FYI: Updated DPO Manual
shady smiles
Post by shady smiles » Wed Feb 20, 2013 4:08 pm
Spied this on the MakeNoise FB page.
http://www.makenoisemusic.com/manuals/DPOManual.pdf
Includes some fixes and a new patch tip (Analog Bass Drum).
Tombola
Post by Tombola » Wed Feb 20, 2013 4:12 pm
You'd think he'd be able to manage more than one patch idea...
jonne74
Post by jonne74 » Wed Feb 20, 2013 4:20 pm
Anyone have links to DPO demos in a more traditional minimoog style system? You know, filters, envelopes etc. Maybe a melody.
Entrainer
Post by Entrainer » Wed Feb 20, 2013 4:32 pm
jonne74 wrote:Anyone have links to DPO demos in a more traditional minimoog style system? You know, filters, envelopes etc. Maybe a melody.
This one has melody, filters, envelopes:
viewtopic.php?t=78330
No minimoog style system though. If I wanted that, I'd buy a Sub-Phatty
or Macbeth DO/BEF.
5,159 custom drum samples for electronic music
made from 4 modular systems, drum modules, and some nice analog outboard processing
202 Instruments for Ableton Live/Push (128s), NI Kontakt, and Logic EXS24
41 Kits for NI Maschine, FXPansion Geist, Ableton Drum Racks, and Octatrack Sample Chains
http://www.drivenmachinedrums.com
jonne74
Post by jonne74 » Wed Feb 20, 2013 5:56 pm
Sounds great, Entrainer! If I get the DPO, it would be in a more traditional system for quite a while. Just curious about the sound in that setting.
Mefistophelees
USB Cat
Post by Mefistophelees » Wed Feb 20, 2013 7:00 pm
jonne74 wrote:Sounds great, Entrainer! If I get the DPO, it would be in a more traditional system for quite a while. Just curious about the sound in that setting.
It does a huge range of sounds, some of which can be very rich and beautiful.
It has a very different sound but it's perfectly usable for melodic work.
The sound is so complex you can hook it up to a envelope generator and a VCA and you've got a pretty powerful synth.
Entrainer
Post by Entrainer » Thu Feb 21, 2013 12:18 pm
Thanks! Well, I'd have to see the system in order to comment.
The thing about combining different designers' module is you do need
to consider the flavor or mix. Consider two engineers mixing a record...
one mixes the kick with a 10kHz boost, another cuts 10kHz and boosts
the hats instead.
Well, take one engineers boosted kick and another's boosted hats, now
you have a harsh mix.
Optomix is clean and I don't think it even opens up to 20kHz, so the
DPO (IMHO) compensates by having a ton of high-frequency harmonics
and distortion/waveshaping available.
Add the DPO to a dirty or nasally filter and it'd be way to much.
I don't consider the DPO to be an all-purpose oscillator. It's something to
be added to a makenoise system or placed in a larger system as an
additional voice in an orchestra.
mantid
Post by mantid » Sat May 19, 2018 10:48 am
Can anyone point me to the context/history of "259 style modulation routing" mentioned in the manual's intro?
leftbracket
Post by leftbracket » Sat May 19, 2018 11:00 am
mantid wrote:Can anyone point me to the context/history of "259 style modulation routing" mentioned in the manual's intro?
It refers to the Buchla 259, the original "complex oscillator":
As you can see, there are a number of fairly direct parallels between this and the DPO (or the Verbos Complex Oscillator, Endorphin.es Furthurrrr Generator, etc.). The modulation routing in question is the voltage-controllable level of FM, AM, and/or timbre (wavefolding) modulation of the principal oscillator by the modulation oscillator seen in the center of the module.
mantid
Post by mantid » Sat May 19, 2018 11:39 am
leftbracket Thank you! I'll do some studying accordingly. DPO just arrived yesterday and initial results are off-the-charts... It seems like it will take more work to learn to tame it than to learn to pull weird stuff out of it, and I like that!
dooj88
Post by dooj88 » Mon May 21, 2018 2:43 pm
here's a generally good idea of the dpo i think.. i shouldn't have listened to this again just now.. james cigler's dpo patch from a modular podcast has the most satisfying tones i think i've ever heard. i just don't have space cash or interest for a dual osc. the sounds though... :drunkhomer: :drunkhomer: :drunkhomer:
mantid
Post by mantid » Mon May 21, 2018 5:44 pm
Here's a bit I just made playing around with the Final output, and using sync mode with a Turing Machine on osc A. The "percussion" is the Strike input and the Angle being triggered by a clock divider. This is just DPO, one wave going through the Xaoc Phase Rotator, and some Reverb:
https://soundcloud.com/mantid/final
TemplarK
Post by TemplarK » Mon May 21, 2018 6:02 pm
Heres the sound of my DPO. I can go through the patch should anyone care.
https://soundcloud.com/robert-tree-hard ... e-dpo-test
Chickenbone
Post by Chickenbone » Mon May 21, 2018 8:13 pm
I love making the DPO go completely insane. It's very easy for the sounds to become incomprehensibly terrifying and disharmonic. It's beautiful.
If you ever come to a fork in the road, pick it up.
Modular Grid
SoundCloud
TemplarK
Post by TemplarK » Mon May 21, 2018 8:28 pm
Chickenbone wrote:I love making the DPO go completely insane. It's very easy for the sounds to become incomprehensibly terrifying and disharmonic. It's beautiful.
For sure, i will admit I like my DPO much better when its combined with either diode distortion or through Moddemix and LxD etc. Something about using Make Noise modules together really they are beutifully designed system.
