Introducing Maestro - 6 channel clocked modulation controller from Acid Rain Technology
nelasma
Re: Introducing Maestro - 6 channel clocked modulation controller from Acid Rain Technology
Post by nelasma » Thu Apr 08, 2021 12:45 am
Ok, thanks for giving me the bigger picture! ;)
Still wondering if it would be possible to record those waveform/division changes in realtime? Let me show you on a snippet of my jams what I mean. At the beginning in this clip I play a gated reverb and actively change the divisions on maestro:
Now if Maestro could record those division changes and play them back afterwards that would be some huge game changer.. at least for me.. :hail:
auditorycanvas
Post by auditorycanvas » Fri Apr 09, 2021 3:55 am
Not sure if it's what you're after, but you can set the clock division of each step in a chain.
nelasma
Post by nelasma » Fri Apr 09, 2021 4:49 am
I know that, but if I would have to add each segment on its own in such a long chain with small segments... I wouldn't do that in a live jam. Sure I could prepare those chains in advance but as I am listening and deciding in the moment I don't really like to do that either.
I got a clock, I got a reset and a finite amount of segments..In my "coding brain" I could imagine that feature being possible. But I'm not sure how the module or the backend is setup..
So again... rather than putting each segment there by a button press I'd love an alternative like a latch function (if thats the right word). Would be huge. I hope I could get the point across, but maybe I need to expand on that :cloud:
nelasma
Post by nelasma » Fri Apr 09, 2021 4:58 am
Example: A chain of only 1/16 pulses is playing. Reset is coming in on each bar.
While its playing I play around with divisions on this chain without going into the chain mode to put each segment there.
Segments get replaced with new segments divisions resulting in a chain like: 1/4, 1/8, 1/8, 1/16,1/16 ,1/16 ,1/16 ,1/4
If its not possible with maestro thats ok and I would have to look on at some point, just saying this would be awesome.
It's a really good module as it is but this would just be awesome, especially for long and fast chains and in general live performances.
DJ Tap Water
Post by DJ Tap Water » Sat Apr 10, 2021 1:41 am
Looks great. Also, if this had more outputs, more buttons, a screen, a data encoder and could do everything pams does, it would be the fully fledged euro sequencer I've been waiting for. I would really like a big sequencer where you can't enter notes individually and you are working more with looped random and macro sculpting...
moo_lefty
Post by moo_lefty » Sat Apr 10, 2021 2:21 am
Sounds like this could be easily achieved by feeding a signal from a clock divider into the clock input of maestro?
nelasma
Post by nelasma » Sat Apr 10, 2021 3:48 am
No it wouldn't be the same since the envelopes or gates would all have the same length in this case. (still like 1/16 divisions if we're talking about my example)
Also in my example I was just talking about divisions.. same thing should also apply to segment waveform and any other parameter you can normally set when building a chain.
nelasma
Post by nelasma » Sat Apr 10, 2021 3:57 am
I can't here your voice but I get the feeling that you're being sarcastic ;)
Anyway, if I take this seriously: Sizewise its perfect and in my case I wouldn't wish for more than that realtime overwriting of segments. Don't need a screen, don't need a data encoder, don't need excessive menu diving.
Why dont you use lfos/quantizers and turing machines in this case? :mrgreen:
DJ Tap Water
Post by DJ Tap Water » Sat Apr 10, 2021 12:14 pm
Not being sarcastic at all.. I really love marbles and I wish it was a fully fledged black box sequencer.. And ya i do use quantisers.. Love em. One of the best things about eurorack for me
Stice
Post by Stice » Sat Apr 10, 2021 12:16 pm
So you’d like it to be an entirely different module?
nelasma
Post by nelasma » Sat Apr 10, 2021 12:30 pm
I dont see why an alternative segment recording makes it entirely different but anyway.
I was asking if that would be possible as I think it would make Meastro one killer controller.
If no one can see the merits of that, maybe its just me and if you know a module which can do this, I'd be glad if you could point me in the right direction ;)
klstay
Post by klstay » Sat Apr 10, 2021 1:27 pm
I may have stated this earlier and am simply WAY too lazy to look. The only additional feature I personally would like is a per track toggle between trigger in for chain advance OR single trigger in for the whole chain. If that is not feasible Maestro will still be phenomenal.
