diy module - afraid to plug it in
seriousziggy
Post by seriousziggy » Mon Jun 29, 2020 7:16 am
Hi everyone ,
Just built a diy project the ginkosynthese seeds .
i did check with a multimeter continuity test "forward and backward" and everything seems fine no shorts between positive ground and negative and a short peak that appears like i read was normal .
Now i'm still afraid to plug it in my case .
A part from frying the module ( i hope not) is there also a chance to fry other things in the case or can i go quiet serenely into it ?
i know some people use for diy projects firs ta small rack just to test but i don't have that possibility .
I already built once before a "time wizard" at my friend from the Shakmat modular and he said i did that properly .
Thanks for your help
Igor
Pelsea
Re: diy module - afraid to plug it in
Post by Pelsea » Mon Jun 29, 2020 10:05 am
What brand of power supply do you have?
Books and tutorials on modular synthesis at http://peterelsea.com
Patch responsibly-
pqe
Muff McMuff
Post by Muff McMuff » Mon Jun 29, 2020 10:34 am
The fear before plugging a freshly built DIY module in. I get that fear too! Glad i am not the only one. Sometimes if i have spent a few hours finishing a module and i am a bit tired i will plug it in the next day. I think its something to do with confidence in your own SDIY abilities which for me is very little, just soldering the right component in the right place. I powered up an SSSR Labs VC Divider. LEDS flashing all over the rack except the VC Divider. Major depression. Turned it all off. Came back to a few hours later. All i needed to do was patch it up and actually use it. LED's started flashing worked fine!
If you are worrying about your other modules though, unplug everything else and just power up the new module on its own. That will minimise any risk to the rest of the rack.
seriousziggy
Post by seriousziggy » Mon Jun 29, 2020 10:46 am
i have a pittsburgh modular case
NeolithicElectrophones
Post by NeolithicElectrophones » Mon Jun 29, 2020 10:53 am
If you plan on doing more DIY and don't want to have repeated anxiety, I would recommend building up a usb supply and power it from a charge bank. This design has short protection, fits nicely on the bench and actually puts out a decent amount of power. https://modularaddict.com/mmi-usbpower-pcb
I use them for portable skiffs as well to get wiggling outside and the power is generally pretty clean even with digital modules.
If you're in Europe you could try to find one of these instead. Don't know if they have short protection but most charge banks have some safety features anyway.
https://modularaddict.com/manufacturer/ ... thingy-pcb
Built up a couple a few months back and they're good fro DIY testing or single module use cases.
Pelsea
Post by Pelsea » Mon Jun 29, 2020 11:51 am
Go ahead. You can't damage that PSU or any other module in the case.
Just turn off the power if it doesn't work.
I have an Elenco power supply on my workbench to check modules out.
Patch responsibly-
pqe
forestcaver
Post by forestcaver » Mon Jun 29, 2020 12:32 pm
I’m not sure that’s entirely true. Eg your module could short a psu rail to ground, meaning other modules will lose that rail. Some modules can be damaged from losing a rail (eg modules with a v2164 that doesnt have explicit protection of the ic). So you can damage other modules pretty easily from a dodgy diy build.
brycecake
Post by brycecake » Mon Jun 29, 2020 12:49 pm
Test it with a pair of 9V batteries.
bgribble
Post by bgribble » Mon Jun 29, 2020 12:55 pm
I would always power up any newly-built project on its own power supply for the first time. If it powers up properly on a power supply by itself, passes all your basic tests for functionality, and doesn't leak magic smoke or get hot then you can give it a try in the full box.
Too many other variables are introduced when your power bus is more like a kindergarten schoolbus full of chatty noisy modules. For example maybe you had a bad flow on a capacitor in the power supply filtering circuit and all the noise from other modules screws up a chip on your module. If you know that it powers up when it's by itself but not with other modules on the bus that points a finger right at the power supply.
Pelsea
Post by Pelsea » Mon Jun 29, 2020 1:58 pm
He did test the power connections with a meter, and found no shorts.
Patch responsibly-
pqe
forestcaver
Post by forestcaver » Mon Jun 29, 2020 2:32 pm
Fair point - but my paranoia is such that I always check all rails to GND with both +ve and -ve leads (ie both directions) to make sure a series diode isnt hiding a short :-) But for the sake of a £7 dc-dc meanwell (if you cant justify/afford a bench supply), I’d never plug a fresh module into my main case....
(But really I agree - if it’s been tested very carefully and there is genuinely no short then damage to other modules or psu is vanishingly unlikely)
mskala
Post by mskala » Mon Jun 29, 2020 4:50 pm
If you're going to do DIY on a regular basis then it's worth investing in a bench supply with current limiting. Adjust the limit to a little more current than you expect the module to draw, plug the module into it first, and then even if there is a short you're unlikely to get any serious damage to module, supply, or anything else.
But I also think it's worth blowing up a few components like LEDs on purpose just to learn what that's like and get past the fear. Connect an LED across the power rails with clip leads and see what happens. People think I'm joking when I say that, but I'm not. You'll really feel more confident once this kind of thing is no longer an unknown.
transistorresistor
Post by transistorresistor » Mon Jun 29, 2020 4:58 pm
both points great advice, especially the later, working w 12v is super easy.
uniquepersonno2
Post by uniquepersonno2 » Mon Jun 29, 2020 5:56 pm
I do a lot of testing and have a dedicated case for testing new modules. Since you're just doing bare minimum not-blowing-anything-up tests literally any supply will work so you can pick up a used uZeus or something for around $100 and protect the rest of your stuff.
seriousziggy
Post by seriousziggy » Mon Jun 29, 2020 7:52 pm
thanks for the replies
did the continuity test ,everything was fine . decided to plug it in
it works !
the sort of usb supply seems like a good idea
thanks
khakifridge
Post by khakifridge » Tue Jun 30, 2020 3:04 am
I have a Joranalogue Test 3 and an FC Power board in a standalone box. It gives me enough of a warm, fuzzy feeling that nothing will die when I transfer my build to a case.
Bodo1967
Post by Bodo1967 » Tue Jun 30, 2020 3:24 am
I have two of these (one with 12 V, one with 15 V) mounted on a standalone board on my workbench, and driven by a 15V AC wall wart. Don't wanna miss them :).
... why buy it for $100 when you can build it yourself for $150?
