quartet and Veils.
Buttons ARE toys
Post by Buttons ARE toys » Thu May 21, 2020 2:59 pm
The Happy Nerding 3xVCA is indeed extremely handy, affordable, and low hp. Hard to beat the VCA to hp ratio on it too.
Ring modulators are also really great for processing your CV since you can automate inversion of your signals in addition to amplitude. Mutable Blinds is a great quad unit, and I personally really like Befaco's A*B+C since it can also apply static offsets and boost signals to +/-2 gain. Doepfer makes some good, inexpensive options as well.
Astronomical Dusk - a web radio show of synthetic delights and collected oddities. Airs monthly at astronomical dusk.
Fedor
Post by Fedor » Thu May 21, 2020 3:11 pm
I'll second Happy Nerding 3xVCA, got two of them.
Arneb
Post by Arneb » Thu May 21, 2020 5:48 pm
I guess you could always wait for the A-130-8.
Bachelard
Post by Bachelard » Thu May 21, 2020 6:55 pm
Brilliant. Thanks for all the insight!
Brilliant idea about ring mods...I did use to have an Intellijel uMod (mk1) that I loved sending CVs through.
ari ellis
Post by ari ellis » Thu May 21, 2020 7:43 pm
For a quad DC-coupled VCA in a reasonable amount of space, the intellijel quad vca, mutable veils, and alm tangle quartet are probably the “standard” choices. I’ve only used the intellijel of the three, but they all use the same op-amp chip and are largely similar in application.
DisappearHere
Post by DisappearHere » Thu May 21, 2020 8:04 pm
The Zlob Vnicursal VCA is 6 DC-coupled VCAs in 8HP. I have one, it's great
