Feedback use and controls
apestate
Post by apestate » Sat Jun 20, 2020 10:32 am
Hello wiggles
I recently got a matrix mixer and started experimenting with feedback patches - and i'm very happy with the sound. Looking for more interesting paths for experimentation.
Please tell me everything you know about feedback patches - with VCOs, filters, reverb, CVs, anything!
How do you keep your feedback under control? How do you prevent ear-piercing moments? :zombie:
blaythe.steuer
Re: Feedback use and controls
Post by blaythe.steuer » Sat Jun 20, 2020 10:34 am
distortion gets real crazy real quick. delay too!
tons of people really like the serge res eq specifically for feedback purposes
pugix
Post by pugix » Sat Jun 20, 2020 10:50 am
Instruō tanh[3] is great to use as a limiter in feedback patches.
https://pugix.com/synth/instruo-tanh3-demo/
DivKid
Richard
https://www.pugix.com
FS: US only - Mutable Instruments Streams
natureclubcassettes
Post by natureclubcassettes » Sat Jun 20, 2020 10:56 am
+1 for this. Also using the Doepfer 188-2, with a bunch of external modules in the feedback path. Filters, other delays, pitch shifters are all really fun in the feedback patch.
Lately I've also been using a combo of the FxdF/Linix and an MMG patched back into the other FxdF input, controlling the outs of the FxdF with the Linix VCAs. Very organic sounding.
Rings is also great in a feedback patch.
Shapeshifter with the internal delay engaged can lead to some really great, pseudo granular sounding patches. There was a really great thread about it a few years back
mritenburg
Post by mritenburg » Sat Jun 20, 2020 10:59 am
Delay feedback using a console fx send to feedback the delay output back into it self is a common Dub Reggae production technique. In Dub Reggae production they manually ride gain the fx send to ensure that the feedback does not get out of control. In modular you can automate this with a delay module and a vca. Use the vca to control the level of the delay output signal that is feeding back into the delay. If you control the vca feedback send appropriately, you can get some great delay feedback and distortion without undesirable feedback effects.
Disappointment with any module is usually a failure of imagination.
The story you are about to hear is true.
apestate
Post by apestate » Sat Jun 20, 2020 11:13 am
Thanks! I vaguely remembered seeing this a few days ago but couldn't remember which module did this.
Is this something that can be done with any waveshaper?
pugix
Post by pugix » Sat Jun 20, 2020 4:40 pm
It depends on whether the waveshaper limits the output.
Richard
moremagic
Post by moremagic » Sat Jun 20, 2020 7:09 pm
feeding back into cv inputs is a great way to change many voltage controlled modules responses. feeding sub audiop
cackland
Post by cackland » Sat Jun 20, 2020 7:15 pm
Hello wiggles
Which matrix mixer did you get?
vrfats
Post by vrfats » Sat Jun 20, 2020 7:25 pm
Hello wiggles
Feedback chain -> Env Follower -> Signal Inverter -> VCA (with Feedback chain passing through) with gain turned up to allow signal to pass through and CV adjusted to liking / functionality
You can do this with A119 and Maths. I think you can also patch an env follower with the slew inputs on maths.
starthief
Post by starthief » Sat Jun 20, 2020 8:48 pm
I like having a VCA in the feedback loop that's controlled from an inverted envelope follower. It'll boost the level to keep feedback going, but cut the level to stop it from clipping.
Depending on what's in the loop, a highpass filter can be helpful to block DC and maintain headroom. Any other filter or EQ is definitely nice to have too, whether to notch out more piercing resonances, or to create resonances where you want them.
A pitch shifter and an "opposite" filter -- e.g. pitch shift down + highpass or pitch shift up + lowpass -- is fun too :D
apestate
Post by apestate » Sun Jun 21, 2020 3:54 am
Livestock electronics' maze.
apestate
Post by apestate » Sun Jun 21, 2020 3:59 am
Do you mean using this signal into env follower etc. as the feedback modulation? Or as additional feedback from the already feedback looping sound?
seicocorp
Post by seicocorp » Sun Jun 21, 2020 6:01 am
Hello wiggles
This!
And also: Verbos got env followers built in. Both the delay (the dry+taps) and the bark filter got it per band + all bands sum. Amp and tone can invert incoming cv. So in Verbos that module list is two modules. delay/bark + Amp&tone. Theyre great for these kind of patches.
smithjohn
Post by smithjohn » Sun Jun 21, 2020 10:31 am
Spring reverbs are great - Doepfer A-199 with A-112 and A-188-2 feeding back into each other can make amazing sounds at the point when the feedback is starting to build up. Seems like an envelope follower or other suggestions above would be useful to keep the levels at bay.
vrfats
Post by vrfats » Sun Jun 21, 2020 8:13 pm
Think of it like patching a sort of ad hoc limiter / compressor. The signal turns down itself if it gets too loud. If you slew the envelope you can mess with the response a bit. This is also fun for sidechain effects etc.
