ALM - Jumble Henge
ALM - Jumble Henge
New from ALM and Worng - looks super interesting!
8 HP
Link: https://busycircuits.com/alm029/
Manual: https://busycircuits.com/docs/alm029-manual.pdf
The Jumble Henge is a 16 input stereo spectral mixer with a unique patch-based mixing interface in a compact space.
Each input has a carefully tuned resonant analog filter and a unique fixed pan value, providing each sound its own space within the mix. There is a Mix control to adjust the depth of the filtering and a clean external stereo input for chaining with another mixer or extra sound source.
Jumble Henge is a space efficient solution for creating rich stereo mixes from a number of both mono and stereo sources, working great in a compact live system or more creatively explored in the studio. Mix down entire patches, sum stereo effect returns or create a complex feedback network all with an intuitive, musically focused approach.
Jumble Henge was designed in collaboration with Worng Electronics and is based on their existing larger and more featured ‘SoundStage’ module. We appreciated the inspiration from the SP1200’s mixer section and how it nicely relates to the Squid Salmple’s output arrangement.
8 HP
- deftinwulf
- Veteran Wiggler
Re: ALM - Jumble Henge
Very interesting. I love the aesthetic, though I'm not really too certain how this module is different from SoundStage aside from having 14 "stereo field" patch points as opposed to SoundStage's 21. Looking forward to hearing audio demos, especially since I'm looking for ways to "stereoize" mono signals at literally this exact moment.
What is lost on the Jumble Henge compared to how the original idea was implemented by worng? There's no cv control over mix on either, right?
Feel free to use my old samplepacks: https://freesound.org/people/altemark/
- blinosynth
- Veteran Wiggler
the cvs on soundstage were pretty awesome, i dont get why the took it away in the new design...
is cheaper ... ok
is cheaper ... ok
- Learning to Wiggle
Wonder if they’ll be a black panel option from Worng?
Tbh not sure how useful cv over eq depth really would be? More so over level... Yes more CV is always betterblinosynth wrote: ↑Fri Feb 05, 2021 8:08 amthe cvs on soundstage were pretty awesome, i dont get why the took it away in the new design...
is cheaper ... ok
I'm now thinking - could this be a good mixer solution? I'd need to pair it up with a set of VCAs with nice manual level controls. Does that exist? Something like a 6 or 8 VCA with sliders? Would be nice next to this.
- Veteran Wiggler
This is almost perfect. Mixing soft to loud per input is my favourite aspect of MTM Startup.
I was going to get Sound Stage, but now I have to consider this...
[bbvideo] [/bbvideo]
songs - guitar, voice, field, synth
this would be siiiick
Seems like a great match with the Salmple as they say. Will be getting it for that at the least.
- Wiggling with Experience
I'm really curious about how much resonance there is in the filtering. I'll have to give the video a good listen when I get home and have headphones to hopefully really hear the stereo spread and the what the filter sounds like.
I was just about to buy a Nearness as a stereo submixer. This is bigger, but this looks so much more interesting. Great for a small system.
I posted on reddit about it, but the gist is this seems like an enticing purchase for someone who wanted a Soundstage but limited in space. You still need VCAs and other utilities to crossfade into the different inputs. I've got an X-Pan and I'm happy with it, and obviously it doesn't have a built-in filter like this. I'm always teetering on giving up on mixing onboard and just sending all my outs to Ableton to deal with panning, but this provides an interesting option for those who want to patch & mix.
Shout out to ALM for collaborating with a great maker. That panel looks fresh with 'Worng x ALM'.
- nios
As I was reading the description I was thinking "wait isn't that just Soundstage" and then indeed it's stated to be like a condensed version of it. 8hp is pretty small; maybe it makes a better argument for being worth its space than 14 for what it does. I'm not even sure if I would want it vs the original though since the CV options were clipped; if they were still in I'd take a much closer look at it.
I like Worng but to be frank Soundstage is one of those modules that some people seem to like but I really don't quite get the appeal of, vs using something like a Verbos Scan & Pan (or the new Joranalogue Morph 4) with more direct control over positioning your signals exactly where you want. There are multiple VSTs that can mimic placement in a room; I find that I don't really need that in a module unless there was maybe some modular-ish quirk to it lke self-patching/feedback/CV over some options etc.
ALM should make some kind of channel to attenuate this. I just put an idea together. I have no idea about module design, so I have no clue if this is even possible.
- Dark Barn
- Contact:
Would be more enticing if we can get a 2hp expander for Squid Salmple adding 4 outputs for individual routing.
- hawkfuzz
- Super Deluxe Wiggler
- Contact:
This will do some fun with the Vortices paired. Surprised it doesn't have CV for MIX but no big.
- Common Wiggler
My favorite use of soundstage is as a VCA with spectrally mixed oscillator waveform outputs. this smaller one lacks that vca. But you can always use 2x external VCA with this one (but uses more HP than 8 then). Mix CV is great too. Soundstage (and this) also pairs well with something like a Morph 4 or ADDAC VC Rotator to move stuff around the spectrum too. It’s great with multiout sampler modules like assimil8or or squid too ... someone here mentioned you could do the same with a VST, perhaps ... if you want to multitrack ~8 outputs at the same time and setup the EQ/Q in the box (personally, I wouldn’t)
ALM just keeps killing it. Love this.
trying to follow what i think some of u have suggested or alluded to above with VCAs or the Rotator ... but ... what would be the most seamless way of CV controlling new panning arrangements with the jumble? if you're sending a tone to the upper right corner and wanted to bring it left, you'd have to unplug it first? ... unless?
- hawkfuzz
- Contact:
9:24 in the YT video a few post up.
It takes a bit.
It takes a bit.
thanks for the heads up!
- windspirit
- Common Wiggler
Hey sorry left you hanging on thatwt.info wrote: ↑Fri Feb 05, 2021 5:41 pmtrying to follow what i think some of u have suggested or alluded to above with VCAs or the Rotator ... but ... what would be the most seamless way of CV controlling new panning arrangements with the jumble? if you're sending a tone to the upper right corner and wanted to bring it left, you'd have to unplug it first? ... unless?
