Mixer AND multitrack audio interface?
LDT
The Modu-Lars
Post by LDT » Sat Sep 19, 2020 4:06 am
I think the answer to the following question is no, but I just want to be 100% sure that I have not missed something.
Is there a module, that works as multitrack audio interface (for computer), but ALSO as a simple mixer? (Minimum requirements for mixer would be a volume knob pr channel. And minimum 8 channels.)
Agawell
Re: Mixer AND multitrack audio interface?
Post by Agawell » Sat Sep 19, 2020 4:38 am
I think the nearest you will come is the es9 plus something like this if you can work out how to setup the midi between them
edit added:
or you could just patch attenuators before the es9 maybe this
Instagram
Utility modules are the inexpensive, dull polish that makes the expensive, shiny modules actually shine!!!
an oscillator is an oscillator - utilities are possibilities
wavejumperr
Post by wavejumperr » Sat Sep 19, 2020 4:38 am
Does it have to be eurorack? There are a ton of options if you look for standalone units.
wigglers are a modular synth's way of making another modular synth
xntrk
Post by xntrk » Sat Sep 19, 2020 6:18 am
I agree with Agawell. The closest thing I can think of is es9. It doesn’t have faders on it. The es9 configuration software does have faders for mixing. You can also run it in standalone mode where it isn’t connected to a computer and mixes based on what you have previously configured. I have been using it as a headphone out for a while.
chaosick
Post by chaosick » Mon Sep 21, 2020 2:26 am
A MODULE? WTF?
What you want is a Tascam Model 24, 16, or 12. I have the 24, love it, got the 12 to try out while traveling, and really like it also, but think I'm going to sell it in a month when I return home fully and keep the Model 24. Totally changed the way I work, all/any of them.
Whatisvalis
Post by Whatisvalis » Mon Sep 21, 2020 7:01 am
I would look outside the rack. Sound Devices MixPre series - HP filter on each channel, pan, limiter - perhaps one of the Zoom boxes.
windchill
Post by windchill » Mon Sep 21, 2020 9:46 am
You might want to check out the K-Mix from Keith McMillen. It's not a module but still pretty compact. I've used one for a couple of years.
ima_jrk
Post by ima_jrk » Mon Sep 21, 2020 10:20 pm
No computer interface but a mixer module with direct outs would let you have your mix and multitrack it too. The Xaoc Praga, the Hexmix with expander, or the Performance mixer with the DB25 expander all come to mind. If you mean a strict in the rack device that does it all then probably not. An interface like the MOTU 8A will do what you want and it handles Eurorack levels with ease and can even be used as a CV interface if you desire.
LDT
The Modu-Lars
Post by LDT » Tue Sep 22, 2020 6:32 pm
Thanks everybody. There is no such module. No worries, case closed.
jkanizzle
Post by jkanizzle » Tue Sep 22, 2020 8:38 pm
Currently using the individual channel outs on my Befaco Hexmix/Hexpander to go into an ES6. That SORTA does the trick, although it doesn't capture the aux sends.
lavalamps
Post by lavalamps » Tue Sep 22, 2020 9:28 pm
The SSP actually might be able to do this.
Lokua
Post by Lokua » Tue Sep 22, 2020 9:45 pm
I've been considering one for this exact purpose. If comparing to audio interfaces alone with that many channels it's actually not that bad price wise for 16 ins.
Edit: and recently someone named thetechnobear made a performance mixer vst for it: https://forum.percussa.com/t/pmix-perfo ... nobear/990
LDT
The Modu-Lars
Post by LDT » Sat Oct 17, 2020 8:14 am
Just an update: Meanwhile I have gotten a Faderfox EC4 for controlling FH-2 stuff, and then I realised the other day, that there is a FW update coming, that gives you midi CC control over volume and pan for the 14 inputs on ES-9. So I just ordered an ES-9, which will become my only mixer in my euro system, and off course provide 14 channels into my macbook.
Only worry: I will be over-taxing my power supply a bit. ES-9 is one hungry module. 😮
Agawell
Post by Agawell » Sat Oct 17, 2020 9:59 am
good luck with that - probably time for a new psu and/or case then!!!
Instagram
LDT
The Modu-Lars
Post by LDT » Sun Oct 18, 2020 3:04 am
The solution might be an additional psu. I actually have an endorphin.es 2hp power module that I was going to sell, but that might come in handy for providing power for the ES-9.
Agawell
Post by Agawell » Sun Oct 18, 2020 7:30 am
sounds like a plan
Instagram
Raindeer
Post by Raindeer » Sun Oct 18, 2020 11:08 am
Everyone saying it’s a lot to ask for in one module, but honestly I’m surprised this doesn’t exist. It would just be a eurorack version of something quite ubiquitous - at its simplest a normal mixer with USB out.
Lokua
Post by Lokua » Sun Oct 18, 2020 2:48 pm
Or you can use a standalone MIDI controller in place of the in-rack MIDI controller. I think the firmware on ES-9 to support this is in beta right now.
Edit: those would run around $800-$1000
cackland
Post by cackland » Sun Oct 18, 2020 2:52 pm
I posed this question / concept to intellijel a while ago... doubt anything would come from it. So I’m designing and building my own
Flounderguts
Post by Flounderguts » Sun Oct 18, 2020 11:04 pm
:yay: :sb: :party:
Flounderguts
Raindeer
Post by Raindeer » Mon Oct 19, 2020 3:17 am
Excellent! Well, if you’re taking requests I’m basically looking for an 8-channel Focusrite Clarrett in eurorack format... in 8hp :-)
cackland
Post by cackland » Mon Oct 19, 2020 3:23 am
This was the original idea posted a while ago on Intellijel forum.. I was thinking 1U format. Original was thunderbolt connection, but now thinking standard USB. 8 Channels works fine over USB.
The idea is that these 8 channels could be selectable inside your DAW of choice, or I could definitely add some configuration buttons on the panel for sub mixes. It was all a thought, however might consider this more of a serious solution for some.
Maybe a 4 hp 3U config... 8 Channels, USB, buttons. All ideas atm.
xcc
Post by xcc » Mon Oct 19, 2020 6:09 am
This would be fantastic. I’d love an ADAT version as well. Maybe a mult expander to send a copy to the DAW while keeping everything in the rack the same could be cool.
