Verbos vs Moog Oscillators?
Joonathan
Post by Joonathan » Tue Sep 15, 2020 12:16 am
Can someone with knowledge of both, describe to me the difference in sound, between something like a Verbos Foundation Oscillator, and something like the Moog Grandmother oscillators? Might be others from either side, but I'm curious about those two in particular. And I'm talking raw sound, not functionality.
Thank you ๐Ÿ‘
The Junglechrist
Re: Verbos vs Moog Oscillators?
Post by The Junglechrist » Tue Sep 15, 2020 12:29 am
I don't own the Foundation but it's base on the core of the Complex and Harmonic oscillator so I can compare with my Grandmother.
For me the Moog sound more bassy and "full".
I'll record a few waveform for you if you want.
Stazma The Junglechrist / Repeat Eater: http://stazmathejunglechrist.com/
Electric Voyage Studio [Mastering / Mixing] : http://electricvoyage-studio.com
My label Concrete Collage : https://concretecollage.bandcamp.com/
Wired Brain Video Channel : https://www.youtube.com/channel/UCh4pym ... vkKp6ofzVA
Joonathan
Post by Joonathan » Tue Sep 15, 2020 12:52 am
You are a true gentleman :) That would be lovely, if you have the time. Also, could you pick a favourite, if you had to, or is that entirely context-based?
The Junglechrist
Post by The Junglechrist » Tue Sep 15, 2020 1:48 am
Here you go :
https://soundcloud.com/stazma-the-jungl ... 7jSe6HOrir
Can't say I like one or the other more, totalmy different beasts. I'd say the Moog vco are very good in a Moog context as they are more fat and juicy so they work very well as pure raw sound generator, as well as food for filters.
The Verbos VCO (and any Buchla based complex VCOs I guess) are more little instruments by themself, so many sound can be obtained from the waveshaper out.
Joonathan
Post by Joonathan » Tue Sep 15, 2020 2:00 am
Thank you - can't wait to check the audio out, when I get of from work ๐Ÿ‘ And thanks for sharing your view as well. Greatly appreciated.
The Junglechrist
Post by The Junglechrist » Tue Sep 15, 2020 3:33 am
Joonathan wrote: โ†‘
Make sure you download the file and listen to the wavs instead of just stream it on Soundcloud ;-)
Joonathan
Post by Joonathan » Tue Sep 15, 2020 3:53 am
The Junglechrist wrote: โ†‘
Will do :) And will I be able to know which is which?
The Junglechrist
Post by The Junglechrist » Tue Sep 15, 2020 5:04 am
It noted on the waveform on soundcloud, just refer to the timing ;-)
Joonathan
Post by Joonathan » Tue Sep 15, 2020 12:41 pm
Thanks again - just had a listen on proper speakers. The difference is more subtle, than I would have thought, but I hear som interesting nuances in the Verbos. Might have to make a little room.. ;)
Black_Materia
Post by Black_Materia » Tue Sep 15, 2020 3:04 pm
Have you checked the sawtooth out on the harmonic oscillator? That is one full and beefy saw! more than the one in the Verbos Complex Osc. The interesting thing about the V.CO is in how delicate and sweet it sounds with high notes, and the organic, almost wooden character of it's crossmodulation. Though it can do plenty bass, and certainly isn't lacking in the sub region of the spectrum.
The Junglechrist
Post by The Junglechrist » Wed Sep 16, 2020 1:23 am
And I havn't played with to much knobs, or FM, or AM between the two. The Amplitude Modulation is probably the most interresting feature of this guy, especialy using the sync, so many weird timbres to get out of this. The weird bass line from 2.25 in this track is what i'm talking about :
Joonathan
Post by Joonathan » Wed Sep 16, 2020 1:29 am
Thanks for the video, will listen later ๐Ÿ‘ What is your experience regarding power for Verbos? I have some rather low quality cases, with switching power supplys, and from what I gather, Verbos might be sensitive to that?
StrangeAttraction
Post by StrangeAttraction » Wed Sep 16, 2020 3:21 am
That's a very cool bass line melody!
What's doing the 303 sound at 1:50?
The Junglechrist
Post by The Junglechrist » Wed Sep 16, 2020 11:38 am
StrangeAttraction wrote: โ†‘
The bassline at 1.50 if simply from my old Xoxbox ! There might be a bit of drive on it (probably the Elysia Karakter 500).
I never had problems with power with Verbos modules but I always used 4MS power suplies.
Return to โ€œEurorack Modulesโ€
