Knobs Recorders
Knobs Recorders
It seems like the preferred module for recording knobs wiggling is the Flame C3 which has been around for quite a while. I have to say that the Flame C3 looks basically perfect and reasonably priced but I wonder if there are other alternatives out there. Perhaps something with a clock input and the option to loop the recordings every X number of bars.
Re: Knobs Recorders in 2021
Tete and tetrapad together are a brilliant solution for knob recording (although it’s really slider recording obviously). You can record and playback gestures on any of the different tetrapad channel options (including mono and bipolar CV sliders, for standard ‘knob recording’). These gestures can all be looped and synced to a clock for as many bars as you like, with an upper recording limit of something like 5 minutes. I’ve found mine to be a bit temperamental with the clock settings but I got it to work perfectly with some deep settings changes (separating the looper from the clock input and instead syncing it to a trigger with the same repeating period as the desired loop length; then also using the reset input for added security).
Formerly 'Raven_Martin' on Muffwiggler
'And those who were seen dancing were thought to be insane by those who could not hear the music' - Nietzsche
https://carrouselmusic.bandcamp.com
https://soundcloud.com/carrousel_uk
- comacomfort
- Common Wiggler
none of the ones i've found are 16 bit or 24 bit, theyre all 12 bit. which is literal garbage, you''ll get stepping on slow movements and harmonics and artifacts when trying to open and close a vca on something with little harmonic content.
So the best knob recorder would actually be a self made one, using a sampler that has dc coupled sampling. Run an offset generator like the intellijel triplatt into a alm squid salmple, and you have 4 recorded knob voltages from a single source
or use an offset generator with rossum assimil80r
- ersatzplanet
- Synthwerks Design
I use a Planar2. Though not exactly a "knob" it works for me.
If this was a more important thing to me, and I had the cash, the Analogue Systems RS-450 is the box to get. Four channels, 16-bit, up to 14K sampling rate. Cost $1200 in the states though.
-James
- Common Wiggler
Looked into this recently as well. Ideally I would like something that can record any CV source, be it a knob, joystick or for example the Koma Kommander.
The only possible new contender to Flame I could come up with is DROID CV processor which seems like it might be possible to set up as a nice CV recorder. Haven't got one yet though, so not a recommendation, but might be worth checking out.
The new Erica Synths Black Joystick 2 looks like the new king of recorded gestures to me.
Something I didn't consider at all honestly but that's right, Flame C3 records at 12 bit. Isn't the output interpolated? It's for a rack I use for live techno/house so it should be okay, surprised no similar alternatives exist. The original Flame C3 is about 10 years old now.comacomfort wrote: ↑Sun Feb 21, 2021 2:01 pmnone of the ones i've found are 16 bit or 24 bit, theyre all 12 bit. which is literal garbage, you''ll get stepping on slow movements and harmonics and artifacts when trying to open and close a vca on something with little harmonic content.
I use an Octatrack and FH-2 for this. I can record knob movement on Octatrack midi tracks which are then sent as CV into the rack via the FH-2.
Nihil novum sub sole.
Re: Knobs Recorders
I find the problem with joysticks is, that you always have to record both axis X and Y. If in a performance you are really happy with the movement on one axis there is no way keeping it while recording the other axis.
We are the Borg. Resistance is equal to voltage divided by current.
https://soundcloud.com/logic_not
current 9U: https://www.modulargrid.net/e/racks/view/428567
Skiff: https://www.modulargrid.net/e/racks/view/818039
Recording: https://www.modulargrid.net/e/racks/view/1392937
Video: https://www.youtube.com/playlist?list=P ... PvexiFtvhI
- Wiggling with Experience
Re: Knobs Recorders
Ehem
Search feature, people. I literally started like two threads about this in the past two months.
BTW - I purchased Voltage Block to do the knob recording thing. It's not a precise knob recording, but it doesn't the job, especially for a noisy techno
viewtopic.php?f=16&t=244671&hilit=knob+recorder
viewtopic.php?f=16&t=238704&hilit=knob+recorder
Re: Knobs Recorders
I’ve got the Flame C3 with the latest firmware and yes, it’s quite nice. You can get it to record one incoming CV instead of the knob on this version. I haven’t noticed any stepping but then I’m usually using it for modulate-the-modulator kinda stuff. You can also have it start on a trigger and do a one shot. If every channel had all the features of chan one it’d be great
Be the modulation you wish to see in the world
https://www.patreon.com/join/jdanielcramer
http://queertunes.bandcamp.com
http://m.youtube.com/user/jdanielcramer
http://soundcloud.com/dcramer
Re: Knobs Recorders
I know that the Squarp Pyramid can record CV (or create CV via a touchpad), so you could record the CV resulting from knob movements, I would venture to guess. And the Eurorack equivalent is the Squarp Hermod, so again, I would venture to guess this is also capable of doing so, but correct me if I am wrong.
The Flame Quad cv recorder is 16bit!comacomfort wrote: ↑Sun Feb 21, 2021 2:01 pmnone of the ones i've found are 16 bit or 24 bit, theyre all 12 bit. which is literal garbage, you''ll get stepping on slow movements and harmonics and artifacts when trying to open and close a vca on something with little harmonic content.
And the Blackbox can record cv..
Re: Knobs Recorders
Yup, I use my Hermod for knob recording. Works like a charm.Peng33 wrote: ↑Sun Feb 21, 2021 7:19 pmI know that the Squarp Pyramid can record CV (or create CV via a touchpad), so you could record the CV resulting from knob movements, I would venture to guess. And the Eurorack equivalent is the Squarp Hermod, so again, I would venture to guess this is also capable of doing so, but correct me if I am wrong.
- Spacelordmother
- Learning to Wiggle
- Contact:
- minimalist
- Common Wiggler
Re: Knobs Recorders
I have the Flame C3 mk2 and think it is great. This module (and its destinations) are the only modules I re-patch when playing. It's just like three extra hands. I never felt that 12bit was a problem as it isn't something I notice.
Re: Knobs Recorders
Love LOVE my Pot Action Recorder from EMW
Bandcamp | Website
Part Two of a Tribute to Genius BRUCE HAACK — Hear a Computer play THE BRUCE HAACK SONGBOOK
Re: Knobs Recorders
I got Voltage Block for motion recording. It isn't quite the same, as it's step recording per clock pulse, but it gives you 8 channels of modulations.
Flame C-3 mk2 is still on my mind though.
I have also recorded knob twiddling nto Ableton MIDI clips followed by ES-9 for MIDI to CV conversion. Works well. Pretty sure any MIDI-to-CV convertor would work well here.
- ersatzplanet
- Synthwerks Design
Re: Knobs Recorders
For recording CVs to MIDI you can also use a ADDAC221 or other CV to MIDI CC converter though the Expert Sleeper stuff is great for this too. The advantage of the other modules like the ADDAC one, is that you can also directly control MIDI synthesizers or hardware without the computer. I use a Doepfer A-190-1 to drive my Nord Modular from CV controllers in my modular for instance. I could easily record them also If I wanted to keep them. The monster is the RS-450 of course, but you have to pay a bunch to get it.StrangeAttraction wrote: ↑Tue Feb 23, 2021 4:46 amI got Voltage Block for motion recording. It isn't quite the same, as it's step recording per clock pulse, but it gives you 8 channels of modulations.
-James
