Arturia Keystep: CV, USB and Clock-Connection
OctaState
Post by OctaState » Fri Oct 16, 2020 10:08 am
First poster, Eurorack-Newbie here :-)
I'm looking for a future proof possibility to connect my Computer/Ableton/MIDI-Masterkeyboard with my Modular-system via USB.
I know there are a few Interfaces like the Intellijel, Doepfer etc. with USB-capability. But I also want a clock output, which the Doepfer doesn't offer, the Intellijel is much more expensive.
After a little research I found the pricewise pretty attractive Arturia Keystep. The Arturia manual is quite inaccurate...
Is it possible to cover all theses fields (CV, USB, Clock) by a Keystep?
So that I can connect the keystep to the modular (CVs and Sync-Outs) and the Computer (USB), have clocking from Ableton via keystep to the modular and can play modular-sounds also with other MIDI-Keyboards (which are connected and configured in Ableton) via Keystep CV-Outs?
Any help is appreciated!
OctaState
Raindeer
Re: Arturia Keystep: CV, USB and Clock-Connection
Post by Raindeer » Fri Oct 16, 2020 10:36 am
OctaState
I can’t say that this is future-proofed. It totally depends which direction you go in with your other gear. But yes this will totally work and the Keystep is very popular with Eurorack owners!
Just select USB slave on the rear panel switches and then it can sync to Ableton. From there the Keystep sequencer, and arpeggiator will stay in time and ‘sync out’ works as a clock source.
And yes, you can also ‘play’ the Keystep from Ableton via USB through CV/Gate and the Midi Out (which can be configured as Midi Thru) For the latter you can get more than one voice but would need a Midi-to-CV module with multiple CV/Gates.
Or just use the Keystep itself as your sequencer. It’s pretty damn good.
R.U.Nuts
Post by R.U.Nuts » Fri Oct 16, 2020 10:39 am
The Keystep only sends clock when it's sequencer or arpeggiator is running. Also it has no reset trigger output if you need to reset your sequencers to the first step when you stop the playback on your DAW.
Long story short: Keystep is usable as a MIDI/clock convertor but not the best solution.
Better go with a Beatstep Pro.
Raindeer
Post by Raindeer » Fri Oct 16, 2020 10:46 am
Yes that’s true. Sync out runs with the sequencer but Keystep continually outputs Midi Clock.
Hovmod
Post by Hovmod » Fri Oct 16, 2020 10:59 am
The Keystep only sends clock when it's sequencer or arpeggiator is running. Also it has no reset trigger output if you need to reset your sequencers (...)
I had a Keystep, and found that I could work around the first issue, but not the second.
I upgraded to Keystep Pro, which has a reset output, but I'm still using the workaround from earlier (MIDI clock master to the Keystep is split and also runs to a Ladik M-220 module) to have a clock in the rack even if the KSP isn't running. If I'm using the KSP as a master and don't have the Ladik patched in, I just let the KSP run and mute tracks, which does not stop the clock output.
I really like the KSP, but it's very much bigger and way more expensive than the Keystep, of course.
OctaState
Post by OctaState » Sat Oct 17, 2020 12:45 pm
Thanks for your inputs!
