DivKid RND STEP
Richard deHove
Re: DivKid RND STEP
Post by Richard deHove » Sat Jul 18, 2020 4:09 pm
So is there a bad batch or is it a trimmer issue?
closedLoop
Re: DivKid RND STEP
Post by closedLoop » Sun Jul 19, 2020 12:03 pm
analogPedagog wrote:
Sat Jul 18, 2020 12:25 pm
Making it louder will keep the even-ness of the distribution but the range will be a bit wider and may include some levels beyond +/-5V at times.
I did a little playing with the adjustments of Rnd Step. I'm guessing from what I noticed is that when the potentiometers are fully clockwise, it's all the way up, and when it's fully counterclockwise, it's all the way down.
While I was carefully doing the adjustments, I noticed a strange thing. When I touched the potentiometers, the range seemed to double, and that effect seemed to linger for a little after adjusting, after which it returned to 'normal.'
Here's 2 quick shot of the 3 channels, one of the bipolar, one of the unipolar. This is with all the potentiometers fully clockwise. Channel 3 has substantially greater range.
GryphonP3
Re: DivKid RND STEP
Post by GryphonP3 » Sun Jul 19, 2020 3:31 pm
Mine is acting exactly the same way. One channwl is stronger than the other two but nowhere near 5v, while the other two max at around 1.3v, and this is at fully clockwise settings.
My cat can eat a whole watermelon ...
BlinkyLights
Re: DivKid RND STEP
Post by BlinkyLights » Sun Jul 19, 2020 3:47 pm
He wrote in this thread that some were simply calibrated conservatively and some may need an adjustment now.
(paraphrasing, but it's just a page or two back, go look...)
Somewhat similarly, I once had to recalibrate my Ultra Random Analog, also with a tiny trimmer on the back.
It required a scope, but I had the Mordax, so it was crazy easy. Only "hard" part was not over-rotating the trimmer.
Richard deHove
Re: DivKid RND STEP
Post by Richard deHove » Sun Jul 19, 2020 4:58 pm
Sure, I read that about calibration and am not above tweaking, but what about people like Gryphon (above)? Pots all the way up and still not right? Or is that 'within spec'? Not hating here, just wanting more specific info!
analogPedagog
Steady State Fate
Re: DivKid RND STEP
Post by analogPedagog » Sun Jul 19, 2020 7:35 pm
Hey all,
So I performed some tests using my Rigol O'Scope and compared them to the Mordax data.
First, I highly recommend not using the voltage monitor to measure the output. The noise transients are very quick and the voltage monitor does not have that kind of bandwidth and will alias out everything nearing or going above 2kHz.
Also compared to the Scope mode on Data and the output is also a bit aliased and not showing the same peak levels as my 70Mhz bench top unit. However, I highly recommend using the scope mode vs Voltage Monitor as it will give you a much better picture of the actual output levels.
The faster your trigger speed, the more detailed the output level will be, as you will be allowing more samples of the noise to be seen on your Scope within a given time division.
That being said, I'm sure that because I was being so conservative that there will be modules with lower output - that may or may not work for you. I will say again that all you need to do is try and turn up the levels. If that does not work for you and/or you are having any other issues - please just contact me via the SSF website contact form and I will take care of you.
Apologies again for any inconvenience caused. Happy to make it right.
-Andrew
SSF
GryphonP3
Re: DivKid RND STEP
Post by GryphonP3 » Mon Jul 20, 2020 12:44 am
Hey all,
-Andrew
SSF
Thank you for the good support andrew, i'll contact you over there.
Glitzerstrahl
Re: DivKid RND STEP
Post by Glitzerstrahl » Sun Jul 26, 2020 10:36 am
I’m finding the s&h performance to be pretty poor honestly. Trying to feed a 16 step sequence of pitches and hit it with random but in sync (e.i. Not Euclidean for example) gates to pick up a melody. I find the resulting pitches to sometimes be out of tune, whereas when I perform the same patch with for example the Intellijel Noise Tools S&H it’s rock solid... I don’t have a scope to verify or screenshot but but it’s obvious to the ear. Thus I’ve resorted to only using it for random modulation instead....
malnourish
Re: DivKid RND STEP
Post by malnourish » Sun Jul 26, 2020 10:48 am
Anyone else feeling the same way? I was hoping to pick one of these up in the near future, and was specifically hoping to do pitch oriented things so I don't want to bite if it's unreliable.
closedLoop
Re: DivKid RND STEP
Post by closedLoop » Sun Jul 26, 2020 11:02 am
Just for clarity - you're feeding a v/oct signal to the input of Rnd Step, and then triggering it randomly?
I've never thought to work that way. I always feed the output of S&Hs into a quantizer.
malnourish
Re: DivKid RND STEP
Post by malnourish » Sun Jul 26, 2020 11:22 am
Typically that would be the expected norm, although this was a significant portion of the marketing pitch, that it would be stable enough for extracting v/oct without drift (or minor enough drift it would be highly useable for this use case).
Glitzerstrahl
Re: DivKid RND STEP
Post by Glitzerstrahl » Sun Jul 26, 2020 7:46 pm
Correct, and to be clear the signal is already quantized as its coming from a quantized sequencer.
Also the triggers are always on the beat.
I've tested it with a sequence from Rene (quantized), the SQ-1 and the new quantized pitches from FW 2.06 of Pam's. Regardless of the source the output does not match the pitches of the sequence 100%, so randomly I get a note that is not in the sequence and therefor throwing the melody out of tune.
With my other Sample & Holds (Intellijel Noise Tools 1U or Doepfer A-148) I'm not seeing this behavior. No matter how frequently or infrequently I trigger them the pitches are always one from the sequence they are being fed.
Exactly. That's what's so surprising to me. :eek:
Maybe I just got a bad unit.... :despair:
And just to avoid confusion, I love my other SSF modules.
Design is always spot on and never had any issues in the past, so no shadow on the brand and their other stuff.
Last edited by Glitzerstrahl on Sun Jul 26, 2020 11:44 pm, edited 1 time in total.
ima_jrk
Re: DivKid RND STEP
Post by ima_jrk » Sun Jul 26, 2020 9:55 pm
And just to avoid confusion, I love my other Instruo modules.
Ochd is Instruo. RND STEP is SSF.
Glitzerstrahl
Re: DivKid RND STEP
Post by Glitzerstrahl » Mon Jul 27, 2020 12:07 am
LOL yep. Sorry mixed it up when I wrote the post. Edited to reflect.
closedLoop
Re: DivKid RND STEP
Post by closedLoop » Mon Jul 27, 2020 9:30 am
Are you grabbing from the Unipolar or Bipolar output?
As I note above, I never work the way you're trying to work, but I did a quick test patch. From the Bipolar output, I'm getting pretty good pitch tracking feeding USTA's CV out into Rnd Step, and triggering with PNW. I'm checking the tune on the Mordax Data tuner.
Things do get a little weird from the unipolar.
Glitzerstrahl
Re: DivKid RND STEP
Post by Glitzerstrahl » Mon Jul 27, 2020 11:49 am
Thanks for checking! I’m using the bipolar since the unipolar always samples from the internal random source. Maybe the
problem is just with my unit... will do some more testing and report back...
kpreid
Re: DivKid RND STEP
Post by kpreid » Mon Jul 27, 2020 12:57 pm
Perhaps the problem is timing? Any sample-and-hold, no matter how good at sampling it is, placed after a sequencer or other stepped CV source will produce "wrong" results if the sampling is performed at the same time the CV source is in the middle of shifting to a new value.
The test/workaround for this would be to add a small delay between the trigger controlling (or produced by) the sequencer and the trigger input of RND STEP, using a trigger delay module, delayed envelope, or similar. If that eliminates the unquantized results, one can then experiment with making the delay as short as possible.
closedLoop
Re: DivKid RND STEP
Post by closedLoop » Mon Jul 27, 2020 1:39 pm
I had completely forgotten the unipolar is always to the pink noise source - thanks for the reminder.
analogPedagog
Steady State Fate
Re: DivKid RND STEP
Post by analogPedagog » Mon Jul 27, 2020 5:39 pm
It is the right idea that the trigger can/should be delayed in some cases.
Being such a fast trigger on RS of 50us, it could be sampling faster than the seq responds - during the transition between notes. And then you have to account that it isn’t always going to be perfect every time.
A longer sample duration that some s&h may utilize would close the sample switch later, once the transition to the next note has completed, but at the expense of high freq performance (ie sample rate reduction) and would allow more of the sample source to creep onto the output.
Glitzerstrahl
Re: DivKid RND STEP
Post by Glitzerstrahl » Tue Jul 28, 2020 12:20 am
Yep the timing could absolutely be the reason, but since my other sample and hold modules do not produce these artifacts I'll just use those instead for pitch and the RND STEP for other tasks. :love:
Dick Champion
Re: DivKid RND STEP
Post by Dick Champion » Sat Aug 01, 2020 8:02 pm
I'm having the similar issues with dropping voltage and wobbly sampling on the RND STEP.
When using o&C to monitor the pitch of an oscillator held by RND STEP, I can see it dropping ever so slightly.
Dont know if that is within reason.
But the annoying thing is, I wanted to do the "quantize-before-s&h"-trick... but the pitch is to darn off.
Even when I just feed the RND STEP a steady voltage from the uScale, it deviates just enough to be useless on each sample.
Kinks from Mutable is actually better at sampling incoming quantized voltages.
I also have a Disting MK3 but it's acting weird.
Oh, and I probably blew my other Disting by some kind of short. This is not my day.
OHEXOH
Re: DivKid RND STEP
Post by OHEXOH » Mon Aug 10, 2020 1:13 pm
I was having similar issues where the voltage range was move like -1v to 1v. After adjusting the screws on the back the voltage is much better going between -5v to + 5v with the weighting as per the diagram in the manual. For me it was a 3/4 turn from fully CW.
Gear for sale (Reverb): https://bit.ly/2Sb90oc
thetechnobear
Re: DivKid RND STEP
Post by thetechnobear » Tue Aug 11, 2020 5:58 am
I had the same problem, even though I only received my RNDSTEP recently.
but thanks to this thread, a quick half turn on each trimmer has brought my RNDSTEP alive !
OHEXOH
Re: DivKid RND STEP
Post by OHEXOH » Tue Aug 11, 2020 11:03 pm
Similar to the post further up, I'm not getting rock steady voltage at all. I've tried sending CV and gates from both a Hermod and a Permutation into RND Step and it struggles with both. I made a comparison with Shifty and the results are very noticeable and unfortunately unusable.
The clip below is a simple 2 note CV and Gate pattern from Permutation. The first example is Sample & Holding via Shifty. The pattern and note pitches are consistent. The second example is via RND Step. The pitches are off - sometimes by a little, sometimes by a lot.
Shifty has the ability to add some delay compensation to allow for the CV to stabilize and I think this is why it's much better - though I've always found Shifty to be very good at this task even when the delay compensation is off.
So my questions are: do I have a dud or is this just the way RND Step performs? If the latter - is it fixable?
SarahB
Re: DivKid RND STEP
Post by SarahB » Thu Aug 13, 2020 12:05 pm
Reporting that mine is also not working properly. My signal is bleeding though (so not holding properly) between triggers. I compared with my Kinks and the difference is really obvious. Disappointing :(
