send / Stereo Return Mixer
maxmax
Post by maxmax » Mon Feb 22, 2021 1:10 pm
Hey there,
IM searching for an Eurorack Mixer modul which has a Stereo Return. Is there something else on the market than the WMD Performance mixer?
Better would be less than 8 channels.
Thanks in advance!
sduck
experimental use of gravity
Re: send / Stereo Return Mixer
Post by sduck » Mon Feb 22, 2021 10:21 pm
Welcome to the forum! You probably meant to ask this in the eurorack forum - try again there (or maybe a mod can move this?)
Post by Kent » Tue Feb 23, 2021 12:19 am
Moved
Rosa
Post by Rosa » Tue Feb 23, 2021 1:30 am
Frap tools cgm qsc + cgm g
batch
Collector of fine modules
Post by batch » Tue Feb 23, 2021 1:34 am
Befaco Hex Mix with expander
Monday Night Modular - a weekly virtual meetup @ 8pm PT
miminashi
Post by miminashi » Tue Feb 23, 2021 2:05 am
Toppobrillo Stereo Mix 2 has a mono send / stereo return. It's a great mixer.
dbnegative
Post by dbnegative » Tue Feb 23, 2021 2:08 am
The tesseract tex mix has a dual mono send / stereo return with pre/post mix. It's pretty reasonably priced as well
redlester
Post by redlester » Tue Feb 23, 2021 2:30 am
Make Noise Rosie is an Output module which has a mono send/stereo return inbuilt, and can be mixed with two other mono signals.
Matt_L
Post by Matt_L » Tue Feb 23, 2021 3:25 am
Befaco HexMix+Hexpander has stereo return but mono send. Very nice unit, pretty big. I've found the headphone amp to be pretty noisy but the direct outs and master out seem to be pretty clean. It's pretty extra with the EQ matrix. The mutes are a wonderful feature. I often end up using pairs of the 6 tracks as stereo, panning each track hard left/right. It's slowly getting pushed out of my rig into a separate rack for recording, finding that I'm using it less for performance.
Has anyone tried the pin matrix mixers like the Instruo lion as quasi- effects send?
col
Post by col » Tue Feb 23, 2021 4:52 am
Before everyone lists the mixer they own it might be better to just post the list of mixers...
https://doudoroff.com/mixers/
AnalogDigits
Post by AnalogDigits » Tue Feb 23, 2021 5:29 am
One thing to note that surprises some people; if you’re trying to incorporate external effect units (or other line-level devices), you’ll likely need to attenuate on the way out and amplify on the way back in. Some mixers do that, many don’t.
I use the XAOC Praga with Hrad expander... really happy with it. There are many good options in outboard “non-Eurorack” mixers (which can be less-expensive). Prior to the Praga, I used a Mackie 1202VLZ.
Definitely take advantage of mdoudoroff’s comparison guides, they’re great stuff.
Jumbuktu
Post by Jumbuktu » Tue Feb 23, 2021 5:31 am
The list of mixers is the place to go ... but meanwhile, let's add Praga and Pittsburgh Lifeforms System Interface.
maxmax
Post by maxmax » Tue Feb 23, 2021 6:24 am
Thank you all for the Good Feedback so far!
Has the xaoc praga a Stereo Return?
Whatisvalis
Post by Whatisvalis » Tue Feb 23, 2021 7:49 am
Happy with the QSC from Frap Tools with the group channel, or you could use any stereo mixer for your returns.
If your only concern is 1 send and a stereo return you shouldn't have too much hassle finding something - the mixer list is a great place to start.
Matt_L
Post by Matt_L » Wed Feb 24, 2021 1:23 am
While it's useful to share that link, it also seems like someone searching for a particular mixer would find it useful to hear first-hand accounts with the opportunity to ask follow up questions.
aze_007
Post by aze_007 » Wed Feb 24, 2021 1:48 am
Yes, it has. But Praga becomes much better with the Hrad expander. Check it out on the Xaoc website.
Euro and nothing else - but isn't that enough?
Member of the 100x100 Club of Dieter Doepfer Supporters.
