Trigger input voltage tolerance on external drum modules
akavalve
Post by akavalve » Wed Jan 13, 2021 3:34 pm
I've got a Pearl Drum X sitting around that I thought I'd try triggering from euro.
Anyone have a rule of thumb for safe input voltages on drum brain input circuits?
Wondering if I need to pad or current limit.
akavalve
Re: Trigger input voltage tolerance on external drum modules
Post by akavalve » Wed Jan 13, 2021 7:07 pm
Found a schematic online for the Drum X specifically.
Looks like +/-8 volt rails and the trigger feeds the opamp input directly, so probably a bad idea to do this without attenuation or protection.
Not sure about other drum brains with trig ins in general.
modeleus
Post by modeleus » Thu Jan 14, 2021 7:44 am
Usually all Digital Trigger should have a response in the 5V range. The op-amp input may have a tolerance of +-0.5V above Vcc and below -Vcc but if your machine is 8V a modular trigger of 10V may damage it.
Many Trigger input circuit designs have some kind of protection diodes for this purpose but usually you can´t take the chance. If you have an attenuator for this purpose use it.
