Which Joystick brings you joy?
nicholasponcedeleon
Re: Which Joystick brings you joy?
Post by nicholasponcedeleon » Sun Nov 15, 2020 4:43 pm
Blue lantern modules - mini FM Joystick V2
Only 6hp and $95 and it does everything I want
mixxalot
Post by mixxalot » Sun Nov 15, 2020 4:54 pm
Haha well there ya go two modules that would be unique right?
My music:
https://soundcloud.com/modben
My modular setup (always work in progress)
https://www.modulargrid.net/e/racks/view/1391380
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Mon Nov 16, 2020 1:06 pm
If the "snap back to 0V" feature is important to you, there are other controllers that will do this easily. Doepfer and Analogue Systems make pitch-bend and mod wheel modules, there are plenty of touch strip type modules that can do this (though most s/h the last position), and there are FSR (Force Sensing Resistor) modules out there too (*self interest alert* - I make a couple of FSR based modules). Everyone should have a bunch of controllers in their rigs.
-James
Cpaf
Post by Cpaf » Mon Nov 16, 2020 2:07 pm
Just so it's clear: If you record Planar2 with the joystick in the middle/at zero and let it play, pause it, wiggle away, with the stick and when you're done and want to "snap back to zero" you simply press play again. Remember to have the ABCD/XY buttons lit and nothing patched to the CV 1 or 2 (then the recording of "zero" will be routed to the output instead of the joystick position).
Alternatively you could also just unlit the ABCD/XY button with nothing patched to the cv 1 or 2in as Planar2 then sends a static zero volt out.
Of course it doesn't move the joystick mechanically if you really need that.
daphnid
Post by daphnid » Mon Nov 16, 2020 2:57 pm
I have the erica black joystick, with no spring. I use it mostly as a playable cv mixing attenuverter, which I guess is what it is. I feel like having a spring in it would make it a more unique module and really expressive/playable, but maybe a bit more limited as well.
adaris
Post by adaris » Mon Nov 16, 2020 3:44 pm
I agree with this wholeheartedly.
Bubbles
Post by Bubbles » Mon Nov 16, 2020 7:19 pm
Too funny Trickness!!!
Bubbles
Post by Bubbles » Mon Nov 16, 2020 7:27 pm
dip_registered wrote:
Sat Nov 14, 2020 10:48 pm
Bubbles wrote:
Thu Nov 05, 2020 11:07 am
Overwhelmingly, wrigglers seem to prefer “stays put”. I’m surprised. I’m looking at the Flame JoyRec because I want fast triggers (on X coord) and modulation (on Y coord), then a quick return to zero.
Also like the CV recording option much.
Yep, cv recording on the flame is awesome. Not to mention looping, restarting etc. I wanted a planar so bad but it was too big for my rack, but now I’m really happy I went for the flame.
Thanks for your 2 cents. I was hoping someone would chime in about the FLAME JOYREC.
trickness
Post by trickness » Mon Nov 16, 2020 9:20 pm
Thanks! I’m here all week :hihi:
tdallas
Post by tdallas » Wed Nov 18, 2020 6:40 am
The Doepfer A-174-4 seems to be available now (at least the black one) -> A-174-4@Thomann
But it is quite huge ... 50 mm deep and the stick is 70 mm high :deadbanana:
studio460
Post by studio460 » Wed Nov 25, 2020 11:15 pm
Rex Coil 7 wrote:
Sat Nov 14, 2020 1:11 pm
. . . I'm too damned lazy today to shoot a picture so I'll just go with the current accepted status quo of posting a Modular Grid "rack" of all my bitchin shit ... cuz I'm a bitchin kinda guy ... with bitchin shit.
Since you're such a bitchin' guy maybe you can help! I was all set to buy two Planar² joysticks, and then I discovered (the much cheaper) Lightplane. What to do? I bought a bitchin' 4ms pod64x explicitly to make a control-skiff to house, originally, two Planar² joysticks and a Tetrapad, quite an expensive proposition. But then, Lightplane to the rescue! I'm primarily making machine-noises, spaceship-engines, and robot-voices, if that helps. I'll re-read your post and try to absorb the pros and cons again, but my mind is swirling . . . Planar² or Lightplane???
Post by dubonaire » Thu Nov 26, 2020 1:32 am
I couldn't really understand the reason for such a large joystick until I watched the videos.
studio460
Post by studio460 » Thu Nov 26, 2020 1:33 am
Hmmm . . . the Doepfer looks dope!
Neither
Post by Neither » Thu Nov 26, 2020 1:45 am
I bet the Doepfer A-174-4 will be awesome with Wrong Vector Space X, Y, & Z inputs :goo:
Sound design for Cabinet of Dr. Caligari:
https://youtube.com/watch?v=4UuWKfwALVs
Post by dubonaire » Thu Nov 26, 2020 1:49 am
:zen:
blaythe.steuer
Post by blaythe.steuer » Thu Nov 26, 2020 2:10 am
i believe there’s a new erica one with recording features
i really want the new doepfer one... in black :) looks like it would be a huge modulation source and a potential heart of a system
KSS
Post by KSS » Thu Nov 26, 2020 2:17 am
I didn't watch this video but it sure looks like it isn't going to work very well -if at all- with those modules on either side of it actually patched.
The hand position seen in the vids preview photo would be impossible if the jacks under it were patched.
edit typo
freakynorth
Withered Gardener
Post by freakynorth » Thu Nov 26, 2020 2:21 am
I was talking with Karl from Knas / Ekdahl and he’s looking for a new spot to get joysticks for the Quad Massager.. (which I want to buy!!) haha.
WANT TO BUY:
Bugbrand - CTL-1, Spring Tanker
Bugbrand/Scrotum Lab - Le Seq, Le Seq Expander, Radio Music, Tresses
KSS
Post by KSS » Thu Nov 26, 2020 2:35 am
Earlier in the thread the corners unavailable to a circular travel JS were brought up.
Is there any value to have a clipping function to turn the circle of this kind of stick into the square available with the type Rex Coil 7 posted <--in the dotcom panel?
One could move the stick in a circle and the output would be 'square'.
Post by dubonaire » Thu Nov 26, 2020 6:40 am
The hand position seem in the vids preview photo would be impossible if the jacks under it were patched.
Huh?
Cpaf
Post by Cpaf » Thu Nov 26, 2020 10:39 am
Planar2 is awesome but personally I wouldn't by two of them. I'd rather go for a tetrapad (+tete maybe) or the new Erica Black Joystick2 (which looks like an awesome second joystick to compliment Planar2). The Doepfer has some really nice tricks but I would rather have an Expressive E Touche on the side instead. The Doepfer looks platicky and too big when everything is patched up
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Thu Nov 26, 2020 2:45 pm
This is my current current controller skiff. I have both a Planar2 and a Choices in it. I have be thinking moving the FOH Power module and making a larger version of the Trunk-16 module in the 2" space above the rows. If I do that then that panel space opens up I may add a second Planar2, but a light plane or other controller would be nice for variation. Having a collection of different controllers often stirs creativity in me, so the more the merrier.
-James
monads
Post by monads » Sat Dec 05, 2020 2:34 am
When's Planar2 gonna be available again? The Doepfer A-174-4V looks nice, should even barely fit in a 4ms Pod--X case.
finalplane
Post by finalplane » Sat Dec 05, 2020 9:30 am
I think Analogue Haven has a Planar 1 on sale still if you want to go that route
whipcreamsfruitquartet.bandcamp.com
Electro Something
Post by Electro Something » Sun Apr 04, 2021 11:48 pm
Is the Planar2 worth the extra $140 from the Doepfer A-174-4V? Trying to decide between the two.
Does it all come down to whether or not you want a spring in your joystick?
