BaxandallEQ from Konstant Lab
Electro Something
Post by Electro Something » Wed Oct 14, 2020 1:32 pm
Just saw that Konstant Lab posted their first demo of their BaxandallEQ.
Shipping worldwide now for 139e.
https://www.konstantlab.audio/shop/baxandalleq/
It was never easier to treat your mono-stereo system or external instruments, whole mixes with a touch of this precision equalizer that allows you to dial in any sound from 1950’s onwards. Our design is based on the fairly popular and now famous work of renowned electronics designer Peter Baxandall who designed one of the world’s most popular EQ curves to date. Why are they so popular? They improve on any source signal you process-send through them.
Here at Konstant Lab we highly admire Peter Baxandall and his work so we decided to base our next module on one of his renowned circuits that stood the testament of time in various tour applications and studio rigs all around the world and make it available for the eurorack modular format, while also improving upon its premise and foundation.
BaxandallEQ is a 3-Band EQ equalizer with two individual channels on board. Gain of each of its bands (bass - middle -treble) features a ±15dB range. Both of the featured channels can be used independently (stereo) with individual gain for each band or as a one big massive single channel with staggering ± 30dB of gain on each band. Internal routing of the circuit of the module is our modification based on the legendary EQ design from 1952.
This highly sought after EQ circuit is being used for well over 70 years for processing audio, mastering in many high-end studios as well as home studios and home radios all around the world. We took the original circuit and its bass - treble section and modified it to feature a defined and sound-rich middle range. Our premise was to deliver a convenient way how to treat your whole eurorack modular system with some precision EQ processing without compromising on sound, high-quality components, and materials. All analog signal path features only the best hand-selected condensers from WIMA and high-quality - low-noise opamps to deliver the best sound possible without any unwanted artifacts. The whole circuit and its components reside on one PCB which allowed us to keep high-quality - high-performance sound without increasing upon modules depth.
There is a switch on the back of the module that allows you to set the overall gain of the module – either 0dB or +6dB if desired.
BaxandallEQ offers you a broad range of applications for your modular system and external instruments alike. It pairs exceptionally well with our high-quality stereo mixer module PanoramaMIX and M2S (mono to stereo converter module).
It was never easier and more affordable to add a slight touch of precision, eliminate unwanted frequencies coming out from your eurorack modular patches, add raw analog power to bass drums, snares, claps, percussions, or glue whole mixes together. Simply feature BaxandallEQ in your signal path and watch the magic of sound reminiscent of the vintage era unfold right before you.
POWER:
+12V @16mA
-12V @16mA
Bass:
40Hz ±18dB
Middle:
800Hz ±16dB
Trebble:
11kHz ±15dB
FREQUENCY RANGE:
25 Hz – 30 kHz ± 1 dB
15 Hz – 50 kHz ± 3 dB
THD (Total Harmonic Distortion):
0,006 % 1 kHz, Output Level 0 dBm ( 0,775 Vrms )
SNR (Signal no Noise Ratio):
more that 95 dB BW 1MHz
Basic transfer gain:
0dB +6dB (switch on back)
MAX OUTPUT VOLTAGE:
6,5Vrms (more that18Vpp)
WIDE:
4HP
DEPTH:
25mm
ACCESSORIES:
2 screws
2 plastic washers
power flat cable
pekbro
Re: BaxandallEQ from Konstant Lab
Post by pekbro » Wed Oct 14, 2020 5:35 pm
Definitely interested in picking up one of these.
dmod
Post by dmod » Thu Oct 15, 2020 12:13 am
Hmmm. Love me some EQ but never thought of this type in this format before. Interesting...
Electro Something
Post by Electro Something » Thu Oct 15, 2020 1:27 pm
Yah I'm trying to decide between this and the Serge ResonantEQ for like $250 USD more. Doesn't seem to be too many analog stereo EQ's out there.
mojopin
Post by mojopin » Thu Oct 15, 2020 1:33 pm
The Serge is mono with multiple inputs.
pekbro
Post by pekbro » Thu Oct 15, 2020 6:01 pm
The Baxandall is kind of a tone stack right? The Serge and this should compliment each other well I would think.
Electro Something
Post by Electro Something » Thu Oct 15, 2020 6:49 pm
Oh you couldn't create a stereo pair this way?
mojopin
Post by mojopin » Thu Oct 15, 2020 8:45 pm
Stereo pair would need two units. What you can do is get a pseudo-stereo output from a mono source using the comb outs.
mnchrme
Post by mnchrme » Fri Oct 16, 2020 8:10 am
Hey guys. We were about to announce this and PanoramaMIX soon, haha. I have the module and been testing/using it for couple months now. I like it. It’s quite small, the sound and available gain is good... sound wise very precise... you can push it to very warm territory if you’d like. The thing I love the most about it is the stereo option though. Lovely to process all kinds of stereo things through it. :guinness:
mnchrme
Post by mnchrme » Fri Oct 16, 2020 12:34 pm
Yeah kind of. I’d say they would compliment each other quite well. I was using it mostly to pump up some sources or to run my Juno through a signal chain featuring this on the stereo fx in my modular. It comes quite handy when you have a final mix in your modular and you want to smooth up the edges here and there or to alter the timbre of certain sounds.
Electro Something
Post by Electro Something » Fri Oct 16, 2020 5:41 pm
More demos, please!
mnchrme
Post by mnchrme » Fri Oct 16, 2020 7:16 pm
More demos, please!
What kind of demo would you like? We can check certain aspects which are of interest. :guinness:
