Arp 1601 Sequencer clone
EOTS
Wood type choices?
Post by EOTS » Tue Jun 18, 2019 8:16 am
Hi,
with the enclosure + wood cheeks variant:
Enclosure with Wood Cheeks: Metal 'boat' chassis finished in black powdercoat plus finished wood cheeks (preliminary pricing US$199- deposit $99 and balance of $100)- compatible with prior versions of the 1601 pcb/panel sets. Wood cheeks will be made from maple, walnut, cherry , poplar or another species, and finished
Let's say, I'd only want walnut, can this be specified in the order
or is the wood species chosen/assigned randomly?
Best regards,
Martin
synthcube
you will be assimilated
Post by synthcube » Tue Jun 18, 2019 8:18 am
we have not made that decision yet--- at the moment, we were thinking to make/offer only one species of wood, likely walnut or cherry. However, we are looking into making the sets available in walnut, cherry and polar... thoughts welcome
facebook: https://www.facebook.com/2SynthCube
synthcube webstore www.synthcube.com/cart
music from outer space: www.musicfromouterspace.com
blacet research: www.blacet.com
MOTM DIY Analog Synthesizers: www.motmsynthesizers.com
music from outer space euro smt: www.mfoseuro.com
fuzzbass
Post by fuzzbass » Wed Jun 19, 2019 12:51 am
synthcube wrote:we have not made that decision yet--- at the moment, we were thinking to make/offer only one species of wood, likely walnut or cherry. However, we are looking into making the sets available in walnut, cherry and polar... thoughts welcome
Poplar (I believe you meant) is not typically attractive enough for clear coating, and often has bands of green running through. However, it is strong, easy to work, very light in weight, and of comparatively low cost in US. If I was using it for cheeks, I would probably paint it solid colors or black.
Wired for weird
synthcube
Post by synthcube » Wed Jun 19, 2019 8:00 am
yes- poplar-- so we've decided to offer cheeks in oil finished walnut and cherry, and stained poplar; the poplar will be a lower cost option but with the dark stain should be very handsome...
Kipling
Post by Kipling » Fri Jun 21, 2019 9:05 am
A completed one for sale on eBay in the U.K. if anyone is interested. This is not mine and I have no connection to the seller, nor can I recommend it or otherwise.
jamieoxford
Post by jamieoxford » Mon Oct 21, 2019 6:02 am
synthcube wrote:yes- poplar-- so we've decided to offer cheeks in oil finished walnut and cherry, and stained poplar; the poplar will be a lower cost option but with the dark stain should be very handsome...
Hello, is there a finalised V5 BOM for the 1601?
Hoping to do all my ordering for this and the TTSH in one go!
Kipling
Post by Kipling » Mon Oct 21, 2019 11:56 am
jamieoxford wrote:Hello, is there a finalised V5 BOM for the 1601?
This one has been produced by Patrick (LED-Man/DSL-Man)
https://www.dsl-man.de/display/TTSHADDO ... aEiVxBfEq4
synthcube
Post by synthcube » Tue Nov 12, 2019 5:14 pm
as an update, the current run of 1601 v5 pre-orders is almost ready to go.
- boats and wood cheeks are all here in the shop
- panels and pcbs are all here in the shop
- first batch of full kits is ready, with exception of the below:
While this version is the v5 1601 PCB from JMLS, we added the panel graphics and holes to allow for the addition of the Divider circuit, as a bonus. The Divider comes as a separate PCB (also here in the shop)
the holdup was arranging to get the latest BOM from JMLS, but we were able to locate a BOM, so we will be kitting those in the next few days, then shipping pre-orders against the queue.
it is a bit more complicated to build with the addition of the second pcb, but we think the extra divider capability is worth it!
cereyanlimusiki
Re: Arp 1601 Sequencer clone
Post by cereyanlimusiki » Fri Nov 20, 2020 8:30 am
Hey all,
Hope you are all healthy and fine
I am considering buying a prebuilt version 1 of pcb.
What are differences or disadvantages of v1 vs recent version ( I assume 6 )
Thanks in advance
Kipling
Post by Kipling » Fri Nov 20, 2020 11:59 am
Functionally, Rev 1 to Rev 5 are identical with only minor differences in PCB track layout and a move towards SMD for a few obsolete DIP ICs, and in Rev 5 a different make of slide switches was introduced.
The current offering, Rev 6c, offers adjustable gate, clock and position 1 out voltage trimmers so making it more eurorack friendly. Other than that they all do exactly the same thing.
I still have my two prototypes which are only very slightly different to Rev 1 (to correct a couple of component spacing issues I encountered).
tommy.york
Post by tommy.york » Sun Nov 22, 2020 12:58 pm
Quick question: what panels are going to fit my Rev. 3 PCB? I just finished mine... today, and I'd tried this matte clear coat on the panel, which I will never ever try again - it cracked once it was on the surface, then taking it off took off the silkscreen. Open to any recommendations for where to find a replacement, too!
Music @ Soundcloud, streaming DIY builds + live music @ twitch and YouTube.
Kipling
Post by Kipling » Sun Nov 22, 2020 1:55 pm
All the panels have identical dimensions. Latterly, Synthcube have added the clock divider option so it has the appropriate holes and text above the power switch, and this is as far as I know your only option for a replacement panel, unless someone has a spare panel somewhere. I can send you the drawing for getting a one-off made if you wish, but it could work out quite expensive. I hate to think how much a Front Panel Express one-off may be.
If the panel and black powder coating is ok you could get the screen print redone somewhere. Again the panel dxf drawing has all the text on a separate layer.
synthcube
Post by synthcube » Wed Nov 25, 2020 3:11 pm
We have recently updated the Main BOM v1.6.2 and Divider BOM v1.6.2 - posted here- for rev 6a pcbs
