ALM - Jumble Henge
Re: ALM - Jumble Henge
Does anybody have this module yet and can comment on the sound quality? My one issue with the Tangle Quartet is that it sounds a bit anemic. Wondering how the Jumble sounds as an (almost) final output stage?
- Noi del Prat
- Learning to Wiggle
I've been using it for a week and I'm very happy, so far.
This is a little clip recorded into the phone through a roland go mixer interface.
In the video, I mult the mono audio from the pocket operator, send them through multiple vca's with cv modulation and mix in the jumble henge.
The output of the jumble henge goes into a fx aid (stereo tape delay) and from there, to the audio interface.
- Whatisvalis
- Wiggling with Experience
How close is this to the Soundstage? Does it use the same components?
Simple to use, effective, good quality with the sounds I put through it.
songs - guitar, voice, field, synth
- plainjanefrancis
- Common Wiggler
what would be cool is if it could link to the jumble henge from the back via i2c. that way you'd. be able to choose where each of the 8 channels are routed via the menu system of squid.
got my 2x Henge today, one for the drum mixing on my main case, and the other for my Palette. only messed with it a bit, but really happy with it so far. My immediate first oppinion is that the mix knob is subtler than I was expecting, but it does what you want and acts a lazy-man's EQ. overall very happy with it so far, can't wait to throw more into the mix (pun intended)
- Paranormal Patroler
- Super Deluxe Wiggler
Any ideas on how to utilize the pair of external inputs as a send/return? There must be a good way without too much feedback.
- Stab Frenzy
- Ultra Wiggler
You can use them as an fx return, but if you’re feeding that fx unit with the outputs you’re creating a feedback loop.Paranormal Patroler wrote: ↑Wed Feb 24, 2021 6:39 pmAny ideas on how to utilize the pair of external inputs as a send/return? There must be a good way without too much feedback.
nsolarz wrote: ↑Wed Feb 24, 2021 6:12 pmgot my 2x Henge today, one for the drum mixing on my main case, and the other for my Palette. only messed with it a bit, but really happy with it so far. My immediate first oppinion is that the mix knob is subtler than I was expecting, but it does what you want and acts a lazy-man's EQ. overall very happy with it so far, can't wait to throw more into the mix (pun intended)
any comments on the filters on this vs the soundstage?
Sorry, never owned a soundstage so I cannot comparevidret wrote: ↑Thu Feb 25, 2021 11:06 amnsolarz wrote: ↑Wed Feb 24, 2021 6:12 pmgot my 2x Henge today, one for the drum mixing on my main case, and the other for my Palette. only messed with it a bit, but really happy with it so far. My immediate first oppinion is that the mix knob is subtler than I was expecting, but it does what you want and acts a lazy-man's EQ. overall very happy with it so far, can't wait to throw more into the mix (pun intended)
my question was aimed at anyone in the know, related to you saying the mix knob was subtler than you were expecting!
anyone?
anyone?
- Whatisvalis
The mix knob on the SoundStage is also pretty subtle up to around 11 o clock- I would imagine they are similar - I can't afford to be the one to test this right now, but I probably will swap my Soundstage out for the space saving in the near future.
