Freeeze a reverb ?
rafyc
Freeeze a reverb ?
Post by rafyc » Fri May 22, 2020 3:58 am
Hello,
I would like to freeze a reverb and wondering if i better to do that with a module or a pedal.
In fact i already have a Strymon BigSky but doesn't freeze.
So i'm on the Ventris Dual or OTO bam (Expensive) with this option.
What about eurorack module ? should i will be able to reproduce this kind of sound with my reverb ?
I've noticed some module to freeze, but looking for stereo
like "Audio Damage ADM15 Spectre Stereo FFT Freeze"
Is it the S&H module ?
djd_oz
Re: Freeeze a reverb ?
Post by djd_oz » Fri May 22, 2020 4:10 am
I believe the Clouds parasites firmware reverb algorithm has the freeze feature.
sir stony
Post by sir stony » Fri May 22, 2020 4:15 am
In eurorack land, Disting is my first idea, but its reverbs aren't really great to begin with. Maybe the reverbs on the new EX version will fare better, that remains to be seen.
Also, if I may add, freezing a reverb doesn't sound half as cool as the name suggests. I have had much better/more useful results by running a reverb tail through a granular processor (like clouds), and eventually freeze it there.
WTB: Dovemans SHFT
rafyc
Post by rafyc » Fri May 22, 2020 4:32 am
Hi thanks for answer,
I've tested clouds and was disappointed with sound quality.
Level was half the original volume, and input VCA distorted the sound. Maybe a bad clone...
I'm waiting for Arbhar.
Yes i've noticed Disting but reverb is not so good.
I would like to use my reverb pedal.
continuum
Post by continuum » Fri May 22, 2020 6:28 am
Freezing a reverb is usually done by setting the feedback to 100% in the algorithm (assuming the reverb structure is stable). One thing to note is that the more modulation inside the 'verb the more the sound will change over time and eventually decay away (it might take hours though). Filter settings may also affect the frozen sound.
Our ZVERB has 'Epic Mod Hall' that has a near infinite 'freeze' at the highest Time, but also has a lot of modulation so the sound changes over time. It is not intended to be a 'freeze' or infinite effect but a massive/ridiculous/epic decay time sound.
A couple of Z-DSP cards have reverbs that can do the 'Freeze' effect - some of the Valhalla programs with the right Chorus and Tone settings and the SSSR Labs 'Vertigo' card has an 'Sidechain Infinite Hall.'
Tiptop Audio R&D
www.tiptopaudio.com/
synonymist
Post by synonymist » Fri May 22, 2020 8:17 am
Hello,
Hello. I think you are mistaken about BigSky: it does implement infinite sustain and freeze.
https://www.strymon.net/manuals/BigSky_ ... l_RevD.pdf
rafyc
Post by rafyc » Fri May 22, 2020 8:52 am
Hello,
In fact i've missed that ! Nice !
I will try but i'm not sure to have a lot of control over it.
corbetta
Post by corbetta » Fri May 22, 2020 10:19 am
Keep in mind that the freeze on the big sky prevents any further signal to be reverberated, so if you run your entire modular signal through it the effect can be quite jarring (lush frozen pad with bone-dry signal alongside it)
The verb on the instruo Arbhar freezes at +5v
