terminal tedium (raspberry zero, pi2, pi3 codec / pd thing)
seanrieger
Re: terminal tedium (raspberry zero, pi2, pi3 codec / pd thing)
Post by seanrieger » Sun Mar 22, 2020 12:36 pm
seismic wrote:
Sun Mar 22, 2020 8:41 am
tadaaa
finally made it. a shame it took me so long..
looks awesome so far!
That looks super awesome! Are you planning on selling kits on your site?
- File Transfer Protocol | Music as dark as the world we live in.
My main rack on Modulargrid |
Instagram | Facebook | Twitter | YouTube
djthopa
Post by djthopa » Sun Mar 22, 2020 1:00 pm
Hi!
Have you enabled audio thru levels?
I have gate asigned to input 1 and cv input to input 6.
I can check later in front of the module and give you more detailed info :tu:
seanrieger
Post by seanrieger » Sun Mar 22, 2020 1:32 pm
Hi!
Aha! Okay, I went through and turned audio through on for all of them, and that's getting me sound. I see what you are saying about the CV being strange though. What I am seeing is that when I hit a key, the gate triggers, but I have to hit the key again to turn the gate off. That got me to a place wehre I can at least look deeper into it though. Thank you very much!
djthopa
Post by djthopa » Sun Mar 22, 2020 1:40 pm
Hi!
Great you made some advance. I think maybe the trigger signal has to be if certain lenght, shape or amplitude? I reccomend trying a few different types and see how it goes. The note in did not work very well for me yet, it might also have to do with the voltage in the signal?
seismic
Post by seismic » Sun Mar 22, 2020 2:07 pm
tadaaa
na - i only ordered 5pcs. one for a friend whom i am developing something with (color display, framebuffer copy to have native terminal/X & QT-stuff). then there were two for me, one i sent to gerald, i think there should be one laying in the basement.
funkytransport
Post by funkytransport » Fri Mar 27, 2020 6:11 am
SOLVED -- Hey Folks, I've had a good read through here but couldn't find exactly what I was looking for so...
my Terminal Tedium seems to work fine. I can run patches fine when I use SSH
i.e. using the following command " pi@raspberrypi:~/terminal_tedium/software $ sudo pd -nogui -rt -r 48000 tt_chord.pd "
but.. When I try to edit my rt_start file to include a command to run this it just doesnt work. I've pasted my rt_start file below, if anyone can see the issue? (it lives in /home/pi/terminal_tedium/software, this is correct right? )
Thanks for any help!
Iain
#!/bin/bash
## Stop the ntp service
sudo service ntp stop
## Stop the triggerhappy service
sudo service triggerhappy stop
## Stop the dbus service. Warning: this can cause unpredictable behaviour when running a desktop environment on the RPi
sudo service dbus stop
## Remount /dev/shm to prevent memory allocation errors
sudo mount -o remount,size=128M /dev/shm
## set CPU scaling governor to performance (pi2, pi3)
for cpu in /sys/devices/system/cpu/cpu[0-9]*; do
echo -n performance | sudo tee $cpu/cpufreq/scaling_governor
done
# master volume
amixer cset numid=1 110
# capture volume
amixer cset numid=3 31
# line capture switch
amixer cset numid=4 on
# HiFi playback switch
amixer cset numid=13 on
# save
alsactl store
## start pd
sudo puredata -noadc -nogui -rt -r /home/pi/terminal_tedium/software/tt_chord.pd &
OR
sudo pd -nogui -rt -r 48000 ~/terminal_tedium/software/tt_chord.pd &
(ive tried both)
exit
Last edited by funkytransport on Mon Mar 30, 2020 6:40 am, edited 1 time in total.
seismic
Post by seismic » Sun Mar 29, 2020 6:04 am
Iain
try calling pd with the full path to your puredata binary (wherever that is in your installation (/usr/bin/pd or some like that) )
funkytransport
Post by funkytransport » Sun Mar 29, 2020 7:37 am
Thank you I will try that now..
funkytransport
Post by funkytransport » Sun Mar 29, 2020 7:57 am
/home/pi/pd-0.48-1/bin
is the path.. do i just put that in?
seismic
Post by seismic » Sun Mar 29, 2020 8:30 am
yes - then it's something like:
sudo /home/pi/pd-0.48-1/bin/pd -nogui -rt /home/pi/terminal_tedium/software/tt_chord.pd &
funkytransport
Post by funkytransport » Mon Mar 30, 2020 6:37 am
Alriiiiiight..... That worked!
That was doing my head in so really appreciate the :help:
stevemensink
Post by stevemensink » Mon Mar 30, 2020 7:29 am
Hi Guys, had this problem for a few months now with 3 of my TT’s. Still can’t figure it out.
When i run this install script
(wget https://raw.githubusercontent.com/mxmxm ... install.sh
sudo chmod +x install.sh
sudo bash install.sh )
i get this:
cloning terminal tedium repo ... ----------------------------------------------
install.sh: line 35: git: command not found
install.sh: line 36: cd: /home/pi/terminal_tedium: No such file or directory
install.sh: line 37: git: command not found
I have been staring at this for too long :-x. I hope anyone can point me in the right direction to fix this!
It was working perfectly fine before september. After that i had no luck. i tried going back to older raspbian versions, no luck either .
seismic
Post by seismic » Mon Mar 30, 2020 9:44 am
check if git is installed and working - try cloning a repo
seismic
Post by seismic » Mon Mar 30, 2020 3:00 pm
its more orac things than TT - but i'll post here anyways.
i wanted to have a look at the main.pd - strangely it crashes pd when i open it on my raspberry and says:
~ $ sudo pd
unable to load preferences file : orac.json
TT thread prio 99
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
Pd: signal 6
Segmentation fault
the talking to the display is done with OSC messages? where can i see how it's done - which pd files to have a look at?
and what exactly is the KontrolModule doing? wehre does it's source come from?
any replies are appreciated - thx
thetechnobear
Post by thetechnobear » Mon Mar 30, 2020 7:06 pm
@seismic , i dont talk to the display via PD,, or osc - its done in my KontrolRack external, which in turn uses my TTuiLite library.
source code:
https://github.com/TheTechnobear/MEC/tr ... ck/devices
https://github.com/TheTechnobear/TTuiLite
note: TTuiLite has a few things in it that ive not finished off yet... e.g. pd external and sidekick, these are kind of placeholders at the moment.
KontrolRack/Module - you'll find in the MEC repo, as above.
they are pretty much the heart of Orac, really Orac just uses PD as a kind of 'glue',
all the code that handling parameters, rebuilding the PD patch, menus/ui.... thats all done in KontrolRack/Module which is an external write in C++
is there something you are particularly after?
seismic
Post by seismic » Tue Mar 31, 2020 1:51 am
no nothing in particular - i just try to understand a little whats happening where.
i'll then check out the MEC things.
it's a very clever thing you built there - but not too easy to understand for diletants like me :)
stevemensink
Post by stevemensink » Sat Apr 18, 2020 8:32 am
Hey People, I have been running in to the Watchdog error recently after i had reset my terminal tedium.
So basically if i for instance call "sudo pd -nogui -rt -r 48000 -verbose /home/pi/terminal_tedium/software/passthru.pd" or any other patch, i just get an infinitely repeating message:
watchdog: signaling pd...
I can find other people that have had this problem in this thread, but i cant seem to figure out how they resolved it.
Any ideas?
stevemensink
Post by stevemensink » Sun Apr 26, 2020 10:11 am
I have done everything from getting new sd cards, different formatting options, different Rapsberry pi's, different terminal tediums. Still same error sadly. "watchdog: signaling pd..."
thetechnobear
Post by thetechnobear » Mon Apr 27, 2020 9:37 am
pd creates the watchdog to check to see if PD is hanging, basically the main render loop will ping back to it to say 'all is good', so you usually just see a couple of start up, and then when PD is 'running' they stop.
so the main event loop would appear to be hanging (or dsp not running?)
Id test a couple of things....
try an empty pd patch , that just starts audio (perhaps outputs a simple sin to outputs) and has not 'terminal tedium' objects in it.
if this works then its likely the TT gpio is for some reason locking up .. you could then remove one by one to see which
if an empty patch does not work, then Id have suspicions about the sound card configuration/hardware.
perhaps test the soundcard with using aplay to output a wav file.
i.e. focus is, is it PD with the issue or a hardware/configuration issue.
Im assuming you have also check dmesg etc for any issues initialising etc.
the other question is... what changed between it working, and not?
(sorry, I cant give specifics, as im using the monome norns image on my TT, so it might be setup slightly differently)
thetechnobear
Post by thetechnobear » Thu Apr 30, 2020 12:07 pm
so Ive been doing a little work to make terminal tedium even more fun, and useful (to me at least ;) )
building on the work I did for Orac, Ive now ported by Sidekick application, with OSC and SuperCollider support!
What is Sidekick?
Sidekick is an application/patch launcher
basically, it will allow you select and switch between patches.
It currently supports launching of supercollider, puredata and 'arbitary shell' patches.
It also will 'auto start' the last patch when you power up.
to bring it up , simply hold all 3 buttons down for about 3 seconds, then the menu will appear.
but there is more :)
It is also provides an OSC interface to the terminal tedium hardware.
so you can write patches in PD, Supercollider or any other programming language that supports OSC and use the TT knobs/cv, buttons, and the displays.
this approach makes it very simple to create new patches in your favourite language.
Ive create a few Supercollider demo programs to help show this:
Default - basically a starting point for your SC patches
Simple - a simple oscillator, which uses the knobs, and displays freq/amp to screen
GrainBuf - a simple granular player which shows loading audio files from sdcard
LiveCoding - a kind of 'proxy' that allows you to develop your supercollider patches on your desktop, then you can just copy them to the TT to run standalone.
oh... I also updated TTui and the Osc interface to include a pretty full graphics api :)
Installation
Im assuming the fates distro (as before)
if thats installed, then its a simple one line command to install (assuming internet connection on TT!)
Code: Select all
sudo curl https://thetechnobear.github.io/apt-tt/install.sh | sh
more details on the wiki...
https://github.com/TheTechnobear/TTuiLite/wiki
EDIT: fixed typo
thetechnobear
Post by thetechnobear » Thu Apr 30, 2020 2:36 pm
quick instagram demo of sidekick, and also Push 2 connected to TT :)
djthopa
Post by djthopa » Thu Apr 30, 2020 6:07 pm
As always hats off! Going to install tomorrow :)
Would norns mother work on this?
thetechnobear
Post by thetechnobear » Fri May 01, 2020 4:55 am
no norns mother wont work...
but it would be relatively easy to take the organelle mother, and get it to work.
if I have time I'll take a look
djthopa
Post by djthopa » Fri May 01, 2020 5:46 am
:hail: :hail: Thanks a lot M.
djthopa
Post by djthopa » Sun May 24, 2020 7:29 pm
Hi Technobear,
I tried updating orac to the latest but my tt would not start so i did a fresh install of fates (latest)
I followed your install instructions on the wiki..
a) disable encoders and screen in /boot/config.txt just comment out the line that says something like dtoverlay=fates-buttons-encoders dtoverlay=fates-ssd1322,rotate=180
b) disable norns sudo systemctl stop norns.target sudo systemctl disable norns.target
c) i rename host to tt, but thats optional! (but Id recommend it ;) ) use raspi-config (you can also setup wifi and expand fs whilst here)
and i copied orac.deb to the home directory.
My lcds do not turn on and the two leds on tt are constantly on :(
Any ideas?
