3 way audio switch?
3 way audio switch?
Looking for either
i) - a 3 way switch that takes 2 audio inputs (A,B) with output and selects either A, B or A+B.
OR
ii) - a 3 way switch that takes 3 audio inputs (A, B, C) with output and a switch that selects from either, A, B or C.
Not much comes up when googling for 3 way switch..
OR
- Kosmikos
- Wiggling with Experience
- Contact:
Re: 3 way switch?
This looks like it could well do the job:
https://wmdevices.com/collections/euror ... tch-matrix
- mosorensen
Re: 3 way switch?
Do you need it for audio or CV?
For i), a crossfader should work (e.g., https://www.modulargrid.net/e/happy-ner ... fade-black)
For ii), a switch should work (e.g., https://www.modulargrid.net/e/doepfer-a-151)
There are fancier versions of both crossfaders and switches with more functions.
Re: 3 way switch?
yes - sorry audio - when I edited it I removed that by accidentmosorensen wrote: ↑Wed Apr 07, 2021 3:10 pmDo you need it for audio or CV?
I'll check out your links - thank you
Re: 3 way switch?
I looked at that - it looks cool actually but it's 3 switches each with 2 inputs. so you'd need multiple button presses to achieve it.dooj88 wrote: ↑Wed Apr 07, 2021 3:08 pmthis one?
https://www.modulargrid.net/e/acid-rain ... witchblade
Re: 3 way switch?
I've actually got one of these although not used it that much yet - too big for my use-case and somewhat overkill.Kosmikos wrote: ↑Wed Apr 07, 2021 3:09 pmThis looks like it could well do the job:
Re: 3 way switch?
for i) a crossfader could work - it depends on the vol curves - I don't want any dip when they are both in the middle.orbita wrote: ↑Wed Apr 07, 2021 4:46 pmyes - sorry audio - when I edited it I removed that by accidentmosorensen wrote: ↑Wed Apr 07, 2021 3:10 pmDo you need it for audio or CV?
for ii) a sequential switch could work - but I would need to pass in a voltage - I have a pico seqs floating around so I'll give this a go.
What I'd really like is a 182-2 but with 3 inputs and the middle position being the 3rd input instead of no connection. Might have to write to doepfer.
Re: 3 way audio switch?
Come to think of it, I think maybe a mutes module like maleko mute or divkid mutes would actually work best.
Also, this from Joranalogue might work. I have a DivKid Mutes, but may add to/replace it with this.
WMD sl3kt has some cool normalling that would work for this methinks....
- DJMaytag
- Ultra Wiggler
- Contact:
Does it have to be a switch? Low Gain CVP might work?
https://www.modulargrid.net/e/low-gain- ... nics-cvp-1
Instagram | Soundcloud | MG Main Rack 6U+6U
“If you talk about improper grounding 3 times, Graham Hinton appears!” -djs
Maybe the Zlob Push VCA? It can do what you want, but with two push buttons.
https://www.modulargrid.net/e/zlob-Zlob ... r-push-vca
Nice find! that definitely solves the problem and in the most compact manner, with the added benefit of the direct outs which I might find a use for.Inflexus wrote: ↑Thu Apr 08, 2021 2:06 amMaybe the Zlob Push VCA? It can do what you want, but with two push buttons.
Basically I want to be able to control the outputs of my DLD so I can choose from either or both channels. Having 2 buttons also lets me choose none - which could be useful and may free up another of my switches.
I think it would have been good if 4ms had put a 3 way switch on the DLD so you can choose which channels were routed to the combined A output.
- bedhed3000
- Contact:
https://www.modulargrid.net/e/2hp-switch is the same width as the Zlob. I used to have that push vca module. It's pretty great (no clicks or pops when muting), but only 2 channels.
With the 2hp switch you can have the 3 inputs you want for scenario ii - and just leave the 4th unpatched as a "mute". And you can switch with CV if you're into that type of thing.
https://soundcloud.com/mporecchia
https://michaelporecchia.bandcamp.com/
