Joranalogue MORPH 4 - Dimensional Modulation Array
joranalogue
Post by joranalogue » Sat Aug 29, 2020 9:14 am
Change is constant
Modulation is the core concept of modular synthesis: parameters changing over time, adding movement and musical interest to what would otherwise be merely static sounds. Being able to control the amplitude of signals throughout a patch is therefore essential, and one can never have too many voltage controlled amplifiers (VCAs).
Designed as a fully-featured modulation hub for Eurorack synthesisers, Morph 4 takes the basic concept of the multi-VCA module to the next level.
Four linear amplitude modulators are controlled by a master ‘morph’ parameter. The response of each modulator to this parameter is completely variable, both manually and under voltage control, and can be overridden if desired. Each response is triangular, with the ‘position’ parameter setting the maximum point along the morph axis, while ‘span’ determines the width of the triangle’s base.
In addition to separate signal inputs and outputs, a variety of combined outputs is available as well: A+B, C+D, add (unity gain) and averaging mixes, and instantaneous minimum and maximum. Input normalisation makes it easy to send the same signal to multiple modulators, while output and modulator response LEDs provide essential visual feedback.
The combination of master control, fully flexible modulators and multiple combined outputs creates a module truly embodying the spirit of ‘patch programmable’ modular synthesis. Use Morph 4 as a voltage controlled mixer, dual crossfader, dual panner, interpolating scanner, interpolating distributor, quad VCA, quadraphonic controller, slope modifier, rectifier, complex waveshaper or something in between any of those—the choice is yours.
Coming soon! Worldwide release on 2020-12-08.
More info: https://joranalogue.com/morph-4
ModularGrid: https://www.modulargrid.net/e/joranalog ... gn-morph-4
Pricing: €350 / $350 (MSRP)
20 HP, 30 mm deep
Joranalogue Audio Design
21st Century Analogue Synthesis—Made in Belgium
Michael
Re: Joranalogue MORPH 4 - Dimensional Modulation Array
Post by Michael » Sat Aug 29, 2020 9:22 am
Very nice!
fxxxxx
Post by fxxxxx » Sat Aug 29, 2020 11:36 am
Looks incredible!
BlinkyLights
Post by BlinkyLights » Sat Aug 29, 2020 11:57 am
Ooh, I like it.
deftinwulf
Post by deftinwulf » Sat Aug 29, 2020 11:59 am
Brilliant. Can't wait to hear demos of it in use!
MossGarden
Post by MossGarden » Sat Aug 29, 2020 12:21 pm
Damn fine!
Aaronautical001
Post by Aaronautical001 » Sat Aug 29, 2020 12:54 pm
Jesus, Joranalogue are on fire!
skreetis
Post by skreetis » Sat Aug 29, 2020 1:39 pm
This looks incredible! My urge to build an all Joranalogue system is growing all the time.
josephcampbell mask
Post by josephcampbell mask » Sat Aug 29, 2020 3:39 pm
Getting heavy MI Frames vibes from this.
The Joranalogue rug that ties the room together! Nice!!
brandnewmath
Post by brandnewmath » Sat Aug 29, 2020 4:35 pm
One thing about that panel I don't get: the inputs are labeled +5, A, B, and C; no section for D? Also that implies the inputs are offset from the knobs in their section. Is that right?
edit: I see now, it's indicating what the normalled input signal is for that section.
EASYBOY
Post by EASYBOY » Sat Aug 29, 2020 4:43 pm
This looks like a macro beast
VibratingMotorGate
Post by VibratingMotorGate » Sat Aug 29, 2020 4:44 pm
does the morph act as a four-way crossfader between the inputs or the modulators? and how does that correlate to the min, max, add, a+b, c+d outs?
joranalogue
Post by joranalogue » Sat Aug 29, 2020 4:54 pm
Each channel responds to the morph 'master' parameter according to its own position and span parameters. You can indeed set up M4 to 'scan' between up to four signals (in which case you would typically use the add or average mix outputs), but the applications are much broader than that; it all depends on how you set up the channels and which outputs you use.
Check out the presentation from the Dutch Modular Fest here: https://youtu.be/TReaU3769LE?t=6280
Enjoy! More demos are coming very soon.
PiecesOfQuiet
Post by PiecesOfQuiet » Sat Aug 29, 2020 5:21 pm
Looks like fun
MvK
Post by MvK » Sat Aug 29, 2020 10:59 pm
looks super interesting! Do the level potis also attenuate the control signal coming from the morph or only the CV from the channels' level input?
Tun
Post by Tun » Sat Aug 29, 2020 11:15 pm
Yes, if I was starting over it’d be an all Joranalogue system. Great quality modules, reasonably priced and love the brand aesthetics.
joranalogue
Post by joranalogue » Sun Aug 30, 2020 4:01 am
Both! Once you use a level CV socket, that channel will function as a standalone VCA, independent from the morphing.
ari ellis
Post by ari ellis » Sun Aug 30, 2020 8:51 am
If anyone could convince me that they’ve built a quad VCA with enough functionality to make 20hp look slim, it’s joranalogue. I’ll be watching this with interest!
cafe-de-la-jungle
Post by cafe-de-la-jungle » Mon Aug 31, 2020 7:07 am
This is fantastic! Instant buy!
damase
Post by damase » Mon Aug 31, 2020 8:13 am
so cool. took the quad vca concept up a notch. definitely will buy
maltemark
Post by maltemark » Wed Sep 02, 2020 2:47 am
I obviously managed to snag a early proto
Feel free to use my old samplepacks: https://freesound.org/people/altemark/
joranalogue
Post by joranalogue » Wed Sep 02, 2020 4:45 am
No relation. :)
pugix
Post by pugix » Wed Sep 02, 2020 7:27 am
Please add a block diagram to the manual.
Richard
https://www.pugix.com
sendepause
Post by sendepause » Wed Sep 02, 2020 7:55 am
Here you can watch back the presentation of the new modules from Joranalogue at Dutch Modular Fest
joranalogue
Post by joranalogue » Tue Nov 17, 2020 11:09 am
Morph 4 releases worldwide on 2020-12-08. We're hard at work, preparing the units for shipping throughout the dealer network. Get those pre-orders ready, initial stock will be limited!
