So here's the sister thread for the Hihats! I posted the Bassdrum thread here earlier today: viewtopic.php?t=111384
This and the other thread will serve as interest check and tech support/build threads for these projects!
This is the Mutant Hihats module. It is an evolution of the infamous 808 circuit. But it's been redesigned from the ground up to be a powerful creative tool in the modular world!
I'll have eurorack panel and PCB sets for sale as well as I'll be stocking those pesky vactrols and long pin headers to bundle with PCB sets if you like. So, all you'll have to find are the easy parts (which there will be a BoM for of course!)
**IF YOU'D LIKE TO GET AN EMAIL WHEN THEY'RE IN STOCK, SIGN UP HERE**: http://eepurl.com/pDf_5
Please indicate using the poll above how many sets you might be interested in. This will help me determine how many to stock!
I will have audio and video demos like crazy over the next few weeks. Just waiting for the last prototypes to arrive at my door so I can record them!
Primary Features
While the internal noise generator is based on the metallic noise generator in the 808, you can plug virtually ANY sound source into the EXT input and make all sorts of cool hihats/percussive sounds!
- analogue hihat circuitry capable of synthesising vanilla TR-808 open and closed hihat sounds (simultaneously)
- external audio input lets you synthesise hihats from virtually any sound source (Jupiter Storm, vcNOIZ, etc.)
- lo-fidelity original VCAs replaced by OTA-based modern VCAs
- VCA DRIVE control for each hihat allows you to dial in anything from soft metallic hihats to extremely overdriven, crunchy hihats
- Exclusive switch lets you select how the two hihats (open/closed) interact with eachother when triggered at the same time
- cutoff frequency control for internal resonant bandpass filter
- resonant filter can be switched on/off
- modular level mutual accent input (0-5V CV)
- trigger input accepts almost anything as a trigger signal
- non-invasive analogue optocouplers used for voltage control, thus, completely vintage sounds can still be had if that's what you're after!
- completely redesigned, hi-fi signal chain spares no expense by replacing cheap transistor amplifiers with low noise opamp and OTA equivalents
- you can dial in super hot, modular level output levels (up to 20Vp-p!)
Audio Demos
[soundcloud url="https://api.soundcloud.com/tracks/147745478" params="auto_play=false&hide_related=false&visual=true" width="100%" height="450" iframe="true" /]
[soundcloud url="https://api.soundcloud.com/tracks/147744352" params="auto_play=false&hide_related=false&visual=true" width="100%" height="450" iframe="true" /]
[soundcloud url="https://api.soundcloud.com/tracks/147745678" params="auto_play=false&hide_related=false&visual=true" width="100%" height="450" iframe="true" /]
