I currently have a Renee v2 as the main sequencer in my system pictured below (incoming Beads will replace Echophon). I think Renee is an ingenious sequencer that does some incredible things. I'm not sure I've completely gotten on with it though. In particular, I just never became fast at creating melodies or pitch sets within a state or at recalling saved states to change among those melodies in real time (e.g., in different sections of a composition). In addition, I don't like how when changing snake patterns it inserts the first note between clock cycles (sounds like a glitch unless it's a really slow temp so I can hit it perfectly or a really fast tempo so it's not as noticeable). I feel like I mess around with Renee a lot and find wonderful happy accidents, but there's a lot of stuff in between.
So I'm contemplating going to a more traditional sequencer where melodies etc. are displayed right in front of you. Much as I dislike screens (yes including Shapey, it's my one exception and I struggle with it), the new Erica Synths Black Sequencer is basically at the top of that list, as it seems the objective was deep but simple and intuitive, and I like the demos I've watched (seems like I could be off and running in 5 minutes). It's obviously a completely different approach to sequencing -- it simply does exactly what you tell it to do (unless you tell it to do magic, and even then it shows you the magic) -- than Renee, so I'm not suggesting they're substitutes. But I'm wondering if anyone else gave a Renee a go, found it a bit opaque, and then either overcame that and got on with Renee or made the switch to a more straight ahead (i.e., non-Cartesian) sequencer.
Or both... If I do get a Black Sequencer, I obviously don't have to sell Renee immediately. So I'd also be interested in anyone's experience using both Renee and a regular/normal/traditional (sorry, I don't know the best word) sequencer together in the same system. If so, what ways do you implement that? All told that would be three two-parameter sequencing channels (Renee) plus four three-parameter sequencing channels (Black); I think seven sequencing channels is potentially overkill for the size system I have (though I guess I have six oscillator channels, and of course you sequence much more than just oscillator pitch). Ultimately I suspect I'd go back down to one sequencer, to make room for other fun stuff.
Thanks in advance for any thoughts. Cheers.
