terminal tedium (raspberry zero, pi2, pi3 codec / pd thing)
tysm
Re: terminal tedium (raspberry zero, pi2, pi3 codec / pd thing)
Post by tysm » Tue Oct 13, 2020 8:38 pm
mutronic wrote:
Mon Oct 05, 2020 12:55 am
Looking for the gerbers for the tt on the GitHub and the link is broken. Does anyone have the files or at least willing to take a screenshot of the board?
seconding this request!
seismic wrote:
Sun Oct 11, 2020 3:18 pm
lib_abllink.~.so -> just need to search for the source and should be like all the others to compile..
The lib_abllink~.so shared library is compiled from this Pure Data external repo that integrates Ableton Link and Pd.
libmec-soundplane.so -> donno if i need it at all?
libmec-eigenharp.so -> donno if i need it at all?
Looks like these two objects provide MEC support for the Soundplane and Eigenharp controllers.
seismic
Post by seismic » Thu Oct 15, 2020 9:55 am
messed up the quote thing... sry
see below..
seismic
Post by seismic » Thu Oct 15, 2020 9:57 am
they are where they ever where:
https://github.com/mxmxmx/terminal_tedi ... m_2016.zip
i found a version that i had on my zero laying around.
thanks for pointing tha tout - i will try to figure out the remaining errors with marks help
belzrebuth
Post by belzrebuth » Mon Oct 19, 2020 9:22 am
Are there any (new) repositories for TT patches?
I don't have much of PD experience so I'd very interested to try any new patches I might have missed..
TT should be great for people designing their own PD sketches I guess but I often wonder how much greater this thing could be if there was a database of user examples of what it can do (sampler, drum synth, wavetable voice, maybe even a mod source or else)
seismic
Post by seismic » Fri Oct 23, 2020 1:48 am
hmm, maybe someone with experience with the WM8731 can help out here:
i try to DC couple the output of the codec, as i'd love to generate some X/Y data for my ILDA laser..
i added an offset so the output swing should be +/- 5V when 0-3.3V comes from the WM8731.
the C32 Elko is bridged..
somehow the output seems to be floating back to zero, it works down to like 1Hz but the i get distortion and the "float back" phenomena..
appreciate any hints/ideas?
seismic
Post by seismic » Tue Mar 30, 2021 1:47 pm
Good news about the DC coupling but floating back:
Its my fault, i miss typed/copied the label of the reference voltage.
Bad news: the pi zero doesnt seem to habe enough „mmmmppffh“ to run ORAC and patches on top of it.
But since i kinda ceased eurorack stuff its no big deal anyway.
seismic
Post by seismic » Tue Mar 30, 2021 1:53 pm
Another question: is somebody here that would help me convert the terminal_tedium_adc external to work with the bcm library instead of the kernel module??
:hail:
Then we could try to hook up more fancy spi displays on another CS pin and run them with „juj fbcp“. That would give native x-window support (like retropie)
henrry
Post by henrry » Tue Apr 06, 2021 4:26 pm
Hello.
Did any of you ever try to load a Pure Data convolution reverb patch in TT?
And if so, what's your feeling about it? Does it work nice, real time, low latency and with long IR?
