Serge TKB Kit!
pickleinn
Post by pickleinn » Mon Dec 25, 2017 7:14 pm
:sb:
egilegilegil
Post by egilegilegil » Mon Dec 25, 2017 10:34 pm
fonik wrote:Just as a sidenote, we are about to build a 1st prototype for a R*S Serge TKB. But there is no ETA yet. It is no simple replika and ee changed and added a few things so we will have to see if it all works out well.
Yes!!! This is going to be amazing! Perhaps too early to ask this but is there a euro version planned?
johnchantler
Post by johnchantler » Tue Dec 26, 2017 5:57 am
already a euro version pretty far along:
https://muffwiggler.com/forum/viewtopic ... highlight=
https://www.analogueresearch.com/product-page/serge-tkb
Synesthesia
Northern Light Modular
Post by Synesthesia » Wed Dec 27, 2017 8:17 am
good news - hopefully it stays at the same pricetag than the kit sold by Zthee or cheaper, but not more expensive.
oldenjon
Post by oldenjon » Fri Feb 16, 2018 4:55 pm
nothing to see here
"We all dance by ourselves, that's why we only play electronic music"
http://synthscalledbeasts.tumblr.com/
MATSmile
Post by MATSmile » Sat Feb 17, 2018 3:28 pm
Does anyone know if MM74C150N will work? Maybe someone here knows where to find MM74C150? Thanks!
cygmu
Post by cygmu » Sat Feb 17, 2018 4:02 pm
MATSmile wrote:Does anyone know if MM74C150N will work? Maybe someone here knows where to find MM74C150? Thanks!
I’m pretty sure MM74C150N is the right part. The N suffix is just Fairchild’s order code for it. Search up the datasheet for confirmation (I’ve just looked but don’t take my word for it)
lcf
Post by lcf » Sat Feb 17, 2018 7:21 pm
Yes it's what i thought.
Triglav
Post by Triglav » Sun Feb 18, 2018 4:07 pm
New Random*Source video:
dksynth
Post by dksynth » Thu Mar 15, 2018 8:45 pm
I am building one of these kits and my touch panel is not working .... when keyboard is on, all LEDs are on.
It works fine in clocked mode when keyboard is shut OFF.
Pulse into RESET causes everything to freak out... it doesn't reset to 1.
anyone has some ideas, I'd appreciate it!
oldenjon
Post by oldenjon » Thu Mar 15, 2018 9:15 pm
dksynth wrote:I am building one of these kits and my touch panel is not working .... when keyboard is on, all LEDs are on.
Try fiddling with the SENS trimmer
dksynth
Post by dksynth » Thu Mar 15, 2018 9:20 pm
I don't think that is the issue, full range of the sense trimmer makes no difference. Also, I don't think that would explain the reset misbehavior?
oldenjon
Post by oldenjon » Thu Mar 15, 2018 9:23 pm
RESET doesn't work the way you expect
dksynth
Post by dksynth » Thu Mar 15, 2018 9:45 pm
right, it hits the preset enable pin of that one counter... I'm not sure how that works at all. In any case, at the limit of the sense pot, half the LEDs turn on and then slowly the rest turn on.
Maybe I should try a bigger trimmer for sensitivity?
I compared some of the input/outputs on the MM74C150 against my ARC TKB and they look quite similar.
will try following things forward tomorrow if the trimmer doesn't change anything.
medbot
Post by medbot » Fri Mar 16, 2018 11:17 am
I don't know if this will apply to yours, but when I built mine I got all sorts of funky, unexplained LED behavior that wound up being caused by a small blob of solder touching the inside of one of the panel holes (like the small cutouts for soldering things to the underside of the touch pad). This was a few years ago, so I can't quite remember the specifics, but I remember it was a pain to fix because it was under the touch pad. I think I ended up sliding pieces of electrical tape under all of it to make sure everything was isolated.
dksynth
Post by dksynth » Fri Mar 16, 2018 1:58 pm
Pin 10 (output) of 74c150 is completely dead even isolated from the circuit,
So I take it my 74c150 is dead.... unless someone suggest otherwise.
Dang!
zdarma
reverse the polarity
Post by zdarma » Fri Apr 06, 2018 4:39 am
It looks like my 74c150 is also dead. Does anyone know where to get a replacement? Maybe Jon still has some?
Reality Checkpoint
Confused By Electricity
Post by Reality Checkpoint » Fri Apr 06, 2018 6:17 am
zdarma wrote:It looks like my 74c150 is also dead. Does anyone know where to get a replacement? Maybe Jon still has some?
I have used these people on several occasions, with no problems at all:
https://www.ebay.co.uk/itm/MM74C150N-IN ... xyjxlTOB0b
zdarma
Post by zdarma » Fri Apr 06, 2018 12:43 pm
Thanks for the recommendation.
I ordered one from this seller in germany, hopefully they are also reliable:
https://www.ebay.com/itm/1-pc-MM74C150N ... SwRgJXiOY4
Eric Appla
Post by Eric Appla » Wed May 23, 2018 4:54 am
I made little PCB which protects the MM74C150 from dying. It simply clips onto the 16 flat cable and you connect two wires to plus and minus of the PSU.
I don't have enough posts here yet to post pictures so picture soon incoming
I can post PCB or populated board to those interested
Best regards
brmex
Post by brmex » Tue Jul 31, 2018 5:03 pm
Hello there! I am curious to know, if the TKB-PCB´s and frontpanles are still available anywhere...any info concerning this? Thanks in advance!
MATSmile
Post by MATSmile » Wed Aug 01, 2018 12:52 am
I have one for sale atm if anyone is interested. Sale
vtl5c3
Post by vtl5c3 » Wed Aug 01, 2018 11:47 am
Definitely interested!
Eric Appla wrote:I made little PCB which protects the MM74C150 from dying. It simply clips onto the 16 flat cable and you connect two wires to plus and minus of the PSU.
Best regards
efexor
Post by efexor » Wed Aug 01, 2018 12:43 pm
brmex wrote:Hello there! I am curious to know, if the TKB-PCB´s and frontpanles are still available anywhere...any info concerning this? Thanks in advance!
Random Source announced a TKB.
But no information on his website.
BillLynes
Post by BillLynes » Tue May 21, 2019 4:27 pm
Is the TKB PCB/Panel kit still available? Ive searched but can't find a source.
Any help is appreciated.
