First impression: Great intuitive rhythmic 6 channel modulator/LFO, that can sequence complex patterns with the given 8 simple waveforms: Saw Up, Saw Down, Triangle, Inverted Triangle, Random, Fixed High and Fixed Low.
One simple example I tried to work out for my current patch:
I've got a repetitive pattern where I modulate the filter resonance and the amp decay time with Maestro. I started to find the basic "right" timing and waveform. It was easy with Chain to introduce "randomness" by adding fixed voltages (waveforms Low and High on the Maestro).
Basic settings were a chain with SawUp 3 beats, then SawDown 3 beats. I added 3 beats Fixed Low (0V) to the resonance (LFO1) at the end of the chain giving it a "rest". And for the decay (LFO2) I added 1 bar High (5V) in between SawUp and SawDown creating a "sustain" and then 9 beats Low (0V) at the end for a longer rest before it restarts. That will take you no time to program as soon as you know what you want. I think sequencing waveforms with different time divisions is unbeatable easy on Maestro. On the other hand you need some brain power for longer sequences (chains), that have a lot of different patterns with various time divisions while looping for example exactly 16 bars.
One thing I noticed is that the Maestro LEDs don't show voltage values, especially the negative values. See the video in the link below:
I set LFO3 to triangle bipolar synced to 1 bar and plugged in a Division6 LED-jack that shows the voltage. While the Maestro output state LED goes up and down within 1 bar, the LED on the output jack goes red (positive voltage) and blue (negative voltage) within that 1 bar. It's just a minor thing, that confused me here and there.
Overall I had a lot of fun with it until now. I realised how much I missed synced modulation in my modular setup, where you can sequence waveforms. And it's so easy to program. Most of the time I don't need complex or morphing waveforms like other modules can give you, though you can chain some complexity of course. And all of that for 6 (!!!) channels.
https://imgur.com/qlHOr9t
