Breaks
wetrawlmhz
Breaks
Post by wetrawlmhz » Fri Oct 16, 2020 3:37 am
Hi,
Which modules are you folks using to create breaks?
I don't mean 4 to the floor kicks but snares, cymbols and kicks or alternative sounds to create breaks.
I know random modules can be used to spurt out stuff which can then be edited.
I'm interested in the conscious placement of sounds to build the beats.
Is this even possible in the euro rack world?
ronnieb
Re: Breaks
Post by ronnieb » Fri Oct 16, 2020 4:44 am
Have a look into cue sets on the Squid Salmple. The erica synths sample drum does a similar thing too
R.U.Nuts
Re: Breaks
Post by R.U.Nuts » Fri Oct 16, 2020 5:15 am
What are you looking for? A sequencer that can be used for that kind of complex beats? Drum modules? Samplers that can chop up a drum loop? All of them?
cinnatoastg
Re: Breaks
Post by cinnatoastg » Fri Oct 16, 2020 6:47 am
I haven't gotten super deep into mine, but the sampledrum isn't the most intentional way to chop breaks. You can chop them up, but as for moving through them I think your only options are forward, backward, and random. As opposed to being controlled over CV.
jkanizzle
Re: Breaks
Post by jkanizzle » Fri Oct 16, 2020 12:33 pm
scragz
Re: Breaks
Post by scragz » Fri Oct 16, 2020 1:47 pm
Bitbox is good for chopping samples and then sequencing the slices.
adg672
Re: Breaks
Post by adg672 » Fri Oct 16, 2020 2:18 pm
Zones on the assimil8tor
brandonlogic
Re: Breaks
Post by brandonlogic » Fri Oct 16, 2020 2:27 pm
Nerdseq + er301 :sb:
adg672
Re: Breaks
Post by adg672 » Fri Oct 16, 2020 2:32 pm
Dude, I’d talked myself out of a 301. You’re not helping ;)
Re: Breaks
Post by ignatius » Fri Oct 16, 2020 2:40 pm
^^this.
also, sequential switches, malekko varigate8, winter modular eloquencer.
edit: this is assimil8or and zone switching. sequenced by varigate8.
wetrawlmhz
Re: Breaks
Post by wetrawlmhz » Fri Oct 16, 2020 3:12 pm
Hi Everyone,
Thanks for sharing. Much appreciated. Yes, after doing the resarch i'm now waiting on an Assimil8or and Eloquencer together with a switch and Logic module. Which would you say is better at swing, Pamela's or the Eowave Swing?
wetrawlmhz
Re: Breaks
Post by wetrawlmhz » Fri Oct 16, 2020 3:14 pm
^^this.
Fantastic! Could Marbles do what the Noise Engineering module is doing?
wetrawlmhz
Re: Breaks
Post by wetrawlmhz » Fri Oct 16, 2020 3:19 pm
Wow, these look serious. Thanks.
wetrawlmhz
Re: Breaks
Post by wetrawlmhz » Fri Oct 16, 2020 3:20 pm
I'm going for the Assimil8or and Eloquencer.
wetrawlmhz
Re: Breaks
Post by wetrawlmhz » Fri Oct 16, 2020 3:21 pm
Yes, the Squid looks really fun to play with. I just can't get with the sound of it. Thank you for the tip.
wetrawlmhz
Re: Breaks
Post by wetrawlmhz » Fri Oct 16, 2020 3:23 pm
Thanks. Haven't seen this one.
wetrawlmhz
Re: Breaks
Okay thanks.
Re: Breaks
Post by ignatius » Fri Oct 16, 2020 7:51 pm
^^this.
thanks. i have no idea. i'm not familiar with marbles. i had 2 sets of patterns going into the NE module and then it was getting switched and blended between the 2 sets of patterns.
daphnid
Re: Breaks
Post by daphnid » Fri Oct 16, 2020 8:23 pm
I mean, you can make a breakbeat with any generic drum modules and a straightforward trig sequencer. Traditionally, break oriented dance music uses samples rather than analog drum sounds.
If you want to chop breakbeat loops ala jungle music it would massively behoove you to get a sample player that does time stretch, which there are shockingly few of in eurorack seeing as how it's been standard feature of any sampler made since like 1990.
The 1010 Bitbox is one of the few that does it. Assimil8tor, Squid Sample, and Sample Drum do not.
kingmaxwell
Re: Breaks
Post by kingmaxwell » Fri Oct 16, 2020 10:20 pm
Grids is one of the most straightforward break representations in eurorack.
kmro.org
Kattefjaes
Re: Breaks
Post by Kattefjaes » Sat Oct 17, 2020 6:18 pm
If you chop breaks up into slices, the Disting EX is quite nice for mapping them chromatically over a 1v/octave range so you can play them with a sequencer/arpeggiator etc.
jebusrice
Re: Breaks
Post by jebusrice » Sat Oct 17, 2020 6:21 pm
As a multisample? Single mode or dual?
Kattefjaes
Re: Breaks
Post by Kattefjaes » Sat Oct 17, 2020 6:23 pm
The above was using SD Multisample mode. Stick them all on one channel and they choke each other for free, too.
jebusrice
Re: Breaks
Post by jebusrice » Sat Oct 17, 2020 6:31 pm
Brilliant. Hadn't thought of using it that way! Thanks :)
StrangeAttraction
Re: Breaks
Post by StrangeAttraction » Sun Oct 18, 2020 11:31 am
Can you elaborate as to what about its sound you don't gel with? cheers
