Soma - LYRA-8 DIY Kit
gnsk
Re: Soma - LYRA-8 DIY Kit
Post by gnsk » Fri Sep 11, 2020 6:18 am
digix wrote:
Fri Sep 11, 2020 4:38 am
OK team - I'm getting close to finishing up my build. I've noticed on the images of stock Lyra-8's the I/O board has two leads coming out from a very large solder pad. Nothing is listed in the documentation about it. What's this about? Just ignore it?
it's chassis ground. not used in my case; wooden case.
Flounderguts
Post by Flounderguts » Fri Sep 11, 2020 9:27 am
This has been brought up before.
It seems to be an artifact from an older version...ground plane hookup is the consensus right now.
The Lyra seems very sensitive to grounding issues.
Flounderguts
LegWyne
Post by LegWyne » Fri Sep 11, 2020 10:03 pm
and EM or static interference. while testing the previously working I noticed the ground hum would increase or decrease if I moved my hand away from or towards one side of the I/O board
klenkstar
Post by klenkstar » Mon Sep 14, 2020 5:04 pm
I'm nearly completed with my lyra but I haven't been able to find a good source for the thumbscrews. Does anyone know where I could get some or have some they would be willing to sell?
LegWyne
Post by LegWyne » Mon Sep 14, 2020 7:50 pm
If you want a cheap option you could buy some on alibaba (2 months shipping) and substitute standard M3 10mm or 12mm bolts while you wait
Flounderguts
Post by Flounderguts » Mon Sep 14, 2020 7:53 pm
klenkstar, welcome to MuffWiggler!
Where are you located? There are several channels to find DIN thumbscrews...if you're in the USA, try computer shops. This style is often used with server racks.
Flounderguts
Lemmy
Post by Lemmy » Tue Sep 15, 2020 9:13 am
I'm collecting parts for a Lyra build and I went this path - they arrived within 2 or 3 weeks.
LegWyne
Post by LegWyne » Tue Sep 15, 2020 7:01 pm
Nice, how was the quality? I ordered mine 5 weeks ago using AliExpress and they haven't shown up yet. Ships seem to take a while to get to Oz tho.
Lemmy
Post by Lemmy » Wed Sep 16, 2020 3:50 am
The quality seems good. These are the ones I ordered - https://www.aliexpress.com/item/4000145 ... 4c4dzHJQKZ
klenkstar
Post by klenkstar » Wed Sep 16, 2020 9:17 am
Thanks! I'm located in the US. There is a microcenter nearby I might scope out first before going the alibaba route. Thanks for the tip!
steviet
Post by steviet » Wed Sep 16, 2020 8:54 pm
It's alive! WOAH man this thing sounds amazing.
Everything works perfect, EXCEPT:
The Hyper LFO doesn't seem to want to modulate the voices. It modulates the delay just fine, but when you flip the switch to "LFO" for modulation source on any of the voices (Total FB knob is turned down, as is Vibrato) the "MOD" knob just messes with the tuning of the voice slightly, and at its max position it pretty much silences the voice.
Everything else works great! Delay, Distortion, all the voices sound, hold knobs, the FM modulation between voices, everything! EXCEPT the Hyper-LFO modulating the voices. The LED also seems a little dim.
Now one thing to mention is I am still waiting on the headphone AMP IC (TDA2822), but I didn't think this would affect the Hyper LFO's ability to modulate the voices.
I've got proper voltages across the board, except where the TDA2822 chip should live. I'm assuming that will read properly right as soon as that chip is in there.
Any thoughts anyone?
EDIT: I re-seated all the dupont headers, now it's all working perfectly :woah: :tu:
Soundcloud
Flounderguts
Post by Flounderguts » Wed Sep 16, 2020 11:26 pm
Wow! Looking great! (nice panel) :hihi:
Flounderguts
LegWyne
Post by LegWyne » Thu Sep 17, 2020 8:31 am
It really is a very nice panel Flounderguts. I'm looking forward to seeing a completed unit!
steviet
Post by steviet » Thu Sep 17, 2020 10:01 am
Oh its a beauty panel, from our dear friends over at www.flundrton.com
They're even working on other cool panel concepts check it out:
viewtopic.php?f=17&t=234558&start=50#p3349177
The guy has some really cool stuff Flounderguts! You should check it out ;)
Soundcloud
Flounderguts
Post by Flounderguts » Fri Sep 18, 2020 10:01 pm
I'm working on an IO panel and enclosure for the standard DIY build.
Question: for the jacks on the back, which do you prefer; text right side up (see it from back), text upside down (see it when peering over from front), or text on top of main panel AND right side up?
And do we all like our power switch on the back?
This is what I've got right now...jacks right side up, power legend upside down. I just liked it, but it doesn't make a whole lotta sense...
Flounderguts
steviet
Post by steviet » Sun Sep 20, 2020 1:18 pm
gnsk wrote:
Fri Sep 04, 2020 12:15 pm
i grounded on the board, my case is wooden.
I stole your picture for my site too gnsk, fire me a PM if you want me to take it down. I credited you as well!
I'm going to be alllll over this. I was thinking of doing a clear acrylic, but if I can be one of the first "Standard Flounderguts builds", well that would be super cool.
Yes love my power switch on the back. Not sure what footprint your going for, but this guy seems pretty standard:
https://www.taydaelectronics.com/rocker ... ap-in.html
I'm a little biased because this is the switch I chose... But regardless, throwing my two cents in.
As far as the legend, I agree it doesn't make a lot of sense, but that is kind of going with the whole theme of the LYRA-8. It doesn't make sense, and that's how we like it :sb:
Soundcloud
gnsk
Post by gnsk » Sun Sep 20, 2020 7:08 pm
Thanks for the credit; "Thanks again gnsk."
De nada. my pleasure.
LegWyne
Re:
Post by LegWyne » Sun Sep 20, 2020 7:20 pm
lasesentaysiete wrote:
Tue Jun 06, 2017 3:39 pm
does anyone else find the control board design an odd choice? I mean that instead of having the pcb-mountable components mount to the pcb via regular footprints, we get this sort of smd type style with THT components. Anyone know why this is?
I actually don't mind it, btw. But it seems an unnecessary amount of work. :despair:
presumably to allow for a diversity of component choices. parts with different physical dimensions can all be "panel mounted" to the PCB without causing an issue. im still new to complex builds and found it quite straightforward to solder the control board using leftover resister leads as recommended.
gnsk
Re: Re:
Post by gnsk » Sun Sep 20, 2020 8:45 pm
factory built is with pcb mount.
For DIY version, it it easier to swap pots and components.
For example, T18 pots to 6.35mm pots etc.
Just my thought.
Flounderguts
Post by Flounderguts » Mon Sep 21, 2020 9:29 pm
more CCCP capacitors arrived today.
Flounderguts
digix
Post by digix » Sun Sep 27, 2020 2:51 am
She's finally finished! Behold the electric blue DIY Lyra-8. I took my time on this one and probably went overboard with the finishes but I'm more than pleased with the outcome. The panel is from frontpanelexpress and the case was custom made by a local wood & metal artist I found on Etsy. Today was final fabrication of the rear panel, cutting the wood, and mounting everything up. Onwards to FM feedback bliss!
gnsk
Post by gnsk » Sun Sep 27, 2020 9:14 am
nice blue.
Could you please let me know, where did you sourced the thumb screws? my screw from aliexpress has a little small diameter(< 12mm).
Thanks.
