Which Joystick brings you joy?
KSS
Re: Which Joystick brings you joy?
Post by KSS » Mon Apr 05, 2021 1:57 am
Doesn't the planar2 include CV recording?
Cpaf
Post by Cpaf » Mon Apr 05, 2021 2:08 am
Yes, and in both x and y or circular speed and width depending on the mode :) you can also record audio modulation in and use it as a crude "wavetable" oscillator
megarat
Post by megarat » Mon Apr 05, 2021 10:18 am
Electro Something wrote:
Sun Apr 04, 2021 11:48 pm
Is the Planar2 worth the extra $140 from the Doepfer A-174-4V? Trying to decide between the two.
Does it all come down to whether or not you want a spring in your joystick?
The A-174-4 has some extra features not found in the Planar 2, most specifically it outputs a third dimension of CV, which is generated by rotating the joystick. It also uses pots to generate an offset for each dimension, as opposed to the Planar 2’s bipolar/unipolar switches, so you can have some finer control if you prefer.
I also understand that the A-174-4 is still unreleased, and given the current global shortage of electronic components, I expect it won’t be available anytime soon. Also, I wouldn’t rule out the possibility that they change the specifications on the finished product. Its original release date was last summer or thereabouts, and they delayed it to change some of its features based on user feedback, so its feature set may still be in flux.
studio460
Post by studio460 » Mon Apr 05, 2021 10:40 am
They actually hit dealers' shelves a couple months ago. I bought two A-174-4Vs about a week apart from the initial shipment. Now they're sold out everywhere again. Yeah—you get Z-axis control by rotating the stick—that's the feature which made me decide to pull the trigger on the Doepfers. They're very deep (and very tall!), but do fit into a 4ms pod64x powered-skiff, just barely (just make sure you get the 'X' pod). I love 'em!
Post by exper » Mon Apr 05, 2021 10:43 am
It’s definitely worth the extra. XY recording, joystick stays where you leave it, really versatile VCA options for panning, distribution, scanning, etc.
Electro Something
Post by Electro Something » Mon Apr 05, 2021 11:14 am
Detroit Modular has the Doepfer joystick in stock. 10% code still working: stpatty10
studio460
Post by studio460 » Mon Apr 05, 2021 11:20 am
Yes, in silver. "Vintage" (black-panel) is still out-of-stock. Looks wicked-cool in black!
adaris
Post by adaris » Mon Apr 05, 2021 11:27 am
I actually just ordered the vintage version of the Doepfer from Nightlife in Canada last week. Looks like they still have it in stock if anyone is looking.
sellanraa
Post by sellanraa » Mon Apr 05, 2021 11:37 am
Does the Doepfer 'knob' of the joystick unscrew or anything to allow for being put into travel cases? It seems so huge and it doesn't seem like they could work in any cases with a lid, but that also seems weird that they wouldn't have planned for some solution given how many people travel with their cases for live performance.
klstay
Post by klstay » Mon Apr 05, 2021 11:45 am
Good to see the Doepfer fits in that case. I really like the inverted outs right on the module. I plan to have a pair of triple attenuators nearby as well. I wish they had put four holes on the faceplate for mounting though.
Just used the code at Detroit to pick one up.
ferran
Post by ferran » Mon Apr 05, 2021 12:18 pm
deleted
ferran
Post by ferran » Mon Apr 05, 2021 12:30 pm
Bubbles wrote:
Thu Nov 05, 2020 11:07 am
Overwhelmingly, wrigglers seem to prefer “stays put”. I’m surprised. I’m looking at the Flame JoyRec because I want fast triggers (on X coord) and modulation (on Y coord), then a quick return to zero.
Well, I do not own a joystick, so this creates interesting doubts about this question.
mixxalot
Post by mixxalot » Mon Apr 05, 2021 12:44 pm
I have a Befaco joystick which is ok but want a Planar 2 that is super awesome! Probably after I get my monster case and move things around and at the next sale the planar 2 will be a must buy for me. Used one at friends' place and had so much fun using it.
My music:
https://soundcloud.com/modben
My modular setup (always work in progress)
https://www.modulargrid.net/e/racks/view/1391380
ferran
Post by ferran » Mon Apr 05, 2021 12:57 pm
Intellijel = Absolute quality guarantee.
Multi Grooves
Post by Multi Grooves » Thu Apr 08, 2021 11:08 am
NeolithicElectrophones wrote:
Wed Nov 04, 2020 8:23 pm
Jumbuktu wrote:
Wed Nov 04, 2020 8:15 pm
Wed Nov 04, 2020 7:08 pm
Absolutely prefer no spring in mine. But i'll take a spring return to center stick over a stick that slowly moves down if it's at a 45 degree or larger angle.
As I get further past age 65, this sounds so familiar.
Can't say Iv'e tried it yet, but a friend told me that in case of no spring, a plug in the bottom jack helps keep the joystick at center.
Lol...you guyz are talking cocks!
In other news I also do not own a joystick either so this thread comes at a perfect time! Aside from contemplation of the latest complex oscillator du jour, I'm pretty much one in, one out. But other day it dawned on me that I could do with a small case with a stick, deffo want a lightplane, manual switches (latching and otherwise) to add something organic to the deep programming I'll be doing.
Last edited by Multi Grooves on Thu Apr 08, 2021 11:49 am, edited 1 time in total.
...but Cynthia, my Daddy never had a heath kit..
FS: SSF Entity
Multi Grooves
Post by Multi Grooves » Thu Apr 08, 2021 11:16 am
LunaticSound wrote:
Fri Nov 13, 2020 5:58 pm
Geometry on a sphere is hard.
Geodesics?
FS: SSF Entity
LunaticSound
Post by LunaticSound » Thu Apr 08, 2021 1:50 pm
Geodesics?
Sounds hard.
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Thu Apr 08, 2021 2:45 pm
A Joystick with a spring return can always be patched into a Track-and-hold module (many sample and hold modules can be jumpers into track and hold) and the current position held by them. of course they will "jump" to the new location when you want to change things.
-James
klstay
Post by klstay » Thu Apr 08, 2021 3:17 pm
Indeed, once the Doepfer gets here (tracking indicates Monday) I plan to regularly patch it through a select 2.
brandonlogic
Post by brandonlogic » Thu Apr 08, 2021 3:30 pm
edit double post.
brandonlogic
Post by brandonlogic » Thu Apr 08, 2021 3:31 pm
The Planar 2 is hard to beat. it's really the perfect joystick module IMO. I love mine. woulnt change anything about it.
oh man, im going to have two brush up on the manual!
