[IN STOCK] Eurorack 4hp THAT2180-based Audio VCA
- pulsepsycle
- Learning to Wiggle
- negativspace
- Manhattan Analog
- Contact:
- DJMaytag
- Ultra Wiggler
- Contact:
Re: [IN STOCK] Eurorack 4hp THAT2180-based Audio VCA
Would a TL074C or something different than a TL074B be suitable? I have a bunch of the linked TL074C's on the way from Tayda, and am about to order up a ton of parts from Mouser & Smallbear. I'm just curious if I should go ahead and get some of the TL074B's from Mouser, just in case, or are there other good/better options?negativspace wrote:[1] TL074B
Am I seeing this right, but is the LM49710 back? If so, I'm glad I waited a bit longer to be able to order parts for this!
Instagram | Soundcloud | Wisco Wigglers
“If you talk about improper grounding 3 times, Graham Hinton appears!” -djs
The "C" specifies standard commercial temperature range, as opposed to "I" for wider temperature range. The "B" specifies that it's selected for smaller DC offset. A chip called TL074B will probably really be TL074BC, and maybe another one or two letters after that to designate the package style. If you substitute a TL074C (no B in the part number) then it should still work, but it will have a larger DC offset. That may be no big deal in an audio VCA, but might be more of an issue in a VCA you plan to use for control voltages.DJMaytag wrote:Would a TL074C or something different than a TL074B be suitable? I have a bunch of the linked TL074C's on the way from Tayda, and am about to order up a ton of parts from Mouser & Smallbear. I'm just curious if I should go ahead and get some of the TL074B's from Mouser, just in case, or are there other good/better options?negativspace wrote:[1] TL074B
North Coast Synthesis Ltd.
Latest Web log posting: Passive multiples and friends
If you tell me that your goal is systemic change toward radical acceptance, and I see that you treat those you perceive as lesser-than with the same kind of scorn and derision that pushed me toward this insular little subculture where I feel comfortable [. . .] then you’ve successfully convinced me that your acceptance is not radical and the change you want not systemic. - Meredith Patterson
- DJMaytag
- Ultra Wiggler
- Contact:
Hmm... looks like spending some extra $$$ for the 074B might be in order here? I can somewhat follow a circuit diagram, though I may not be able to use the right terminology to describe whats going on, but it looks like the TL074 is handling the mixing (or processing) of the two CV inputs, and the THAT & LME chips are handling the audio.
I don't know how much of a big deal the operating temps are, but is an offset of 10mV vs 3mV that huge of a deal for proper operation?
- veets
- Wiggling with Experience
- Contact:
Or perhaps you can.
I've successfully built three of these. Number 4... not so much. I can't get the voltage at TP to drop below 3.6v when performing calibration. And the fuse nearest the edge of the board gets mighty hot. Like burn your finger hot. Perhaps this is normal, but I've never experienced this before. (The other fuse might be hot, too, but I haven't checked.)
Perhaps a short? If so, and given the symptoms, any suggestions about where to look? I wonder if it's the 1K TC. That was rough to solder.
Does your Manhattan Analog VCA output have a nasty high frequency oscillation?
All the ones I built did... The fix was pretty simple:
- replace the 330 ohm resistor near U3 (LME49710) with a jumper
- place a 330 ohm resistor between the output jack and the PCB
This takes the 330 ohm resistor out of the feedback loop around U3 and stops the oscillation on the output.
I'm not sure why the 330 was in the feedback loop - if anyone can shed some light on that I'd love to know in case my 'fix' has introduced a new problem.
- neil.johnson
- Super Deluxe Wiggler
- Contact:
The problem is that this is a poorly designed circuit. That 330 ohm resistor is supposed to protect the opamp output from capacitive loads, and putting it inside the feedback loop is the correct arrangement to ensure DC accuracy. HOWEVER the small 22p compensating capacitor is supposed to connect to the other side of the 330 ohm resistor. There are various posts on here about this.ndf wrote:Does your Manhattan Analog VCA output have a nasty high frequency oscillation?
Neil
- neil.johnson
- Contact:
Well, here's an example from Dave Jones showing the correct way to do the output circuit: viewtopic.php?p=1445492&highlight=#1445492ndf wrote:Thanks Neil, could you please suggest a link to one of the posts?There are various posts on here about this.
You say this is a poorly designed circuit... Could you please elaborate?
For detailed analysis try this: viewtopic.php?p=1129644#1129644
As far as this design is concerned, the control circuit has many issues, most of which could be fixed by reading the THAT datasheet.
Neil
- neil.johnson
- Contact:
The resistor is there not to protect against shorts but to stop the output oscillating when cables are plugged in due to the cable capacitance interacting with the op-amp's output stage and the feedback circuit.paperCUT wrote:Looks like the easiest fix would be to remove the 330ohm resistor and replace it with a jumper. Then add the resistor between the output PCB hole and the output jack.
It's already AC coupled so doesn't need any accuracy, just some slight protection against shorts.
Neil
Wish this had come up with my post in January.neil.johnson wrote:The problem is that this is a poorly designed circuit. That 330 ohm resistor is supposed to protect the opamp output from capacitive loads, and putting it inside the feedback loop is the correct arrangement to ensure DC accuracy. HOWEVER the small 22p compensating capacitor is supposed to connect to the other side of the 330 ohm resistor. There are various posts on here about this.ndf wrote:Does your Manhattan Analog VCA output have a nasty high frequency oscillation?
Neil
I spent probably 20 hours troubleshooting, then chucked it in the trash.
Studio system: http://www.modulargrid.net/e/racks/view/413249
WestCoasty: http://www.modulargrid.net/e/racks/view/435591
6u portable: https://www.modulargrid.net/e/racks/view/703297
Portoclocker: https://www.modulargrid.net/e/racks/view/759773
- Veteran Wiggler
I recently built a MA VCA. While the unit sounds good, it is SIGNIFICANTLY quieter than my other VCA's. I calibrated precisely (within <1mV) to the values listed in the manual, and while the response is good, it's really low volume.
Before I go swapping any resistors, does anyone have any advice? Should I have used a 10v Zener instead of a 5.1V?
- DJMaytag
- Ultra Wiggler
- Contact:
You may have installed something wrong. Mine are SUPER hot on the output side.
- negativspace
- Manhattan Analog
- Contact:
If it's built and calibrated correctly, it'll be at unity gain @ full CW on the offset control. You'll be able to get a little bit more out of it than that if you use external CV more than ~5.2V, depending on the exact performance of the zener you chose.
I'd doublecheck parts and calibration to be sure everything is in order.
BOM for v1.4 of the PCB
Hi, thanks for your awesome modules.
Do you have a BOM available for the version 1.4?
Thanks & regards.
Thanks & regards.
- negativspace
- Manhattan Analog
- Contact:
Mouser BOM?
Ive been through the entire post, but I cant seem to see anyone shared their BOM from Mouser.. And it would save me a lot of time, sourcing.. (Im kind of a noob, at it)
So.. Can anyone be so kind to share their BOM from Mouser, please. I already ordered the 2x PCB and Panel + THAT 2180 chips and knobs, from Thonk.. So dont worry about that.. :-)
All the best
Johan
All the best
Johan
I Am:
Phaedrus / Johan de Reybekill
www.phaedrus.dk
www.soundcloud.com/johan_de_reybekill
www.phloq.dk
Current rack: https://www.modulargrid.net/e/racks/view/658018
www.phaedrus.dk
www.phloq.dk
- negativspace
- Manhattan Analog
- Contact:
hi guys,
i need some help (i'm very noob at this).
just finished building the rev1.4 board, and did managed to calibrate it like instructed on first page, but when i try it (put oscillator signal into input, lfo into cv 1 and cv2) no sound coming out. been testing and checking for hours all the component, and it seems everything right to me.
i did notice something, compare the board picture from first page and my board, the layout of the resistor in the upper board next to 5v1 zener is a bit different. i don't know if its correct or not..
on the first page
100K
100K
20K
100R
330R
and on the rev1.4 board
100K
100K
100R
20K
330R
any suggestions maybe..?
thank you.
on the first page
100K
100K
20K
100R
330R
100K
100K
100R
20K
330R
thank you.
- negativspace
- Manhattan Analog
- Contact:
